Old 06-02-2010, 02:40 PM   #1
Zecatfish OP
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
KTM LC4E 640... Side Stand??
Seems the Parts fiche shows side stand mounted with two allen head cap bolts.
BUT my 2000 LC4 Enduro uses one cap bolt and a recessed nut of some kind that is MIA. I talked to dealer and he said it was two bolts too.
I need to see if I'm missing something or what gives.
The rear bolt bolts to the frame, the front bolt hole appears to
line up with the stud on the center stand????
Can some one get me a picture of your side stand?
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 06-03-2010, 08:30 AM   #2
Zecatfish OP
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Seems that I got an odd ball.
Bike has both side and center stand, and KTM Cycle Hutt couldn't find a part number for the shouldered nut that is needed for the side stand.
I guess fro the lack of replies here no one has any ideas either.
Old 06-03-2010, 08:37 AM   #3
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,769
maybe you have an aftermarket side stand....
wrk2surf is offline   Reply With Quote
Old 06-03-2010, 08:48 AM   #4
jeiff
Oddometer: 249
Sounds like a SW-Motech sidestand. Check with twistedthrottle.com for parts.
jeiff is online now   Reply With Quote
Old 06-03-2010, 09:08 AM   #5
Zecatfish OP
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
From KTM LC4 Enduro
From KTM LC4 Enduro
From KTM LC4 Enduro
Here you can see the missing Nut, its actually very similar to the same one holding the gas tank down.
Thanks for the tips, I'll check with twisted throttle too.
KTM sure doesn't know anything about it.
Old 06-03-2010, 09:35 AM   #6
jeiff
Oddometer: 249
That's definitely a SW-Motech sidestand. Twisted Throtle sells them. The nut is notorious for loosening. I used blue Loctite on mine, and check for tightness occasionally. No problems yet. I believe some have resorted to drilling and safety wire.
Old 06-03-2010, 09:36 AM   #7
Zecatfish OP
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Just talked to twistedthrottle and thats what it is. Seems SW-Mototech makes OEM parts for KTM too.
Heres the link for future reference
http://www.twistedthrottle.com/trade/productview/329
Theres a pdf at the bottom of the page that lists all the misc pieces.
So anyone else that has this issue it can be found again.
Old 06-03-2010, 09:51 AM   #8
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,887
SW Motech I would assume. Only one I know of.
EDIT:
I see i was 205'd
Here is a pic of LuCy4's combo
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 06-03-2010, 11:10 AM   #9
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 839
Funny, 2000 Adv has factory weldet bracket for side stand, and both stands as stock...
Seikkailu_R is offline   Reply With Quote
Old 06-03-2010, 02:13 PM   #10
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,477
Just watch fitting that nut, overtighten it and snap, no more bolt to screw the nut on.......DAMHIK
The other bolt (screws into the frame) comes loose as well so i fitted a longer bolt & put a nyloc nut on the inside of the frame to lock it, I had no luck with loctite!
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 07-06-2013, 04:11 PM   #11
scottcolbath
scottcolbath's Avatar
Oddometer: 7,073
Time to revive this thread.
I broke both the bolt for the SW-Motech side stand, and the stud on my center stand.
Is there some easy fix for the center stand, such as drilling out the broken stud and using a nut/bolt?
S.C.
scottcolbath is offline   Reply With Quote
Old 07-06-2013, 10:25 PM   #12
bmwktmbill
Traveler
Oddometer: 5,147
S.C.
That's what I did,my kickstand also broke so it'swelded to the frame.
Ace hardware had a selection of nuts and bolts in Metric or American.
http://www.advrider.com/forums/showthread.php?t=888077
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 08-20-2013, 06:43 PM   #13
scottcolbath
Oddometer: 7,073
bill
Would you believe that I can't find a proper shouldered bolt to replace the broken shouldered/threaded pivot stud on the center stand? Nothing at Copper State Fasteners! Of all places, the nuts and bolts store has nothing. The local Ace has nothing. I'm going to check an Ace down in Phoenix next. The shoulder looks to be close to 10mm. How friggin' hard can it be to find a proper fit?
S.C.
Times are GMT -7.   It's 11:21 PM.
