Old 08-19-2011, 06:18 AM   #106
Platypus-3in1
Fluid Journey
Platypus-3in1's Avatar
Oddometer: 723
Originally Posted by Hodakaguy View Post
[B]
That looks like one of the Landing Zones in Halo ... You even have one of the ODST helmet's ... ... I cant tell if that guy on the wall looks like the Master Chief or a Hunter...
Platypus-3in1 is offline   Reply With Quote
Old 08-19-2011, 01:02 PM   #107
Mercenary
Mindless Savage
Mercenary's Avatar
Oddometer: 867
2008 DR 650
We can handle it....We're Canadian
Mercenary is offline   Reply With Quote
Old 04-07-2012, 08:12 AM   #108
Humunn
Moto Prozac
Humunn's Avatar
Oddometer: 952
GREAT RR. Just rediscovered it...again. Liked the vids so much I copied them to my FB account. AWESOME JOB!
High Desert Adventures
Backcountry Motorcycle Tours
www.highdesertadventures.net
2009 KTM 450 EXC The Citrus Mistress - 2004 KTM 250 EXC 2T plated Little Miss Britches - 2010 Yamaha FZ1 Legally Black
Humunn is offline   Reply With Quote
Old 04-08-2012, 05:48 AM   #109
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 1,722
Send a message via AIM to n16ht5 Send a message via Skype™ to n16ht5
Thumb
I remember this from pnwds... Awesome RR
n16ht5 is offline   Reply With Quote
Old 10-16-2012, 09:30 AM   #110
ABeaulieu
Oddometer: 6
This is an awesome report ! So inspiring ! But I wonder how you dealed with oil ? For a 530, KTM recommend 15h intervals .. And, what tires do you have ? I'm running on Kenda Trackmaster II, but they're melting so bad fast !
ABeaulieu is offline   Reply With Quote
Old 10-17-2012, 05:12 AM   #111
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 1,682
The 530 works perfectly for long distance desert travel. When around home I change oil at the recommended 10-15hrs. When on a long trip I usually push it out to 800-1000 miles between changes (engine side oinly, I change the trans side once I return home).. Often you are covering ground quickly in the open desert and the bike is plenty capable of going a couple changes past the recommended interval.
When on a trip I carry a full qt of oil in the Giant Loop bag and a 2oz Nalgene bottle (LINK HERE) full of oil in the tank bag for topping the bike off with each morning. The Nalgene bottle works perfectly for filling the bike and once low I just refill it with the bottle in the GL bag. Since the 530 only holds .6 qts on the engine side I can change oil half way through the trip and have plenty of oil left over for topping off with. Having the qt of oil is also handy if you end up getting water in the engine durning a failed stream crossing and need to change oil before continuing on.
Also when carrying the oil on the bike take a roll of electrical tape and tightly wrap the lid, it's a extra guarantee that it won't leak and keeps the lid tight and secure.
For tires I run Dunlop D606's while on long trips, along with Extra heavy duty tubes. They hook up remarkably well for a DOT legal tire and wear like iron, after a 1500 mile trip I'll still have 40-50% tread left. Another plus for the 606 is they have stiff side walls which helps prevent pinch flats while on the trail. The 606's are notorious for being out of balance, when balancing the tires it can help to play with the position of the tire on the rim to minimize the amount of weight needed. I use and love these removable wheel weights from a ADV member (CLICK HERE), having the wheels balanced makes a huge difference when you need to hop on the highway to connect the next trail.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy screwed with this post 10-17-2012 at 05:30 AM
Hodakaguy is offline   Reply With Quote
Old 10-18-2012, 04:59 PM   #112
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,425
just found this RR.
awesome!
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
Times are GMT -7.   It's 10:54 AM.
