Old 05-30-2010, 08:03 AM   #16
motomikedh
motomikedh's Avatar
Oddometer: 228
Awesome job Rich !!! I can't wait to see those lights again in Moab lighting up the canyon walls. Everyone should have HID's. My XR is next on the list for the 35 watt upgrade. See ya soon !! Ha ha.
motomikedh is offline   Reply With Quote
Old 02-04-2011, 04:54 PM   #17
freedomtwoup
freedomtwoup
freedomtwoup's Avatar
Oddometer: 97
PIAA 510 HID converstion
Thank you Rich.
Received the kit from DDM
Any shots of the wiring connection?
Thanking you in anticipation.
David
freedomtwoup is offline   Reply With Quote
Old 02-04-2011, 05:08 PM   #18
RPMINC OP
Oddometer: 70
Hey Bud , shoot me an email and I can send ya what I got , must be that time of year again , my bike currently sits in a "heated haven" out in a trailer surrounded by 4' of snow , hopefully an early melt ,
RPMINC is offline   Reply With Quote
Old 02-05-2011, 12:33 AM   #19
Semper Fi
Runs with Scissors
Semper Fi's Avatar
Oddometer: 872
Excellent write up
2011 R1200 GS Adventure Smoke Grey Metallic Matt
2009 G450X White
IBA #35651
Semper Fi is offline   Reply With Quote
Old 02-05-2011, 12:05 PM   #20
sdpc2
Just another Rally Rat
sdpc2's Avatar
Oddometer: 1,143
what size 510's are these?
i have two different sizes, 4" on my GSPD and 6" on my GSA.
also, how have these been over the long term? Any issues?
TIA
'12 R1200GS Rallye Edition, '99 R1100GS,'77 R100S
I lower my passenger pegs for those riders that have gone before me
sdpc2 is offline   Reply With Quote
Old 02-05-2011, 01:35 PM   #21
Scottly
Oddometer: 128
Originally Posted by scooteraug02 View Post
Nice report.
Is this where you got them? http://www.ddmtuning.com/product.php?II=101
I got mine there. I converted my low-beam and both BMW factory GSA aux headlamps. They work great, no CANBUS problems. Total spent for all three = $105.
Scottly is offline   Reply With Quote
Old 02-15-2011, 01:50 AM   #22
1coolbanana
1coolbanana's Avatar
Oddometer: 1,448
Thanks for posting up, it inspired me to do both my PIAA 4" 510's, low and high beams on my GSA.
No Canbus issues.
I left the fogs as fogs with halogen (learnt that the hard way!)
This pic is taken in daylight (and raining a little) but gives you an idea.
Thats 220 watts of HID
As a bonus, it may fry most bugs before they hit me
1coolbanana is offline   Reply With Quote
Old 02-22-2011, 08:43 PM   #23
freedomtwoup
freedomtwoup
Oddometer: 97
No Canbus issues.
Converted my 510's but it was suggested to use only 35W 5K HID's. (DDM's)
They are a little yellow against the 55W LB HID, I read that heat might be a problem in the 4" 510's . . .
What say you?
Old 02-22-2011, 10:34 PM   #24
1coolbanana
Oddometer: 1,448
What say you?
55 watt HID does not produce any more heat than 55 watt halogen.
55 watt Super White halogen is what my PIAA 4" 510's long range spots came with originally.
I wont damage or make anything melt any more than the standard halogen.
I used 55W 4300k (natural sunlight) in all 4, HB, LB and the PIAA's.
Any higher in colour temp becomes blue'ish and reduces lumens and penetration.
Always go for max penetration
Old 02-23-2011, 04:08 AM   #25
NachoRoto
Meet you there. OK?
NachoRoto's Avatar
Oddometer: 5,731
What size bulbs do the 510's use? And how did the beam change once going to hid? When I did my stock lights, the beam is now higher. Did it do the same?
Screw this shit. I'll meet you there.....
NachoRoto is offline   Reply With Quote
Old 02-23-2011, 04:34 AM   #26
Dan Căta
Dan Căta's Avatar
Oddometer: 1,676
Does anyone know what the difference is betwen the 510's and the ff50 from Hella? I am considering in adding both fogs and driving lights with 4300K HID's inside and would like to make the best choice.
Dan.
Dan Căta is offline   Reply With Quote
Old 02-23-2011, 12:37 PM   #27
1coolbanana
Oddometer: 1,448
H3's in the 510's.
Cant say if its higher, I removed them to convert them and realigned when I replaced.
Old 12-30-2012, 02:03 AM   #28
tellec
Oddometer: 2
PIAA 510 HID retrofit on an R1200GS
I picked up a pair of PIAA 510s for my GS from my buddy Kbasa a couple of months ago, and while I was digging the additional lighting, they weren't as bright as I was hoping. Ho ho ho - I found a 35w HID kit from DDM Tuning under the tree this year! I'm just guessing, but I think Santa went with the 35w ballasts instead of the 55w to save space and reduce the amount of heat in the 510s' housings. Good call Santa, good call.
Following RPMINC's writeup, I upgraded my 510s this afternoon. Other than drilling out the back of the housings, the install kit was plug-n-play - nice:
I attached the ballasts to the underside of the oil cooler using 3M "Extreme" double-sided tape:
I wanted to use Dual Lock, but couldn't find any locally. If I have any problems with adhesion, I'll swap it out. The rest of the wiring tucked up nicely, and the PIAA wiring harness was already hooked up to my fuse block:
Hot damn, these things put out a huge amount of light. Here are the old halogens only (the close-up illumination is from LEDs installed on the handguards) - all pictures below were taken with a Canon S95 - f2 0.25s ISO400):
...and the new HIDs:
Everything on (LEDs + low + high + PIAA 510 halogens):
Everything on (LEDs + low + high + PIAA 510 HID):
The color temperature is a bit bluer than I was expecting - I was hoping the 5000K would be daylight-ish white, but they seem a bit colder than that. No biggie - I can deal!
More install pics:
http://fallingwithstyle.com/pics/GS_Lighting_Upgrade/
tellec is offline   Reply With Quote
Old 01-09-2013, 08:10 PM   #29
Plane Dr
Plane Dr's Avatar
Oddometer: 868
I have been considering doing the HID as well. I'm finding my piaa 510 s don't really contribute much. So I assume they are fogs. They have worked well at that the 2 or 3 times I've used them for that compared to LED spots.
Any idea if they will be less useful at that if converted?
I currently have the 35w HID low beam and 2 LEDs. I simply haven't got to the high as around town I find the standard bulbs nice for a "flash". That said the LEDs are great daytime visibility and with the low beam conversion flashing is not quite as important. It would be nice to expand the use of the PIAAs as fog isn't much of an issue in TX!
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline   Reply With Quote
Times are GMT -7.   It's 01:45 AM.
