Old 06-07-2010, 09:18 PM   #1
oclv454 OP
Oddometer: 291
Brake Pedal height adjustment
I found that when standing, the brake pedal is seems too low and hard to reach. I went to adjust it up and could not find an adjustment for this. Normally there are two nuts, one for height and one for actuation. Is this the way it is? Thanks. oclv
oclv454 is offline   Reply With Quote
Old 06-07-2010, 09:24 PM   #2
oclv454 OP
Oddometer: 291
I did a search through google and found my answer. Seems there is no adjustment. One post mentioned that Pivot Pegs made the brake pedal seem too high for this person. This might solve my issue (can't raise the pedal....then lower the pegs). oclv
Old 06-07-2010, 11:40 PM   #3
itsatdm
itsatdm's Avatar
Oddometer: 4,873
There is a way to raise the pedal. Take the cover off that covers the rear of the brake arm and you will see where the arm bends and rest against its stop. With a file or a grinding wheel remove enough material off the arm to get the pedal where you want it.
Adjust the rod going to the brake reservoir to get back your brake "feel" (lengthen it).
If you haven't cut your brake line in the process, you are good to go.
Have you pull the little peg rubbers off?
itsatdm is online now   Reply With Quote
Old 06-08-2010, 06:10 AM   #4
oclv454 OP
Oddometer: 291
Good call on the rubber tops to the foot pegs, I looked at grinding the back of the brake arm but figured it was too much of a project. Removing the rubber inserts is a good thought. Thanks. oclv
Old 06-08-2010, 06:15 AM   #5
raider
Big red dog
raider's Avatar
Oddometer: 1,582
The Wunderlich brake pedal is adjustable for length (by around 2" from memory), which might ease your problem a little (the further the tip is from your foot, the less ankle deflection needed to hook under it).
14 R1200GS Adventure
raider is offline   Reply With Quote
Old 06-08-2010, 07:14 AM   #6
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I didn't care for the brake pedal height either. The Fastway pegs in the lowboy position made it all better.
johngil is offline   Reply With Quote
Old 06-08-2010, 05:00 PM   #7
ecce
ecce's Avatar
Oddometer: 129
the bike is undrivable with the rubber stuff on the foot pegs.
Both break- and shift lever should work well in standing and seated possition with the rubber crap removed. Much better than many other bikes.
Not saying it wont work even better with pivot pegz or similar.
ecce is offline   Reply With Quote
Old 06-08-2010, 07:18 PM   #8
SCVGS
Oddometer: 72
I "drive" mine all the time with the rubber in the pegs
SCVGS is offline   Reply With Quote
Old 06-08-2010, 07:29 PM   #9
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,938
I took those rubbers out before I left the dealer.
I've since gone with Fastways.
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 06-08-2010, 11:37 PM   #10
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 268
I only drive nails, golf balls and the occasional car.
I removed my rubber peg inserts to get some more leg room. I have not been bothered by excess vibes without them.
I'm planning on installing pivot pegs in the future.
mapuda is offline   Reply With Quote
Old 06-09-2010, 01:44 PM   #11
Tor
Native Viking
Tor's Avatar
Oddometer: 803
I went ahead and adjusted the cylinder rod play, so at least the pedal don't go as deep before it brakes. I'll probably end up bolting something out of aluminum on top of the Pedal to make it higher.....
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 06-09-2010, 06:48 PM   #12
Ron Wardman
Beemerguy
Oddometer: 249
pedal
I would caution one an adjusting the push rod on the brake cylinder. If you do not have the correct free play, plan on having the rear brake lockup when drag overheats the disk. I know from experience. Adding height to the pedal with a custom piece is the better way to go.
Ron Wardman is offline   Reply With Quote
Old 06-10-2010, 04:43 AM   #13
Tor
Native Viking
Tor's Avatar
Oddometer: 803
+1. No or little blow-back clearence = look-up, or at least drag, so be careful if you do this.
Times are GMT -7.   It's 08:23 PM.
