Old 04-22-2012, 01:52 PM   #256
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,841
I think Motostrano sells the radial adapter plates. I know someone makes them because I've seen them on supermoto bikes. I'm 99% sure Magura sells some.
Bike is still looking good. At this rate it'll be ready by summer?
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 04-24-2012, 05:30 PM   #257
K2m
....58....
K2m's Avatar
Oddometer: 2,242
Originally Posted by Pete640 View Post
Just as a general info thing for those who are using FG to manufacture tanks and the like make sure you check the tech data sheet for the resin your using to see if it is resistant to the fuel/oil and ALSO the fuel/oil vapours. You'll find the vapours cause more problems than the liquid.
K2M - if your using VE as a barrier layer make sure you use a layer of tissue 1st with the vinyl and a neat layer second. Make sure the 1st cures properly - add a little DMA if you can to speed it up if your in a cold area.
Thank you Pete. We really appreciate your advice. You are the professional fiberglasser.
I was given something called "wax in styrene" to add at 2% is that the DMA you are talking about?
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 04-24-2012, 06:29 PM   #258
K2m
....58....
K2m's Avatar
Oddometer: 2,242
Man have I been busy. Trying to fit a later model g/box to my car. Car drivers are slack assholes I don't think this box ever got new oil. It was black inside, and some of the bearings were fucked. 4th rebuild. The bloody thing ways about 70kg's. Very hard on your own off the floor. Makes an oil change on an LC8 seem like a walk in the park.............................
Fuck I hate working on cars. I was nearly condemned to do this for life. As an apprentice I could not afford a car so I got a small bike for transport a 125 Yamaha (rubber pads on the tank) YS or something. Rode it to see a just realest movie "On any Sunday". The beginning of a life time obsession
If it lasts 2 years I'll be happy. It's not a good idea to buy a g/box on the Internet. Next time I'll look local and pull this rear cover off/or use these photos to blackmail this very popular dismantler to do the right thing by me or I will expose them through the forums, which is where they came recommended Mmmmmmmmmmm
At last ................back to the bike
Old 04-24-2012, 07:06 PM   #259
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,734
No Wax in styrene is just that - parafin wax diluted in styrene solution. Its added to styrene based resins to remove the "tackiness" when it cures. Eases sanding so you dont get clogging or used to finished layers that are not being coated by paint or flocote. Do not use this in epoxy resins....
In styrene based resins there is the gel time (time it takes till the resin turns to jelly) and the cure time (time taken to achieve curing) Cobalt octoate affects the gel time and DMA (Diamethylanaline) affects the cure time. Tech data sheets will advise % of both to give a gel time based on ambient temps for certain resins.
Epoxies have a different base resin and the hardener dictates gel/cure times. You dont get to adjust epoxies as easily as you do styrene based resins for variances in temp. You just get fast med and slow hardeners.
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 04-27-2012, 04:47 AM   #260
K2m
....58....
K2m's Avatar
Oddometer: 2,242
Thanks Pete I will have to learn more about the technical side of polly-resins. Those data sheets are a great asset.
So I took my time looking at the various options of mounting the oil tank. One tends to think of it resting on a steel mount. Such mounts are not necessary with carbon as its structural strength will support from a couple of mounts. So with a minimum of weight increase I used two of the existing rear fuel tank/exhaust/pillion peg mounts, and one frame mount up high.......... there are no frame mounts, and I did not want to start welding. So I made a wet carbon wrap against nylon/non stick.
First I made the mounts on the tank having determined their approximate position. I made them much bigger than necessary, then grind them down at the end before mounting.
Wrapping the tank in carbon will be done in one go, so the mounts will be chemically bonded "Strong" 8mm thick.
Old 04-27-2012, 04:50 AM   #261
K2m
....58....
K2m's Avatar
Oddometer: 2,242
Old 04-27-2012, 11:22 AM   #262
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
That is simply awsome K2M. Love your work. Your skills are really cool, keep it comming. Help me keep this thread alive. 8mm. That will be the last thing to deform in a frontal collision with a truck.
GO...
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is online now   Reply With Quote
Old 04-27-2012, 11:26 AM   #263
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
and that Sub Tranny, well to wild engine. VW passat 1994, just gone past 670.000km all original. 90hp...über machine. Way above us-made cars. ;-)
KTM 530 EXC-R 08
Old 04-28-2012, 04:35 AM   #264
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
Update:
Texted Søren yesterday if he had time to help me complete the right fork. And yes right away this morning 0830 he stepped in and helped a lot.
Scrap.
All this work made it possible to see if the radiator would fit. A bit nervous because it is way longer than the original.
First test looks great. The fit seems ok and some measurering where done and full compression with 21" should clear fine. Though we will do some more test a long the assembling. I still have a 2.5cm(1inch) i could move of the front exhaust so the radiator could come further back.
Begins to look like a bike. I´m thrilled.
KTM 530 EXC-R 08
Old 04-28-2012, 07:33 AM   #265
Katoom119
Katoom119's Avatar
Oddometer: 1,841
Man that's looking good!
Old 04-28-2012, 08:00 AM   #266
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,273
+1 pass the popcorn
Old 05-04-2012, 02:07 AM   #267
K2m
....58....
K2m's Avatar
Oddometer: 2,242
Originally Posted by Locul@hotmail.com View Post
That is simply awsome K2M. Love your work. Your skills are really cool, keep it comming. Help me keep this thread alive. 8mm. That will be the last thing to deform in a frontal collision with a truck.GO...
Thanks Mate.
That tranny was not designed for that motor so I accept it's shortcomings. This Outback tranny is stronger to match later more powerful motors so I will fit the 3Lt 6 cylinder motor next with turbo and start the breaking process again
Mounting the oil tank.
I welded tabs to the existing rear tank/exhaust mounts
The top mount was made by by wrapping wet carbon around the frame
I used a piece of nylon to keep them apart. This will allow the rubber grommet to have space.
This mount bolts onto the pillion peg mounts on the frame. I can attach pillion pegs if i need them.
Old 05-04-2012, 02:52 AM   #268
K2m
....58....
K2m's Avatar
Oddometer: 2,242
I got this idea on how to finish off the oil tank. I thought why not spray a little gloss clear from a can........... Carbon can be hard to finish. usually I wipe some wet epoxy on with my finger, but it does not give the best results.
From this :-
To this :-
I must say that I very happy with this result, and it's simplicity
While not being perfect it sure is easy
Old 05-18-2012, 04:42 AM   #269
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
Long time since last update. My work has taken all of my time.
Small but big steps have been taken.
Where i´m often seatet. The difficult right side.
Plate for...
Fuel pump.
We have WATER.
Søren has done some rewiring and now its a runner,
Project for some up comming nightrace.
Our helper.
Late night work. Drove home 02:15
Update will follow. Blinkers and front/rear light mounted and connected. Getting there...
KTM 530 EXC-R 08
Old 05-18-2012, 04:54 AM   #270
LukasM
Oddometer: 5,415
Looking good Mikael. I'd be concerned with vapor lock in that location, both from the proximity of the header as well as the hot air blowing in that direction. At the very least I'd go with some quality reflective foil and maybe ceramic coat the exhaust system inside and out.
Fuel pump.
Times are GMT -7.   It's 01:14 AM.
