05-17-2010, 08:22 PM
#1 |
Voyageur
Oddometer: 79
BMW airhead, quick fork question
Any help or suggestions appreciated...
I have auxiliary instrument mounts on my R90/6 that are secured under the top "guide support" bolts (#8, picture A). What's the best way to remove these bolts in order to remove the mounts (the bolts are in there tight)? Also, what size wrench or socket do I need to get, these are larger than anything I have. Mounts in questions are #14 in picture B. Picture A. ![]() Picture B.
1976 R90/6 |
05-18-2010, 06:54 AM
#2 |
Still a stupid tire guy
Oddometer: 7,339
The top clamp nuts are 36mm in diameter, and there's a wrench in the stock BMW tool kit to take them loose. It's really short, so I usually get a 1-1/4" wrench on the other end for leverage.
Use caution as when you remove the nuts, too, as they are also the fork spring keepers. It's easy to get a finger pinched between the nuts and the handlebars. DAMHIK.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln |
05-18-2010, 07:16 AM
#3 |
Voyageur
Oddometer: 79
I don't have the 36 mm wrench in my kit (recently got the bike), and I think that's for the axle bolt, too. I'll pick up a wrench for the bike and socket for home use. This is all part of changing out the handlebars, so they'll be off when I remove the nut.
1976 R90/6 |
05-18-2010, 11:32 AM
#4 | |
Oddometer: 7,339
05-19-2010, 05:04 PM
#5 | |
Red Clay Halo
Oddometer: 11,346
I think you'll probably have to removed the handlebars to get in there with any tool.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
05-19-2010, 05:44 PM
#6 |
Oddometer: 9,786
Right, your best bet is to get the appropriate wrench, I believe its still available, otherwise I also think its the same wrench used on Porsche Fan Belt pulleys. A socket can be used if ground but it is unwieldy in that the center of torque applied is 2" above the very skinny bolt.
These top nuts do a few things as mentioned, importantly they hold in the springs, so make sure its supported off the front tire. They also locate the plate in relationship to the lower clamp. That is if you remove the nut/bolt and reinstall you can actually change the alignment of the fork tubes and end up with a binding fork. Much has been written about this issue and the use of a "torque relief bar" basically to prevent the torque on the bolt from applying torsion and flexing the system they apply counter pressure using a pry bar. And lastly, these suckers are supposed to be tight, iirc 90-100 ft pounds. I have these same plates on my bike, I have an S fairing. I normally ride with out the S fairing. But I leave those plates in. Not worth the effort to remove/replace if I want to use a fairing. |
05-19-2010, 08:09 PM
#7 |
Voyageur
Oddometer: 79
Thanks for the input. I ordered the proper wrench from Hucky's today and will look into the alignment issue before I get started. Is this going to be a deal breaker? I don't use the mounts and they annoy me just hanging out there.
1976 R90/6 |
05-19-2010, 08:18 PM
#8 |
Oddometer: 9,786
Nah they aren't that bad, its just basically that you want to tighten the fork cap, but you don't want to do so against the steering stop. So you have to use a pry bar or large screwdriver to resist the tightening effort.
Should be covered in any article on fork stiction relating to airheads. |
05-20-2010, 05:01 AM
#9 |
Guest
Oddometer: n/a
I quit using the stock wrench because of the stress it puts on the corners of the nuts, being a bit of a loose fit. I now use a quality adjustable wrench, I can get a perfect fit and it has more leverage. I polished all the doodads and don't use a dash pad so I want everything to stay all purdy.
05-20-2010, 05:49 AM
#10 |
Chronic Noob
Oddometer: 2,300
I have a 36mm ring spanner ground flat (no bevel) and thin on the bottom. The top side is ground to a taper towards the front. It can service the centre nut without removing or loosening the handlebars. Very handy for for doing steering head bearing adjustments as well as fork top nut removal.
Cheap as at an Auto store
If the Earth is flat why are my tyres round? |
