Old 06-06-2010, 05:00 PM   #1
kkug OP
kkug's Avatar
Oddometer: 966
Ohlins Shock--Who has one on their bike ?
I am just wondering how many are out in the field ?
What is your experience with them, the good -bad -ugly
________________________________
F800GS
KTM 450 MXC
"Never let the Situation affect you Emotionally. If you do it will have an adverse affect on your ability to make the correct decisions.
kkug is offline   Reply With Quote
Old 06-06-2010, 05:18 PM   #2
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I have one. I've had to tweak it a bit, but it works well.
The first spring was too stiff, it seems. Ohlins is still learning about this bike.
They have been more than fair w/ me.
johngil is offline   Reply With Quote
Old 06-06-2010, 05:37 PM   #3
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
If you get one, make sure and get the Ralle-Moto brace at minimum, if not Indy Unlimited's upper shock bolt bushing setup.
These aftermarket shock manufacturers are all using the same 3-piece design, which weakens the structural integrity of the upper shock mount on this bike. The mount system is designed for the stock shock, which is one solid piece and not three. If you get an aftermarket shock, this upper shock mount will most definitely need support.
http://www.advrider.com/forums/showthread.php?t=486251
Old 06-06-2010, 06:00 PM   #4
kkug OP
kkug's Avatar
Oddometer: 966
I got the Indy set up.Looks good . Yes my bolt was starting to bend. I think they have soft bolts in the bikes. I wounder if we will see a change from BMW in a few years ?
F800GS
KTM 450 MXC
Old 06-06-2010, 06:06 PM   #5
johnparjr
johnparjr's Avatar
Oddometer: 203
Ive had mine for about a month now all is good no bending bolts
johnparjr is offline   Reply With Quote
Old 06-06-2010, 06:47 PM   #6
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
The Indy fix will cost $100 for both the top and bottom.
The spacer/bushings Ohlins use are pretty prone to getting damaged by bent bolts.
If you have the funds, I'd consider contacting him. (Indy)
I know he was only making a limited amount, but you never know.
Old 06-06-2010, 07:52 PM   #7
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,452
Yes looks like I am making more kits so they will be available.
Just PM me for details. JohnparJr
above is also using my fix.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 06-06-2010, 08:42 PM   #8
johnparjr
johnparjr's Avatar
Oddometer: 203
Remember Indy I sent it back
Old 06-06-2010, 09:43 PM   #9
Indy Unlimited
Oddometer: 1,452
Sorry John out of the 60 kits I sent out worldwide you were the only one that sent it back because it was for a stock shock. I remember now. My bad. I need to know the shock brand to make the kit correctly.
Current Stable:
Old 06-07-2010, 12:58 AM   #10
-W-
Flying Finn
Oddometer: 193
Does anybody know much "internal" preload Öhlins has (or recomend to have) when the preload knob itself is set to mininum..?
-W- is offline   Reply With Quote
Old 06-07-2010, 01:10 AM   #11
johnparjr
johnparjr's Avatar
Oddometer: 203
I would suggest having it done by someone who knows what their doing. In my neck of the woods Im fortunate that I have Suspension Guru Dave Moss local so I had him adjust mine for me.
Old 06-07-2010, 01:11 AM   #12
johnparjr
johnparjr's Avatar
Oddometer: 203
No Problems Indy.
Old 06-07-2010, 01:32 AM   #13
-W-
Flying Finn
Oddometer: 193
Yes, but still I would like to know what Öhlins recommends/has as stock. I would like compare that to what original Sachs has (which seem to have a bit too much internal preload for linkless swing arm) and what KTM's Adventure & Superenduro has. Trying to learn new things myself you know...
-W- screwed with this post 06-07-2010 at 01:37 AM
Times are GMT -7.   It's 09:44 AM.
