Old 05-09-2010, 05:53 PM   #16
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,199
That's a brilliant effort.
Old 05-09-2010, 08:14 PM   #17
TX Ryder
TX Ryder's Avatar
Oddometer: 104
I wish along with the last name, that I also shared Paul's skills. That's some incredible craftmanship he's done, topnotch stuff! Thanks for posting the pics.
TX Ryder is offline   Reply With Quote
Old 05-10-2010, 12:16 AM   #18
igormortis
igormortis's Avatar
Oddometer: 1,380
Wow. And it still looks like an Airhead.
How do you guys in Oz register something like that for road use? i.e. an entirely new frame?
igormortis is offline   Reply With Quote
Old 05-10-2010, 05:08 PM   #19
Beemerboff
Oddometer: 2,334
He doest seem to see any benifit it triangulation, so I imagine there wont be many other frame designers who see much merit in the design.
It also looks like it is intended that the engine /gearbox is a stressed member, but a quick look at BMWs method of attaching the box to the engine will tell you that it was never intended for that purpose.
Fork angle looks a bit steeper than normal for a offroad bike too.
Leaves me cold, but there is no accounting for taste , I suppose.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 05-10-2010, 06:15 PM   #20
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,199
Box sections are all about cross sectional area. Make no mistake, that frame's hell for strong. The triangulated box section near the swingarm pivot points will be far stiffer than it'd ever need to be to resist any flexing that could ever be produced by those two tire contact patches.
Stressed member transmission? Wrong again. The engine's held in place, and becomes a bit of a stressed member by virtue of it's shape, though it bears no chassis load. The trans is bolted to the motor, just like a stock airhead.
Steering geometry appears to be a bit steeper than maybe BMW standards, but well within acceptable norms from manufacturers that build offroad bikes that actually handle well.
That's three for three.
You have any opinions founded in substantive reason?
Old 05-10-2010, 07:05 PM   #21
OldDog
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,719
'boff, you may not have bumped into Pauls work before but he's a very well respected bike builder over this side of the pond, easily in the same league as companies like HPN, only he's small time and a lot easier to approach. He's got a very long racing background as well, so he knows his stuff. As you can see by Pezz's response, he's placed an order for one of these frames sight unseen, thats how much faith people place in this guy. I personally have had a fair few dealings with him when i built up my Ducati Dirt bike, he rebuilt the suspension and advised on the new geometry that i added to the bike, some of what he told me to do didn't seem to make sense at the time but i just did as i was told (grudgingly) and i'm glad i did, It rides like cadillac on the dirt, a testament to how much this guy knows.
Okay enough pissing in Pauls pocket, back to the show........
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is offline   Reply With Quote
Old 05-11-2010, 07:16 AM   #22
Beemerboff
Oddometer: 2,334
It isnt instantly clear were the shock is mounted , but what triangulation there is seems to be seems to be holding up the seat.
Sure a big heavy box section can be made stiff, but a well designed triangulated frame can be made lighter and stiffer. And there is a large unbraced length over the top of the engine - remember that deflection is a hyperbolic function of of the length, that is, a long tube will deflect a lot more than one half the length. So for the same stiffness needs it to be a lot stronger.
The steering head looks strangely unsupported too.
But as a qualified structural engineer I am probably looking at it from a different viewpoint to you.
If the engine is not used as a stressed member that is as it should be, but then the top tube simply doest look up to the job.
But handsome is as handsome does, and there have been some weird looking frames which defied all sense and logic and performed quite well - perhaps this will be one of them.
Old 05-11-2010, 07:31 AM   #23
AliBaba
AliBaba's Avatar
Oddometer: 372
Check prev page.
AliBaba is offline   Reply With Quote
Old 05-11-2010, 08:31 AM   #24
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,199
The top shock mount's clearly visible in the view I posted above.
Apparently this bike's lighter than a stocker. ie. he appears to have met the design goals of increased strength and reduced weight.
That box section backbone isn't going to flex. I'm just a guy with a bit of practical experience in fabrication and design. I'm not worried about that structure giving up much in the way of distortion and deflection. You're the structural engineer: Run the numbers.
As regards your other comments, you're either a troll or a pompous fool.
As we say in the trades "If it wasn't for engineers, we'd all be out of work."
Old 05-11-2010, 08:36 AM   #25
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,496
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 05-11-2010, 04:40 PM   #26
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,700
Beemerboffs niether of these.
Grumpy old man with some ideas that are refreshingly outside the square yes.
Not impressed by fashion or popular opinion, yes.
Able to be pursuaded to consider alternate viewpoints, sometimes.
Pursuaded to change his opinion, only if presented with evidence.
I've seen some good looking pics of a frame that looks like it would be stiffer than the standard rubber item but a stiff G/S under 183kg wet is achievable with a conventional reinforced frame so I can't say I've seen any "evidence" but I sure am impressed by and interested in Pauls work.
I'll be watching to see what MkII, III & IV versions evolove into.
My bike is slow but the earth is patient.
Rucksta screwed with this post 05-11-2010 at 04:45 PM
Rucksta is offline   Reply With Quote
Old 05-11-2010, 06:38 PM   #27
OldDog
aka Hugh Jarse
OldDog's Avatar
Oddometer: 4,719
I think you have to listen to peoples opinnions , you never know you just may learn something, so in that spirit 'boff i'd like to understand this a bit better.
I'm assuming that the part you're talking about is the area forward of the front mount as the frame to the rear of that is braced using the engine as part of the frame structure, tieing into it at the top, then lower down the frame where i assume the gearbox bolts to the engine, as well as underneath it, so by rights the frame should be very strong from this area back? So on the "front" section, it is relatively short so it should fall into what you say about a short box section being stronger/stiffer than a long length? Plus the triangular piece under the headstem, isn't that strong enough to support the deflection etc caused here by the front wheel hitting a large bump or whatever? Do you think that the headstem would be better with an extra support gusset on top between the headstem and the frame?
Cheers
Bill
Old 05-12-2010, 12:05 AM   #28
BOOTLACE
Bikie Scum.
BOOTLACE's Avatar
Oddometer: 4,247
Just rang Chris, to ask him how it rides. "Bloody awesome mate!"
I guess that's what matters in the end, huh?
bootlace
BOOTLACE is online now   Reply With Quote
Old 05-12-2010, 02:11 AM   #29
Phreaky Phil
Oddometer: 1,884
Wonder how much $ for a frame ?
Phreaky Phil is offline   Reply With Quote
Old 05-12-2010, 02:54 AM   #30
Steve in NZ
scared/cheap
Steve in NZ's Avatar
Oddometer: 1,045
Kiwi style
I certain ya could cobble somehing up Phil. Just to be carbon neutral how about doing it out of "Pine".
I think the woodgrain frame would look super
Cheers Steve
bike = the purple pig
Steve in NZ is offline   Reply With Quote
Times are GMT -7.   It's 06:46 PM.
