Old 04-15-2011, 08:25 PM   #256
cug
Oddometer: 4,946
Originally Posted by Micatech View Post
We here ya. Although, 9" cases aren't likely to get made. As for the top loaders... we're sketching
While you are thinking about a top loader, maybe I can do an "idea dump" here and you might take things into consideration.
  • No hinges for the lids. If you have hinges you pretty much have to take of luggage that is strapped to the passenger seat area. The Touratech Zega or BMW OEM concept is pretty good, though I'd really do without the retainer strap of the OEMs.
  • Lids not too high. Makes loading awkward.
  • Should have a common size, so that available liners will "just fit". I'd love to fit the Kriega Bag in medium expansion the case.
  • I'd hate cases that have a large "lip" around the opening. Makes using tight fitting liners pretty much impossible and easily damages stuff. There must be better ways.
  • As I've mentioned before, a lot of my stuff like tent, sleeping bag, other things, pack to around 20cm width. That makes it a tight fit in an 8" case, would love to see 9" cases. Again ...
  • Lockable. But must close securely without locking. Meaning, vibrations won't open the lock.
  • Anodized or powder coated is a must for me.
Of course, that's all just me and other people will have different priorities.
cug is online now   Reply With Quote
Old 04-17-2011, 12:33 PM   #257
cug
Oddometer: 4,946
Maier Splash Guard
Is anybody using the Maier Splash Guard with Pilot Mounts? Does it fit?
Old 04-17-2011, 12:42 PM   #258
GB
Mod Squad
GB's Avatar
Oddometer: 56,754
You'd have to trim it a bit around the frame mounted brackets that hold the bullets.
Old 04-17-2011, 02:44 PM   #259
cug
Oddometer: 4,946
Just trimming? So it will fit with some TLC? Great. So I can order one.
Old 04-18-2011, 10:45 AM   #260
Ramv
Ramv's Avatar
Oddometer: 474
Very intriqued by these, any pictures on a Multistrada?
AJ
'10 Multistrada 1200 Std ('11 - current) for sale
http://advrider.com/forums/showthrea...2#post23383292
'07 Super Enduro 950
'96 KLX250R - kind of street legal
Ramv is offline   Reply With Quote
Old 04-18-2011, 12:55 PM   #261
Micatech OP
Motorcycle Luggage
Micatech's Avatar
Oddometer: 206
We easily modified a Maier Splash Guard for an R1200GS customer by trimming a couple of small areas with a utility knife. There is also a splash guard available from Machine Art Moto that fits with the Pilot Mounting System.
Micatech is offline   Reply With Quote
Old 04-18-2011, 02:07 PM   #262
cug
Oddometer: 4,946
Great. That'll do it for me. Just didn't want to spend $50 for throwing it away later ...
Old 04-18-2011, 04:16 PM   #263
Micatech OP
Motorcycle Luggage
Micatech's Avatar
Oddometer: 206
AJ
We've yet to put V2s on a Multistrada. However, we think it'll look pretty slick. Here's a quick photoshop mock up to get an idea. We did custom red doors to really make it pop. Note, we offer 3 standard colors (Black, Silver, and Vein). We'll do custom colors but because matching a color is a personal opinion, we request that the customer choose and order the custom powder. Contact us for more details.
Old 04-18-2011, 04:20 PM   #264
ghostryder
made it
ghostryder's Avatar
Oddometer: 5,900
Ok I may be missing something then, because when I tried to mount one its contact points were where the Micatech mounts were. Got any pics?
ghostryder is offline   Reply With Quote
Old 04-19-2011, 09:11 AM   #265
Ramv
Ramv's Avatar
Oddometer: 474
Very cool. I cross posted over to the Ducati forum as well. I like the look.
Old 04-19-2011, 12:43 PM   #266
Micatech OP
Motorcycle Luggage
Micatech's Avatar
Oddometer: 206
We asked our customer for photos and will post them where when we have some.
Old 04-19-2011, 12:44 PM   #267
Micatech OP
Motorcycle Luggage
Micatech's Avatar
Oddometer: 206
Thanks, we like the look too.
Old 04-19-2011, 12:46 PM   #268
Micatech OP
Motorcycle Luggage
Micatech's Avatar
Oddometer: 206
Kawasaki Versys
We've had a few emails lately about V2s on the Kawasaki Versys so we made another quick mock up of what it might look like. Enjoy.
Old 04-25-2011, 05:13 AM   #269
Micatech OP
Motorcycle Luggage
Micatech's Avatar
Oddometer: 206
You're right, the Pilot Mounts mate up with the Splash Guard mounts. It's not the pretties solution but it gets the job done.
We used a utility knife (although sharp scissors would work) to perform a little trimming. It was a very minor modification that took less than 30 minutes. With these modifications, there is no interference from the splash guard or the tie-downs. The rider says:
Initially, I was concerned about maybe not enough clearance at the bottom of the guard from the rear tire. However, this is not a problem. I road fairly hard on very twisty roads with no problems. Upon arriving back home I removed the rear wheel so I could drop the Final Drive and change the oil. As you can see from the pictures there was absolutely no contact between the tire and the splash guard. When I installed the splash guard I used a longer plastic tie to go over the side frame brackets. I'm very pleased as this will give me the protection that I wanted for my Ohlins.
Old 04-25-2011, 10:29 AM   #270
BobLoblaw
Comfortably Numb
BobLoblaw's Avatar
Oddometer: 1,507
Are the VPilots available for the 1150GS?
Ride till you can't - Marty Hill
BobLoblaw is offline   Reply With Quote
Times are GMT -7.   It's 11:07 AM.
