06-08-2010, 12:49 PM
#1 |
Saratogian
Oddometer: 146
Help Troubleshooting a 640 Adventure that won't run
2000 KTM 640 ADV R w/ 24,000 miles
Current Status: Bike cranks, but will not fire (battery is strong) I started the bike on Sunday. It started no problem and was warming up for a couple minutes before dying all of the sudden. It sounded perfectly normal before dying very quickly (it was by itself in the driveway). I tried restarting it right away. It would fire a little bit, then die. It would then fire less, and die. It then woudl not fire at all and has not since (I've tried push/bump starting it, E-starting it, and kick-starting it about 30+ times total). I tried starting it with and without an air filter in place. Relevant Mods: Aftermarket carb installed by the previous owner (not sure of the brand off the top) Airbox is opened up (previous owner) LeoV can (previous owner) With these mods, the bike was running really great prior to this. Great power, off-throttle response, fuel mileage, etc. Always started right away...no issues. Other Impotant Info: Idle is around 1,800 RPM Gas tank is full. Bike generally starts without the use of the choke. A twist or two of the throttle prior to thumbing the starter is all it needs. I changed the air filter immediately prior to starting the bike and think this may be the problem/cause. The air filter had been cleaned, oiled, and placed in a plastic bag by the previous owner. It was super tacky and appeared ready to go. My theory is that the filter was too restrictive, causing an overly rich condition, causing the plug to foul.... My Plan: Remove the gas tank Check the spark plug If the plug looks good, make sure all the fuel lines going to the carb are good/clear. Then, if needed, I will attempt to see if the carb is somehow malfunctioning (note: I know very little about carbs, but intend to learn. I do maintenance, mods, suspension, etc....but not much real engine/carb work (my other bike is a FI'd Yami)). What I need from you: Thoughts/ideas related to what the issue might be and opinions on my "plan" thoughts/ideas on how I can get up the carb learning curve (I have the ability and will, just not the experience or mentor). Also, since I have to remove the tank to check the spark plug, I'm going to have to reassemble everything to see if that's the fix, right? Any tips on streamlining this testing phase and/or making sure the carb gets fuel again once the tank is reattached? Thanks
06-08-2010, 01:05 PM
#2 |
whats a cagiva
Oddometer: 2,454
Is the gas valve turned on . I dont think KTM uses the vacume valves like the jap bikes do but if so they are failure prone . Check and be sure there is gas to the carb . SEYA
David H 00 Cagiva GC 04 9 fiddy 05 ST3 duck 07 KTM 450 EXC 86 Goldwing my geezer ride |
06-08-2010, 01:27 PM
#3 |
Oddometer: 65
Mine won't start without the choke. Are you running too rich / have something broken in the carb? My money is on the carb.
06-08-2010, 04:02 PM
#4 | ||
Saratogian
Oddometer: 146
However, I have not determined if gas is getting to the carb but I know I need to. The fuel goes from the tank, to the fuel pump, to the carb and the hoses are not transparent...so what's the best practice for confirming the carb is getting fuel? Quote:
I really don't think the bike is running rich in general as fuel mileage is pretty good and the bike pulls very hard....seat of the pants feels to be twice as powerful as my 08 DR650. |
06-08-2010, 04:08 PM
#5 |
whats a cagiva
Oddometer: 2,454
Open the carb bowl drain screw and see if there is a steady flow of gas draining out .Also if it has an electric pump you should here it pumping when you turn on the switch . When draining the carb turn the key on and the pump should run . SEYA
06-08-2010, 04:52 PM
#6 |
Oddometer: 364
Engine Pulse line
I had a problem with the intake pulse line from the intake manifold to the fuel pump. The line had a crack in it at the intake manifold, the crack ran past the barbed nipple on the intake manifold. So the fuel pump was not pumping fuel, it had no engine pressure pulse to actuate the membrane in the fuel pump to move fuel through the one way check valve on its way to the carby.
Symptoms: Multiple cranking required on the e-start before I would get a weak start. Good luck. Mine is an 03 and I have never had any other problems other than wearing out rear tires at an alarming rate.
06-08-2010, 09:49 PM
#7 | |
Saratogian
Oddometer: 146
Just got home from work and did the following.
Looks like I have a fuel to the carb problem. That took about 2 minutes...getting closer...going back to the garage to investigate fuel supply issues. This carb shit ain't so hard Quote:
06-08-2010, 09:50 PM
#8 |
Ignostic
Oddometer: 13,839
Any luck with the troubleshooting threads littered about the 640 Index?
If you get nowhere, do you know about Scuderia West? I'll personally vouch for them; they are a good shop.
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
06-08-2010, 11:01 PM
#9 |
BITD/Rallye
Oddometer: 5,306
pull your fuel line off the carb and try to start it to see if your pump and fuel are working first.. then you know to pull the carb for a look see..
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
06-08-2010, 11:25 PM
#10 |
Custom User Title
Oddometer: 608
Did something find it's way into the idle circuit while idleing before it died? I've never tried it, but I wonder if it would start with the throttle held partially open, ie: on the main instead of the idle circuit.
"the previous owner explained that with the current carb, two twists of the throttle prior to thumbing the starter creates the temp. rich condition needed for a cold start." It sounds like your carb could be an FCR-41. Check out this thread... http://www.advrider.com/forums/showthread.php?t=43819 And then search from there. Good luck! Chad M screwed with this post 06-08-2010 at 11:41 PM |
06-08-2010, 11:51 PM
#11 | ||||
Saratogian
Oddometer: 146
Pulled the 17mm bowl plug...some fuel came out but that was about it.
The tank is now off but it appears that I need to continue my reading/education on carbs so I can figure out what the problem is. I want to know more before I start removing jets etc. and cleaning everything. In the meantime, I have a couple questions. (1) when the bowl cap is removed and the petcock is open, should fuel dump out? (2) when the overflow scew is open and the petcock is open, should fuel dump out? I have no fuel leaving the carb in both of the above situations. Does that tell me anything? Based on what we've learned today, what kind of things would cause the bike to stall all of the sudden like it did? Clogged pilot jet? Oh by the way, it's got the Keihin FCR on there.... Thanks again Quote:
Scuderia is a great shop...I buy parts/supplies from them every now. I lived half a block away for quite some time. Quote:
06-09-2010, 12:23 AM
#12 |
Traveler
Oddometer: 4,002
Reread what Works to surf said. First remove the fuel line at the petcock and open it, does gas run out, reconnect the fuel line and follow W's to Surf's instruction to check the function of the fuel pump to carb.
Does it run? Have you removed the fuel tank to make sure you have spark? If not do it. If you don't find spark tighten the cap on the wire, check the main fuse(near the battery) and tighten the contacts to each leg with a needle nose, next tighten the connections at each battery terminal. Try it again. Does it run? It better!!! bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
06-09-2010, 12:45 AM
#13 | |
Saratogian
Oddometer: 146
Seems like it's most likely that my float needle is gunked up and stuck. I'll be investigating.
I forgot to mention that after confirmed the spark plug was fine, I did the following:
Hmmm...so then I did this:
06-09-2010, 09:26 AM
#14 |
Traveler
Oddometer: 4,002
Defy,
You are close. The carb comes off and up through the frame rails with all the cables attached, unhook the fuel line and the airbox connection and anything else you dont like, clear the way, be gentle, it's a bitch, the bowl screws can be f'n tight so lock on with a vice grips, needle nose if necessary. Sounds like something's plugged, main jet idle jet, fuel screen in carb intake pipe(this screen I have not ever personally seen but they say it is there). Have fun, rag off the opening between the rails to catch small parts, I stick a piece of board across to make a work station, watch out for the idle fuel screw o-ring and spring, idle jet unscrews, main jet unscrews and is slotted for position. Bowl gasket is good for life. Easy on the carb cleaner, use air. bill
06-09-2010, 10:36 AM
#15 |
Vesperado !
Oddometer: 1,255
fuel pump aint pumping,check vac line
Laromo '91 Vespa PX 200E "Lusso" '05 KTM 640 ADV "Fatman" '99 HD FLHRCI "Leviathan" |
