Old 06-03-2010, 02:39 PM   #1
Bill Harris OP
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,898
Daytime running lights on crash bars
I have a pair of 6"x2", 60-series amber LED turn signals that I want to use as DRLs. I plan to mount them on the crashbars and am looking into making a pair of clamp-on mounts for them, which shouldn't be that hard. The crash bar tubing is a tad less than 1" (24mm).
But if I can get something ready-made, I'll consider using 'em. The only thing I've seen are TrailTech "Anti-vibe" frame mounts, which are probably overkill.
http://trailtech.net/frame_mounts.html
Here is a cut-and-paste of how they should mount:
'73 R60/5 Toaster
Old 06-03-2010, 02:57 PM   #2
ruedaloca
just me
ruedaloca's Avatar
Oddometer: 446
Techmounts at Twistedthrottle ... other sizes too !.
They works !
Daniel.
R1200GS '07
Looking for a house or apartment at El Salvador ? your solution is here !!
ruedaloca is offline   Reply With Quote
Old 06-03-2010, 06:16 PM   #3
worwig
Oddometer: 1,247
I've had great luck with these from an auto parts store for light weight items like that.
Hog mountain Weather
worwig is offline   Reply With Quote
Old 06-04-2010, 06:26 AM   #4
Bill Harris OP
Oddometer: 7,898
Good ideas. If I need to go heavy-duty, my local hardware store has split shaft collars like the clamps that ruedaloca shows and also the rubber-covered clamps like worwig shows.
These LED lamps are light and I can probably use a light mounting system. What I envision is a couple of the rubber covered clamps holding a vertical plate with the lamp fastened onto the plate with 3M automotive trim tape.
Thanks, folks!
'73 R60/5 Toaster
Old 06-10-2010, 07:12 AM   #5
Bill Harris OP
Oddometer: 7,898
I made a pair of mounting brackets using the rubber-covered clamps and have all the bits and pieces collected to make up a wiring harness , which plan to do this evening. I'll post full pics when I'm done.
These 60-series oval amber turnsignal/brakelight/tail light assemblies that have two "power" wires-- one for full bightness and the other for reduced brighness for use as a tail light. Full brightness would be great as daytime running lights/conspicuity lights. But I have a concern that they might be too bright for nighttime use and might cause glare or distraction to oncoming traffic on a dark rural road. I could easily mount a toggle switch to select high/low brightness but will need to put the extra wire in the wiring harness.
What is your experience with the Whelan TIR/LIN lights used as daytime running lights or the Photon Blaster DRLs? Too bright at night?
'73 R60/5 Toaster
Bill Harris screwed with this post 01-21-2012 at 04:06 AM
Old 06-12-2010, 03:00 PM   #6
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,079
Boating stores sell stainless steel rubber covered clamps I have use to mount small lights to my crash bars.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 06-12-2010, 03:22 PM   #7
Megamoto
Yes, I do look like this.
Megamoto's Avatar
Oddometer: 2,997
Use mirror mounts.
I used them to fit a set of spots on the crash bars on my DR800.
Guerrilla Moto diplomacy.
Higher level simians as ambassadors of vroom to skewer ignorance and amalgamate ideas globally.
I'm so happy I could whistle through my willie. (Dan Walsh)
Unum bonum Centurio
Megamoto is offline   Reply With Quote
Old 06-21-2010, 09:28 PM   #8
Bill Harris OP
Oddometer: 7,898
All done. As I said, a set of rubber-covered clamps to a flat plate and the LED lamp body secured with 3M Weatherstrip adhesive. I have the /5 switch-board modified to have a headlight & bright DRL-only (no taillights) for daytime and another setting for headlight-taillight-night brightness marker lights. At night, the DRLs were almost obnoxiously bright and I was able to use a dim setting.
They provide a distinctive bright triangle pattern with the headlight in the daytime mode, and a distinctive pattern with the headlight and running lights in the nightime mode.
'73 R60/5 Toaster
Bill Harris screwed with this post 02-20-2011 at 07:56 PM
Times are GMT -7.   It's 08:27 PM.
