Old 05-17-2010, 04:34 PM   #1
llewdaert OP
llewdaert's Avatar
Oddometer: 270
Plastic Tank restoration
Hello Does anyone have some wisdom to pass on regarding restoring plastic fuel tanks. I have a XR 500 [its an ADV type of XR 500!] with a oxidised looking, standard OEM fuel tank. Is there a polish or proprietary product, or do you wet and dry or scotchbrite or perhaps both.. Thanks in advance.....
llewdaert
llewdaert is offline   Reply With Quote
Old 05-17-2010, 04:42 PM   #2
kipo
kipo's Avatar
Oddometer: 2,196
llewdaert
I'm restoring a 1980 PE 250 and was about to ask the same question.
Jesus loves me, but everyone else thinks I'm a prick
"The only true wilderness is between a Greenies ears"
Full Member - Quorn Schnitzel Club
kipo is offline   Reply With Quote
Old 05-17-2010, 04:59 PM   #3
searchin oz
Sand, Gimme more sand
searchin oz's Avatar
Oddometer: 1,169
Steel wool.
I done the tank and gaurds on my old XR with steel wool and it came up pretty good. If real bad try scraping without gouging the plastic with a butter knife or similar.
Dont criticize someone till you have walked a mile in their shoes,
at least then if they get angry they will be a mile away - and barefoot.
searchin oz is offline   Reply With Quote
Old 05-17-2010, 05:06 PM   #4
thecanoeguy
just a yobbo from oz
thecanoeguy's Avatar
Oddometer: 1,854
my 87 klr was faded
i hit the plastics with a paint stripping gun and they came up like new ,(don,t try this at home ,kids)
thecanoeguy is offline   Reply With Quote
Old 05-17-2010, 07:42 PM   #5
shank
Shank950
shank's Avatar
Oddometer: 829
Ballards Sell a Plastic "POLISH" Rejuvinator, Or something like that
A mate used it on his XR400, and it worked a treat,
I was amazed at the end result, I'm not sure of the amount of elbow grease that is required.
Vinny: What the fuck do you mean, replicas?
Sol: They look the shit, don't they? And nobody is gonna argue. And I've got some extra loud blanks, just in case.
Vinny: In... Oh, in case we have to deafen them to death?
shank is offline   Reply With Quote
Old 05-17-2010, 08:33 PM   #6
DRjoe
DRjoe's Avatar
Oddometer: 5,115
I just finished polishing a plastic fuel tank using normal cut and polish compound with wool buffing pad on the buffer. It worked great just try resist spinning the pad to fast.
I have used wet and dry to remove sctratckes as well and then polished them of using a blow torch. Needles to say dont do that on a tank with fuel or fuel vapour in it.
Old 05-18-2010, 12:45 AM   #7
Aussie Trev
aka DRTrev
Aussie Trev's Avatar
Oddometer: 5,727
Mate of mine, crash repairer, put me on to 'T Cut' polish some years ago to replenish scratches in cars. I use it on my IMS translucent tank every now and then (without too much elbow grease) and it appears to be keeping it at its original 'colour'.
2011 Triumph Tiger 800XC
1982 PE175Z
Full member......Quorn Schnitzel Club
"Just having a crack"
Aussie Trev is offline   Reply With Quote
Old 05-18-2010, 01:21 AM   #8
sequent
South Australia's own....
sequent's Avatar
Oddometer: 475
For what it's worth, I've used something called Clorox "Gumption" which is an abrasive kitchen cleaning paste with a scotch brite pad or steel wool with success....
In life, if you don't risk anything, you risk everything...
sequent is offline   Reply With Quote
Old 05-18-2010, 01:30 AM   #9
Tee Dee Mmm
Tee Dee Mmm's Avatar
Oddometer: 1,628
I have found this a good product.
http://www.novusautoglass.com.au/plastic.htm
Cheers
Tee Dee Mmm is offline   Reply With Quote
Old 05-18-2010, 02:10 AM   #10
Miss Jane
Ride like a girl
Miss Jane's Avatar
Oddometer: 1,949
I'd give a product like plexus a go, keeps my black fuel tank looking good as new even though I have put the odd shallow scratch in it. Just spray it on and give it a wipe, easy on the elbows too.
Miss Jane is offline   Reply With Quote
Old 05-18-2010, 03:00 PM   #11
outback jack
outback jack's Avatar
Oddometer: 6,913
If your considering paint have a read of this, i tried once to paint a kids Pee wee tank but the fuel vapours beat me. I had no idea you had to seal the inside of the tank as well, by the way the paint i used on the rest of the plastics held up really well.
http://www.4strokes.com/tech/plastic_restore/
There's something ugly about a NEW bike on a trailer.
CCC ride Cattle, Coal & Cane or Captains Crossing & Castlemaine.
http://www.advrider.com/forums/showt...1#post17025601
outback jack is offline   Reply With Quote
Old 05-18-2010, 04:54 PM   #12
crash n bern
crash n bern's Avatar
Oddometer: 1,302
It will depend on how oxidised your tank is. VMX magazine did a feature on in some time ago. If it's in bad condition you have to scrape the tank with a Stanley blade (Although I've had good results with beadblasting.) to get all the oxidation off. Then start sanding with wet and dry sand paper and work your way up to 1200 grit, then go to a plosih. It's a long and tedious process.
Try http://www.ozvmx.com/community/ A lot of old dirt bikers here that spend all their spare time restoring old bikes. If you do a forum search you'll dig something up on the subject.
Or you could contact http://www.vmxmag.com.au/02_Home%20page/homepage.html and find out the back issue that had the article.
crash n bern is offline   Reply With Quote
Old 05-18-2010, 04:56 PM   #13
ECKS-Man
ECKS-Man's Avatar
Oddometer: 873
This is a good product, although I am not convinced it will restore badly faded plastics, and certainly not with good long-term results. I'd look at the polish option, starting with Gumption. Then go Plexus to keep the shine afterwards.
Work to live, Live to Ride!
ECKS-Man is offline   Reply With Quote
Old 05-18-2010, 05:02 PM   #14
Jim Bud
Jim Bud's Avatar
Oddometer: 3,439
Think of it as a headlight lens.....
this is the best instruction I have seen to polish a plastic surface....if it works on a lens, it will work on a tank....
http://www.popularmechanics.com/cars...enance/4252611
Jim Bud
"Nearly all men can stand adversity, but if you want to test a man's character......give him power".....Abraham Lincoln
Jim Bud is offline   Reply With Quote
Times are GMT -7.   It's 01:02 AM.
