Old 06-07-2010, 09:13 PM   #16
utahrpm
utahrpm's Avatar
Oddometer: 141
So, what about the "new" KTM (I assume Brembo?) slave cylinder?
'04 KTM 950 Adventure "S"
'03 KTM 640 Adventure
'02 KTM 520 EXC (dual sported)
'07 KTM Super Duke 990
'04 Ducati ST4S ABS
'99 Ducati 900SS
'76 BMW R90S
'67 BMW R60/2 w. Ural sidecar
'79 Triumph Bonneville
'71 Triumph Bonneville
'64 HD FLH "Duo-Glide"
'38 Indian Chief long-term project
utahrpm is offline   Reply With Quote
Old 06-08-2010, 03:27 AM   #17
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,668
If u read back afew posts u will see that I toasted the upgraded KTM/magura unit . I'm not aware of a Brembo slave .
2015 BMW R1200RT 600 miles
2003 Harley XL883 CAFE
1stiski is offline   Reply With Quote
Old 06-17-2010, 10:41 AM   #18
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Originally Posted by 1stiski
One thing their site does say, is that they don't use O-rings, but it is a machined U groove seal. I also like that the piston is also sealed from the rest of the unit, this should cut down on the amount of crud in the system that leaks by on the OEM unit (the piston is non sealed from the rest of the unit.)
How does the Evo differ in design?
Originally Posted by kennyd
EVO has a 10 year warranty a spare set of seals included. oberon quoted over 50$ for their special seals both are available in orange now! soo 20$ advantage to EVO
I'm confused on this if the Oberon uses a u-groove seal.
What is there to replace "special seals" / wear-item wise on each design?
crazybrit is offline   Reply With Quote
Old 06-17-2010, 11:07 AM   #19
kennyd
kennyd
Oddometer: 231
evo non-special oring seals
evo uses simple std size o-ring seals and includes 1 free set with the the kit. oberon uses a u-groove or u-pack seal design not so simple and they charge much more and do not supply spares with their kit. evo 10 year warranty. oberon 1 year. orange or black available with evo now! some want the bling! www.alternatecycle.com
kennyd is offline   Reply With Quote
Old 06-17-2010, 11:14 AM   #20
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Ah, I read u-groove as meaning a seal-less design. I guess this isn't correct. Since I'm on the other side of the pond I'd rather not have to mail order seals from the UK, doubly so if they are $$$
Old 06-17-2010, 11:33 AM   #21
1stiski
1stiski's Avatar
Oddometer: 1,668
Can anyone post a pic of the EVO with the piston side showing, both the piston itself and the bore the piston goes into. I'm wondering if the EVO has a similar but better design than the OEM unit. The Oberon my have an upper hand in that catagory.
Old 06-17-2010, 11:47 AM   #22
kennyd
kennyd
Oddometer: 231
piston design
the evo uses 2 orings to support both ends of the longer than stock piston. the stock magura only has 1 oring and is shorter allowing it to cock in the bore .
Old 06-17-2010, 12:06 PM   #23
evoluzione
evoluzione's Avatar
Oddometer: 333
fwiw, we played around with a "u-groove" seal on our slave cylinders and could find no advantages. we did find the o-rings were more durable and much easier to assemble/disassemble (they do not tear like the u-groove ones do if you don't use the proper tools/technique). since ktm riders will go anywhere, there was the possibility of field repairs in the middle of nowhere and we felt the o-rings just made the most sense.
regards,
ken zeller
president - evoluzione cyclesports
www.evoluzione.net
evoluzione is offline   Reply With Quote
Old 06-17-2010, 12:45 PM   #24
AdvGa
AdvGa's Avatar
Oddometer: 1,320
My Evo Clutch Slave is working fine and a fine piece of workmanship. Even comes with its own Bleeder Unit which was a nice touch.
AdvGa is offline   Reply With Quote
Old 06-18-2010, 10:40 PM   #25
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Will the president of Oberon step up and tirelessly provide personal responses to rookie questions?
erappaport is offline   Reply With Quote
Old 06-19-2010, 04:36 AM   #26
HWSNBN
HWSNBN's Avatar
Oddometer: 2,895
So... I'm at year 4 and 30k on the stock slave. Works fine.
Trick is to drain out the stock mineral oil and replace with a synthetic such as fork oil or ATF. Sintered aluminum will chemically react with mineral oil and oxidize the cylinder bore of the slave when it gets hot. Its the bore's eventual enlargement that tends to cock the piston and lead to it breaking and leaking. Costs less than $10.. no bling factor though it does fix the problem.
HWSNBN is offline   Reply With Quote
Old 06-19-2010, 05:33 AM   #27
mookymoo
Mookish Mook
Oddometer: 4,396
What weight fork oil are you using/recommending?
mookymoo is offline   Reply With Quote
Old 06-19-2010, 06:18 AM   #28
HWSNBN
HWSNBN's Avatar
Oddometer: 2,895
I have 3wt. Maxima in mine, just because it was what was on the shelf. A buddy has Mobile 1 ATF in his, feels the same to me though its supposedly more like 7wt. I'm of the opinion that just about any thin synth hydraulic oil will suffice but your results may vary.
Old 06-20-2010, 01:54 AM   #29
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
So why do both Brembo and KTM spec mineral oil instead of selling us an expensive branded synthetic?
Old 06-23-2010, 12:25 PM   #30
BoulderGuy
out ridin'....
BoulderGuy's Avatar
Oddometer: 433
30K on my Evoluzione slave cylinder. Works like a charm. Comes with a bleed kit which is handy for brakes as well. I use 5W fork oil which works fine and is what was laying around. Oh, comes with spare O rings as well just in case...
BoulderGuy is offline   Reply With Quote
Times are GMT -7.   It's 02:23 AM.
