04-10-2012, 04:28 PM
#31 | |
Bin Ridin
Oddometer: 725
Skidplate install
I just put the wunderlich version on my GSA three weeks ago. Looks like similar complexity to your version. Took about an hour or so, mainly trying to see what went where due to not the best instructions and lots of bolts to install the first time around. The nightmare will be uninstall and reinstall to change oil as I do that a lot on my GSA. Teh littel stock BMS skidplate was easy to pull on/off. Not so these larger ones.
Bin Ridin "Terrorizing small animals on the road since 1971" |
04-21-2012, 11:32 PM
#32 | |
Oddometer: 207
I got the grommets and "shouldered bushings" in my kit, but apparently got an outdated set of instructions. In mine, it lists 4x M6x20 bolts, where I actually have 2xM6x20 and 2xM6x25. It also doesn't list the grommets or sleeves in the parts list or instructions. I figured out where the grommets had to go, and then that the M6x25 bolts had to be for mounting the front. But I don't have a picture of how the sleeves are supposed to be installed. I see from your picture that the sleeves were inserted from the inner face of the bash plate, pointing downward. Doing it this way is counterintuitive to me. (as bolt head will snug against bare rubber on bottom side) Can you verify this is how your instructions said to do things?
-- Dampers control movement over shocks and bumps Dampeners make things damp |
04-21-2012, 11:59 PM
#33 |
Don't want a pickle
Oddometer: 129
Your intuition is correct, the shouldered bushings should be inserted from below (pointing upwards).
And yes, M6x25 front and M6x20 rear. |
04-29-2012, 12:59 AM
#34 |
not-quite-a-n00b
Oddometer: 43
little help?
Okay, so the install overview which the OP posted at the start of this thread is great, except there's a gotcha which I discovered tonight when I finally got around to trying to do the install on my 2010 GSA... Following the instructions that came with the large plate, step 1 is of course to remove the original small plate. No problem there. But when I went to the next step, to remove the "buffers" which are hexagonal rubber blocks with bolts protruding from them used to secure the small plate to the engine case, I hit a wall.
Trying to unscrew these rubber buffers from the engine case seems impossible without tearing them in half. First of all, I don't own a socket large enough for them so I tried my crescent wrench, but the rubber just deformed and the wrench slipped off. Using pliers as a last resort I could grab the block and twist this way and that but it would not unscrew. I'm not even sure if it's threaded normally or reverse, so for all I know I could be twisting the wrong way. If I keep twisting this buffer it seems like it will just rip off leaving a threaded bolt with no head (or rather a chewed up bit of rubber in place of a head) in my engine block. ![]() Can anyone here *please* explain how to get these buffers off so I can proceed with the rest of the installation? Pics below (assuming I link them correctly) are the instruction diagram showing the buffers (9) I'm talking about with no indication which direction to turn them, then a pic of the offending item itself, and another pic of me unsuccessfully trying to unscrew it. ![]() ![]()
_____________________________________________ Snatching defeat from the jaws of victory since 2003! |
04-29-2012, 01:31 AM
#35 |
Oddometer: 395
GSQuester, I was going to update this thread (thank you OP btw).
Believe me, they are indeed threaded. The bottom section is all rubber, but the top little section right underneath the engine is a metal plate with the rubber glued or something to it. Take a spanner or like, right up under the engine and undo. FYI, pulling will not work. I found out the hard way saying fuck it and cut the rubber off, then almost panicked when I couldn't figure out how to get it out... |
04-29-2012, 09:01 AM
#36 | |
Oddometer: 207
They are basically a bolt with a hex plate on top, then rubber of the same diameter as the plate, then another hex plate and bolt. You can't loosen it with just the rubber because it deforms, but you should be able to turn it via the plate. Otherwise, go to the store and buy a deep socket of the appropriate size and get them out that way. (Or borrow one. I wonder if the local BMW dealer would oblige and help you get them out in the 20 seconds it would take with their tools) With respect to the rest of the install, the damn rear bracket is a POS nightmare. I was able to get the left side clamp and bolt on by hand after much finagling, but couldn't get it tight. The right one was just impossible. I tried using a tie down to compress the suspension to no avail. What ended up helping is putting the bike on the side stand, then lowering the center stand and holding it agains the ground with my foot. From there, a helper pressed the bolt through and I compressed the clamp and put the nut on. From there, we were able to get a crescent wrench and torx screwdriver on the fastener--I held the wrench and he drove the bolt. On the left side, getting a tool on the bolt is tough. I ended up using a torx socket with a 2-3 inch extension, mounting it to the bolt by hand, then attaching the rachet head driver after the bit was in place. From there, my helper was able to get a spanner on the nut, and I held the socket in place while he turned the nut. If I had to do it by myself, I don't think it would have been possible. Those deformed nuts require 20ft*lbs or so of torque just to tighten, and I couldn't hold tools in place and drive that much torque alone. No doubt the next major revision of the bike will have predrilled threads for that bracket on the frame. Finally, my instructions said to mount the rear most bracket to the skid plate before mounting it under the motor. If done that way, getting it through the center stand (which you'll probably have deployed) would have been comedic. Instead, mount the plate to the front and center brackets, then attach the rear bracket in place. Plenty of room to get the tools in without trouble.
-- Dampers control movement over shocks and bumps Dampeners make things damp rritterson screwed with this post 04-29-2012 at 09:09 AM |
04-29-2012, 10:04 AM
#37 |
Flatlander
Oddometer: 202
What's with the weird nuts and bolts that hold the plate to the rear bracket? They have some indentations on the nuts and then seize when installed on the bolts. My bolts then sheared when tightening. Needless to say I replaced them with metric nuts, bolts and wave washers from my personal supply.
04-29-2012, 10:53 AM
#38 | |
not-quite-a-n00b
Oddometer: 43
Oh well, at least I know which direction to turn the thing. Can't wait to get to the rear bracket install step - sounds like more fun! So much for this being an hour install...
04-29-2012, 01:26 PM
#39 | ||
Oddometer: 207
Those strange nuts make sense for the clamps holding the rear bracket to bike frame, as I bet they are very vibration resistant. Doesn't make nearly as much sense holding bracket to skid plate, as the plate has to be removed for oil changes.
-- Dampers control movement over shocks and bumps Dampeners make things damp rritterson screwed with this post 04-29-2012 at 01:32 PM |
04-29-2012, 02:21 PM
#40 |
Oddometer: 497
Damn. I'm usually a DIY-sort of guy, but your write-up is making me reconsider whether I want to install this myself or have the dealer take care of the swearing and bleeding knuckles.
04-29-2012, 03:20 PM
#41 | |
Oddometer: 558
Take it slow, don't tighten anything until it all comes together and you're done. Took me 30 minutes and I have hands like hams. |
04-29-2012, 03:57 PM
#42 | |
not-quite-a-n00b
Oddometer: 43
Hopefully the rest goes a bit more smoothly. I'm not that mechanically inept... honest!
04-29-2012, 05:51 PM
#43 | |
Oddometer: 207
It's only obnoxious because 95% of the install is pure butter and easy, the last 5% tricky. If I were to do it again, I might ditch the deformed nuts that came in the kit and replaced them with standard nuts and locktite. Then you only have to use wrench+driver for half a turn instead of 5 whole turns.
04-29-2012, 08:35 PM
#44 | |
Oddometer: 284
I had no trouble at all installing mine, and I worked alone. That said, it does help if you have a nice table-lift in your garage. Makes things much easier when you're not flat on your back, and rolling around on the ground.
Tom AMA - BMW MOA '07 Honda GL1800A Gold Wing '11 BMW R1200GS "TRIPLE BLACK" '12 Ford F250 Lariat SuperCrew 4x4 Diesel |
04-30-2012, 04:26 AM
#45 |
The Energizer Bunny
Oddometer: 3,794
With the right tools it's not hard to do. Using vice grips or your hands, yeah it would be harder.
ride till you can't. 1200GS black Cagiva Gran Canyon Italiano/rosso |
