Old 05-31-2010, 04:55 PM   #1
ba_ OP
ba_'s Avatar
Oddometer: 2,836
Rear brake question - F800GS
What is this rubber part on the bottom left:
And more importantly, what is the proper way for me to put it back where it rightfully belongs? Do I need to take the pads off and insert it from the backside?
Thanks.
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
FS: DID Chain & front/rear JT sprockets WR250R
ba_ is online now   Reply With Quote
Old 06-02-2010, 09:43 PM   #2
Gumbeaux
The Chameleon
Gumbeaux's Avatar
Oddometer: 825
I think this is a dust cover of some sort that fits over the "pin"...which should still be attached to the rubber part on the bottom right of your picture. I have seen this pulled of an F650GS front brake before, and all efforts to re-insert it were fruitless...
Let me guess, you pulled on it to see what was underneath and it came right off...
Gumbeaux
Gumbeaux is offline   Reply With Quote
Old 06-03-2010, 03:35 AM   #3
ba_ OP
ba_'s Avatar
Oddometer: 2,836
More or less. I found instructions on how to put it back in. Will attempt it on Saturday
Old 06-03-2010, 04:15 AM   #4
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,429
Please share those instructions if they work for you.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 06-03-2010, 04:26 AM   #5
ba_ OP
ba_'s Avatar
Oddometer: 2,836
I actually found it in the Hall of Wisdom:
http://advwisdom.hogranch.com/Wisdom/BFDRear2.1.1.pdf
Check out pages 46-50
Old 06-03-2010, 07:51 AM   #6
Trout
Trout's Avatar
Oddometer: 341
I had one of these rubber boots fail on one of the front calipers. I'll see if I can get the dealership to warrantee replace it next time I'm in. I'm also going to see if I can get them to show me how to replace it - looks to be a pain in the ass.
Trout is offline   Reply With Quote
Old 06-06-2010, 12:47 PM   #7
ba_ OP
ba_'s Avatar
Oddometer: 2,836
On the rear brake it was actually really easy to put back on. After I removed the brake pads I could separate the caliper from the carrier, but the rubber gaitor back on, and then put everything back together.
Times are GMT -7.   It's 05:15 PM.
