Old 06-02-2010, 04:50 PM   #1
LaPorte OP
LaPorte's Avatar
Oddometer: 503
Hyperpro Fork Springs
I have ordered a set of Hyperpro fork springs for my F800 GS. So today I was looking to see what tools I need to change the springs. Looks like the front brake calipers have Torx bolts which will require female Torx sockets to remove them. Anyone know what size the female socket is, E-what ?
LaPorte
If you don't know where your going don't lead!
LaPorte screwed with this post 06-02-2010 at 05:26 PM
LaPorte is offline   Reply With Quote
Old 06-02-2010, 05:00 PM   #2
Pomo
gonzo
Pomo's Avatar
Oddometer: 611
Originally Posted by LaPorte
I have ordered a set of Hyperpro fork springs. So today I was looking to see what tools I need to change the springs. Looks like the front brake calipers have Torx bolts which will require female Torx sockets to remove them. Anyone know what size the female socket is, E-what ?
LaPorte
There are only 3 sizes used on the bike IIRC. E8 (shift lever bolt), E10 (handlebar clamps), and E12 (brake calipers). I may be wrong but if that's the case I'm sure I'll be corrected.
The ghetto fabulous way (which I have used a few times) is to just use an adjustable wrench on them. If you're careful you won't do too much damage to the bolts, but obviously that's not an ideal solution.
Stubborn and Stupid
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip
Pomo is offline   Reply With Quote
Old 06-02-2010, 09:50 PM   #3
gr8ridn
gr8ridn's Avatar
Oddometer: 413
Get the proper socket. The re-tightening torque for the calipers is CRITICAL. Too loose the bolts will loosen and fall off. Too tight will damage the mount threads and fastener. The Torque for the front caliper bolts is 38 NM (28 Ft/lb) dry and clean. You won't be able to do this with an adjustable wrench.
For something this important I suggest using the correct tools or have someone do this for you. You really don't want to cause problems with the brakes
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn is offline   Reply With Quote
Old 06-03-2010, 06:30 AM   #4
Nictrolis
Nictrolis's Avatar
Oddometer: 204
As an added help, check out this:
http://www.advrider.com/forums/showp...&postcount=265
Video walkthrough for taking the forks off. Though he's replacing the cartridges, you'll be doing basically the same thing.
Good luck, let us know how you like them!
Nictrolis is offline   Reply With Quote
Old 06-03-2010, 07:01 AM   #5
zaner32
In over my head
zaner32's Avatar
Oddometer: 652
LaPorte
Proper size torx is E-12.
Axle torque 30Nm
Axle pinch bolts torque 19Nm
2009 KTM 990 Adventure
Just ride!
zaner32 is offline   Reply With Quote
Old 06-03-2010, 07:57 AM   #6
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Yup.
Front Axle Bolt: 30Nm
Front Brake Caliper Bolts: 38Nm
Plastic Fork Guards/Fender Bolts: 4Nm
Top & Bottom Triple Tree Clamp Bolts: 19Nm
Fork Tube Covers: 20Nm
Damping Rod Locknut to Fork Tube Cover: 20Nm
No thread locker anywhere. Only clean and dry threads.
Old 06-03-2010, 08:03 AM   #7
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Also, get one of these babies for getting at the damping rod locknut:
Park Tool Cone Wrench. They're flat enough to fit in between the spring coils. You'll need 13mm:
http://www.biketiresdirect.com/pptcw...nch_set/pp.htm
Old 06-03-2010, 08:09 AM   #8
LaPorte OP
LaPorte's Avatar
Oddometer: 503
Thank you all for the information. I got the answer to my question ++++++++++++++++.
LaPorte
Old 06-03-2010, 08:40 AM   #9
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
That link I posted is for a cone wrench kit... oops. All you need is a single 13mm:
http://www.amazon.com/Park-Tool-PT-0.../dp/B001B6IQUI
Old 06-03-2010, 08:57 AM   #10
HMarc
Hoseur
HMarc's Avatar
Oddometer: 264
An 8mm socket works well on the E10 handlebar bolts.
But my solution (which I also did on my R12GS) was to replace the E-Torx bolts with Allen-head bolts. Well, the shifter and handlebar bolts anyway, for the brake calipers I used conventional bolts (17mm heads, in my case). That makes my tool roll smaller as I already need the Allen head sockets and the 17mm wrench.
HMarc
HMarc is offline   Reply With Quote
Old 06-03-2010, 09:33 AM   #11
tmex
tmex's Avatar
Oddometer: 2,039
LaPorte
While it is true that the front caliper bolts require a female torx socket to remove, you do not need to remove the calipers to change the fork springs.
BTW, you should stop being a cheap bastard and buy a whole set of torx sockets.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 06-03-2010, 02:46 PM   #12
LaPorte OP
LaPorte's Avatar
Oddometer: 503
tmex
Cheap bastard, cheap bastard how can you say that, I just wanted to borrow the E-12 socket for a few minutes. I was going to give it back just as soon as I was done with it. Hell if you want, you can borrow my Kragen 6", fully adjustable wench any time you want. I even have a piece of pipe to slip on the handle to get more leverage for those tight suckers.
LaPorte
Old 06-04-2010, 08:58 AM   #13
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,737
tmex
LaPorte
v8toilet is online now   Reply With Quote
Old 06-04-2010, 09:01 AM   #14
Nictrolis
Nictrolis's Avatar
Oddometer: 204
...Hell if you want, you can borrow my Kragen 6", fully adjustable wench any time you want. I even have a piece of pipe to slip on the handle to get more leverage for those tight suckers.
Fully adjustable wenches are surely the best!
Old 06-06-2010, 09:27 PM   #15
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,210
Hey LaPorte, I'd love to try out your 800 once you get the springs in to compare the difference. What weight springs did you get? (stockers are .44 I think)
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Times are GMT -7.   It's 11:35 AM.
