Old 05-12-2010, 09:21 AM   #1
metal OP
President of FRONJ
metal's Avatar
Oddometer: 151
Garmin 276c questions (uploading files)
I'm trying to install a .gpx file of the Continental Divide onto my Garmin 276c. When I purchased my 276c all it came with was a USB cable and a wall charger.
At first I tried to just plug the GPS into my computer with the USB cable, but luck. Then I remembered that I usually have to have the driver, so I downloaded it. Now when I plug the GPS into my computer the GPS' screen says "USB Connected," so I know that it is now plugged into mu computer. How do I now transfer files into the GPS now? Is there some programe that I need that I am missing?
I'm planning on leaving in about 3 weeks, so I need to figure out some solution to this.
metal is offline   Reply With Quote
Old 05-12-2010, 09:27 AM   #2
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,546
Yeah, Garmin Mapsource, although there may be some 3rd party software that will work.
You don't just load .gpx files directly to a 276C.
3 weeks is nowhere near enough time to figure out a GPS.
Mike S.
'09 Bonneville Black
AMA MSTA STOC
http://autos.groups.yahoo.com/group/...orcycleriders/
tbirdsp is offline   Reply With Quote
Old 05-12-2010, 09:47 AM   #3
metal OP
President of FRONJ
metal's Avatar
Oddometer: 151
I tried to download Garmin MapSource. When I went to install the software on my computer it wouldn't allow me since "Previous MapSource not Found."
All I need for this trip is to upload the file and follow the trail. I am not really looking to know all of the ins and outs of the system.
Old 05-12-2010, 10:20 AM   #4
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,289
Send a message via AIM to rwamf Send a message via Yahoo to rwamf
you have to have Mapsource to load tracks into your unit, either borrow a copy from someone of buy a mapset.
You will open the 'gpx' file in mapsource and then select ' send to gps' and it will install the tracks, I believe the 276 holds 15 tracks @ 700 points each. You can filter, combine etc in Mapsource.
Garmin Training Center
then you can run the update
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE
Robert
rwamf homepage
rwamf screwed with this post 05-13-2010 at 08:20 AM
rwamf is offline   Reply With Quote
Old 05-13-2010, 03:09 AM   #5
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 11,662
Unless you plan to spend a lot of time between now and then, don't rely on the GPS as your primary navigational aid on your trip.
dunno.....
HTML code is Off
Times are GMT -7.   It's 12:38 PM.
