Old 05-03-2010, 01:14 PM   #1
Strummer OP
Snail Trailer
Strummer's Avatar
Oddometer: 2,271
Drz 400 Chain Lengths - Need Info
I would like to know if anyone has experimented with different sprocket combos and made a note of how many chain links each combo uses? I want to swap between my motard wheels (15/41) and dirt wheels (14/47) and would prefer using one chain. Any thoughts?
Strummer
Strummer's music here - https://soundcloud.com/vospar-gem
Videos here:http://www.youtube.com/user/strummerdrz?feature=mhum
Strummer is offline   Reply With Quote
Old 05-03-2010, 09:00 PM   #2
Racerman27410
Racerman27410's Avatar
Oddometer: 503
which model do you have? S or SM?
you can do a 14/44 and 15/41 with a stock SM chain which i believe is 110 links.
Racerman27410 is offline   Reply With Quote
Old 05-03-2010, 09:06 PM   #3
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
What i do is:
13/44 for dirt
16/40 for SM.
Uses the same chain, i just swap the front sprocket.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 05-04-2010, 06:18 PM   #4
Strummer OP
Snail Trailer
Strummer's Avatar
Oddometer: 2,271
I have both an E and an S. I want to use both for enduro plus a comfortable 100 kph on the highway. But also use the S for extended touring at around 120 kph. Was thinking 15/47 for enduro and 15/41 on the factory motard 17" wheels for extended touring. Hoping that will give me reasonable versatility.
Any ideas welcome.
Strummer
Old 05-04-2010, 06:32 PM   #5
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 810
Stock chain length for 15/44 is listed as 112... that does not work with 14/48... too short. AMHIK.
114 does the trick for both.
Ralf Wilkowski
Been there - already forgot about it...!
Follow my Journey, pursue insanity:
www.itwasnotme.com
signit98 is offline   Reply With Quote
Old 05-04-2010, 09:55 PM   #6
ptgarcia
Huh?
ptgarcia's Avatar
Oddometer: 509
On my S, with dirt wheels I run 15/47 and with SM wheels 15/44, both with the factory 112 link chain. 15/41 wouldn't work (chain too long) but 14/48 should work fine.
Pauly
'06 DR-Z400S
ptgarcia is offline   Reply With Quote
Times are GMT -7.   It's 05:49 PM.
