Old 02-14-2011, 02:46 PM   #106
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,284
Yep and no.
If lucky i should be picking up the paintet stuff tomorrow. Then i can get to the enginemounting part. Suspension is giving the dealer gray hair. He is having hard time getting solved. WP which now is owned by KTM are really not helping him to release some info regarding our 300mm-wishing.
Regards
From once again cold and snowy Denmark...arghh
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 02-14-2011, 11:08 PM   #107
randel
randel's Avatar
Oddometer: 315
Maybe a stupid question, but why are you planning to increase suspension travel to 300mm? I can see benefits for serious offroad, but for mainly street and gravel riding with such ridiculous amount of horsepower isn't even less travel than stock and firmer suspension favorable? Like supermoto has?
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 02-15-2011, 02:48 AM   #108
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,284
Well i´ve always wished the extended legs. It´s an experiment, but since we haven´t had any solution I think i´m just going to service the standard suspension.
" ridiculous amount of horsepower "...their is not to much power, if just you can control it.
KTM 530 EXC-R 08
Old 02-17-2011, 04:16 PM   #109
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,284
A little progress on this slow going project. Got the stuff from the painter the other day. While this has been going on i have ordered some stuff i know i will be needing in a month or so. Bearings and such. If lucky i should be recceiving my upgraded suspension in a week or so. A coupæe of year ago i went with SPS front and standard rear. It fit me well, but i´m getting it serviced right now and asked for the 0.59 spring in he front. Rear should just need a service.
Some pics.
KTM 530 EXC-R 08
Old 02-27-2011, 04:27 PM   #110
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,284
Hep
I´m in the middle of upgrading the frontend(suspension).
I would like to use the 0.64 springs from KTMTWINS. But there is a notice about sanding the "hydraulic stop"? Would could someone explain or anyone done this?
http://www.ktmtwins.com/950adventure/spsf43485-50.html
"Note: .56,.58 and .64 springs may require you to shave or sand down your Hydraulic Stop in-order for these to fit."
Edit:
I get what the "stop" is. Should i just "grind" siding?
Its part 24.
Regards
Mikael
KTM 530 EXC-R 08
LocuL screwed with this post 02-27-2011 at 04:37 PM
Old 02-27-2011, 04:52 PM   #111
mookymoo
Mookish Mook
Oddometer: 4,392
Originally Posted by Locul@hotmail.com View Post
Hep
Edit:
Its part 24.
Regards
Mikael
Yeah, just use an angle grinder - or put it a lathe if you have one handy.
You just need to remove some of the material (its plastic) so the spring doesnt bind on it.
mookymoo is offline   Reply With Quote
Old 03-01-2011, 09:34 AM   #112
Tijuana_Taxi
Oddometer: 326
This video shows you what you are trying to accomplish
http://www.youtube.com/watch?v=uo5NSJI3M60
Tijuana_Taxi screwed with this post 03-01-2011 at 09:42 AM
Tijuana_Taxi is offline   Reply With Quote
Old 03-01-2011, 05:30 PM   #113
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
Nice video. I had my stops turned on the lathe and then the plastic fur from machining just sanded right off. Easy to do, even with out a lathe. If I had no lathe, I would use a heavy file on each rib of the damper stop to get the same results.
Good luck!
snowhawk jockey is offline   Reply With Quote
Old 03-01-2011, 09:47 PM   #114
K2m
....58....
K2m's Avatar
Oddometer: 2,242
It looks like you could just file the square edge of each rib to stop the springs from binding.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 03-12-2011, 04:47 PM   #115
K2m
....58....
K2m's Avatar
Oddometer: 2,242
Originally Posted by K2m View Post
I would to, It's good know for those who follow. I can see my self doing this one day.
I have been experimenting with aerodynamics on our cooling system with good results. I test my findings commuting in Sydney traffic as it is summer down here in the Antipodes. I use lack of fan switch on as a guide.
My ideas were to remove the clutter from the back to allow air to freely exit the radiator unhindered. The fan was moved to the front. Next was to capture air from as wide as possible a direct it into the radiator with home made carbon fiber shrouds. One side was finished 3 months ago and I have been very happy with the results so far. I don't have a photo of the shroud yet.
The results so far are a major improvement during low speed running, and that is with only one shroud.
Nice solution. Please post some more pictures.
OK while we all watch the unbelievable tragic developments in Japan, I though I might add some ideas for consideration.
In testing the air intake shrouds are proving to be well worth the effort. they help direct a large amount of air through the radiator. As a side bonus there is an large increase in cool/fresh air flowing into the carburetor area..... so much so that a additional filter cover that I add with my 2/up seat now continually blows off at speeds over 80 kmh.
The fan was moved to the front to open and unrestrict the rear of the radiator.
It is very important to keep hot (less dense) air away from the carbes and having thought about what materials to use I decided to go with rubber inner tube... 4 pieces with cable ties as it is cheep, quick, and effective.
FCR 41mm carbes (equivalent of 46mm C/V's aprox) would be perfect for this project
K2m screwed with this post 03-12-2011 at 07:36 PM
Old 03-13-2011, 09:04 PM   #116
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,320
Old 03-26-2011, 12:55 AM   #117
SorenSand
autodidact :-[
SorenSand's Avatar
Oddometer: 12
Come on Mikael...Lot's of stuff happening ind the work shop!
Share some pictures
Søren
SorenSand is offline   Reply With Quote
Old 03-26-2011, 02:42 AM   #118
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,284
This evening i´ll hve the time for sharing the cutting and assembling...
KTM 530 EXC-R 08
Old 03-26-2011, 06:12 AM   #119
LocuL OP
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,284
As promised i would make follow up on the project this day.
Weather, work and the newly started Danish Enduro Cup had taken a lot of my time.
My 530 Exc 08 needed some "time" to get ready. It had developed the "bad E-start syndrom". Thanks to KTMtalk.com and my friend Søren(onboard here), we got through it and it starts and hauls.
From this years first Enduro.
Bike...
Back on track.
My goal was to get the "bike" rolling with the chasis, engine, wheels. It will be a bit more easy to get to the welder. And i could test fit the tanks()
It all started with some cutting, grinding and 10x on/off engine mounting. I had the old "hillclimber" as a reference, but that was all. I´m ure it is pictured way back in the thread.
Sørens dog.
Grinding the engine...
To mount the engine as far back possible we had to cut some tubular framing. This will will hopefully make room for the stock 950 radiator with 2 x fans. It will come in again when we get it to the welder.
So far, so good...
I won´t get much done the next weeks and weekends as both work, enduro, training and daughter will take my time.
Ohh.. we did try to mount the tanks and was relieved how little needed to be done on the left side. But the right side will be tough. Søren talked about a company who could weld plastic. If thats true, it may not be the biggest effort.
And i found out the ECU from a RC8 would not work with the RC8R.
Regards
Mikael
PS:
Søren and his GasGas 300 which didn´t go to well at the Enduro opening(he had just bought it... ).
KTM 530 EXC-R 08
Old 03-26-2011, 03:36 PM   #120
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
K2M, Locul, you guys are inspirations! Keep tweaking, fun to watch and scheme...
viola-tor is offline   Reply With Quote
Times are GMT -7.   It's 07:15 AM.
