Old 11-04-2004, 08:13 PM   #1
seh750 OP
seh750's Avatar
Oddometer: 964
Question Electrical strangeness - please help
I just installed a set of Dual-Star heated grips with a Heat-Troller variable controller. I have the exact same setup on my FJR and it works great there.
On the 950, I have it wired through the switched accessory lead (number 1, I believe). When the bike is turned on, but not running everything works great. The light blinks slowly when the Heat-Troller knob is turned to the left and blinks progressively faster as the knob is turned to the right. Seems to have an appropriate effect on heat.
When the bike is running, the Heat Troller seems to have three states: off, during the first 1/3 of rotation, hot during the second 1/3 of rotation, and blow the fuses when turned most of the way to the right.
The Heat Troller is powered and grounded with the accessory leads. The grips are wired in parallel with the white leads going to the white wire from the Heat Troller and the blue and red leads from the grips together going to the purple wire from the Heat Troller. This is the setup that is suggested on www.FJRTech.com and the same setup I used on my FJR where it works great.
Any suggestions?!?!?
Stephen
14 Yamaha Super Tenere
11 KTM SMT 990
07 Suzuki GSXR750
04 BMW R1150RT (Project, for sale)
seh750 is offline   Reply With Quote
Old 11-04-2004, 08:57 PM   #2
k7
Ancien cyclist
k7's Avatar
Oddometer: 19,340
I think the accessory wires are fused for only 5 watts. I know nothing about those grips but if you're blowing fuses, your electrical load is more than the fuse can handle. Either run different (larger) wire with larger fuses or get a multimeter and measure the resistance at different points. Share your findings and we'll go to the next step.
k7 is offline   Reply With Quote
Old 11-04-2004, 09:20 PM   #3
Stephen
Stephen's Avatar
Oddometer: 3,194
Originally Posted by k7lro
I think the accessory wires are fused for only 5 watts...
Five amps.
That's 60 watts at 12 volts, 70 at 14.
Does DualStar give a consumption figure for the grips? It's likely in watts, so we'll have to do the math.
Stephen is offline   Reply With Quote
Old 11-04-2004, 09:38 PM   #4
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,501
I can't imagine that the wiring to the accessory port, regardless of the fuse size, is heavy enough gauge for electric grips.
Run it right to the battery, with it's own dedicated fuse.
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 11-04-2004, 10:28 PM   #5
seh750 OP
seh750's Avatar
Oddometer: 964
Originally Posted by Stephen
Five amps.
Dual Star quotes the grips to use 36W...that's only 3 amps, so the wiring and fuse should be sufficient.
Even if the rating of the wiring and fuse were a little low for this application, that doesn't explain the change in behavior when the bike is running vs when it is not running...I've never encountered that before. I certainly could rewire it to the battery and use the accessory circuit to trigger a relay if people think that will help.
Stephen
11 KTM SMT 990
07 Suzuki GSXR750
Old 11-05-2004, 06:29 AM   #6
Reformed DucFlogger
Inventor Of The Wheel Mk2
Reformed DucFlogger's Avatar
Oddometer: 1,445
Fuses
The 5 amp connections under the 'glove box' ARE NOT dedicated connections to the battery.
If you look at your wiring diagram (drop me a PM with an email address and I can send you a color pick from repair manual), the connections are, shall we say, convoluted on the battery side of that fuse box.
Fuse 1 (switched) shares the same switched 12v as the headlight, unswitched with the clock and there is some debate as to what role the voltage regulator plays in these connections.
In short, it isn't just a clean switched straight run to the battery at either of those connections.
I run a heated vest of the unswitched circuit with a Aerostitch heat controller with no issues.
My guesses would be a combination of:
1. The 5amp rating for that connection is optimistic at best. Don't the DS's some with two watt ratings (high/low) and what amount of current does the heat troller draw? It's not a simple resistance-based controller right?
2. Something is coming on when the bike is started that either shares that connection that is causing issues with the heat troller.
3. The voltage regulator is somehow coming into play and fucking up your heat troller's little mind when the bike is running.
Options
1. Just run nice fat, heat- resistant cables to the battery via a relay controlled by that switched circuit.
2. Try connecting to the unswitched circuit - note: the ones on mine were mislabeled (#1 ws #2, etc).
3. Disconnect the heatroller and just go straight with a high/low switch and see if the same problem occurs.
Curious ...
"...who gives a rat fornication?"
Reformed DucFlogger is offline   Reply With Quote
Old 11-05-2004, 06:39 AM   #7
seh750 OP
seh750's Avatar
Oddometer: 964
I don't know how much current it draws although I certainly could test. No, it's not a simple resistance-based controller, I believe it's a essentially high-speed on-off switch...but that's based on memory, so don't quote me.
This seems to be the quickest way to salvation, so that's what I'll do. I have a second power outlet running straight to the battery already.
I tested the circuits so I'm positive which is switched and which is unswitched.
That'd be just as much work as running the whole shebang to the battery, so the battery it is.
Thanks for the suggestions everone!
Stephen
11 KTM SMT 990
07 Suzuki GSXR750
Old 11-05-2004, 06:53 AM   #8
Reformed DucFlogger
Oddometer: 1,445
Grips
I was just curious how it worked on the unswitched circuit - I guess would be the same as the switched with the bike off.
I thought as much on the heat troller, most manufacturers have moved away from the older resistance-based controllers.
I'd guess something in the power delivery when the bike is running is giving your heat troller circuitry fits.
It is an odd one though.
Old 11-05-2004, 06:58 AM   #9
FarmerRick
FarmerRick's Avatar
Oddometer: 1,307
According to my wiring diagram for my Dual-Stars, the Red wire is the Ground Wire for each grip while the White is for High and the Blue is for low setting. In an earlier post I thought you said you had the Blue and Red goint to the Purple on the Heat-troller? Seems to me you are gonna have a short somewhere with that setup.
I am using the regular High/Low Switch but if I were gonna use the Heat-troller, I'd use the White(High) wire to the Purple on the Troller and make sure the ground is set up correctly.
It is only a 3 amp draw, so... something in the wiring or the Heat-Troller is wrong. Having dealt with Heat-Troller on my Gerbing clothes, I'm VERY CONFIDENT that it is not their equipment (okay the odds are like 1 in 10000 that it is).
Is that the REAL Heat-Troller or the chinese knock off?
Rick
FarmerRick is offline   Reply With Quote
Old 11-05-2004, 06:18 PM   #10
wesfnw
portland,or
wesfnw's Avatar
Oddometer: 356
...but...if you wire them to the battery...what will happen
when you leave them ON overnight?
and you WILL leave them on...I know
wes
wesfnw is offline   Reply With Quote
Old 11-05-2004, 06:22 PM   #11
Shuffler
Hommes Grande
Shuffler's Avatar
Oddometer: 1,687
I just installed the Dual Stars a while back and went w/o the HeatTroller unit. I run the switched accessory plug, since I don't want my battery to run down in case I forget to flip the switch to 'off' when I park the bike. The Hi/Lo settings are great so far. No electrical problems or quirkiness to speak of.
________________________________
AMA | COHVCO | TPA | NCTR | BRC
KTM 950A | KTM 300XCW | BMW R1100RT
Shuffler is offline   Reply With Quote
Old 11-05-2004, 06:23 PM   #12
k7
Ancien cyclist
k7's Avatar
Oddometer: 19,340
Five amps.
Thanks for the correction... 5A is what I meant to say. Sorry.
Old 11-05-2004, 08:14 PM   #13
Greg Minor
The Trespasser
Greg Minor's Avatar
Oddometer: 2,322
Where can I get these?
THE ORANGE ONES ARE FASTER!
Have maximum fun while preserving bike and body
2004 KTM 950
2003 Ducati Multistrada
2001 Honda XR 400
1988 C&J Honda 625
1970 Honda SL 100 (green)
Greg Minor is offline   Reply With Quote
Old 11-05-2004, 10:54 PM   #14
seh750 OP
seh750's Avatar
Oddometer: 964
Yes, I know the blue/red combination is not what Heat Troller recommended but they actually list the FJRTech site as an example of directions and that setup does work. Once again, everything works fine when the bike's not running. And yes, it's a "real" Heat Troller.
Stephen
11 KTM SMT 990
07 Suzuki GSXR750
Old 11-05-2004, 10:55 PM   #15
seh750 OP
seh750's Avatar
Oddometer: 964
wes
That's why I'll install it with a relay...
Stephen
11 KTM SMT 990
07 Suzuki GSXR750
Times are GMT -7.   It's 03:25 AM.
