Old 06-14-2010, 05:28 PM   #16
Dusty
Dusty's Avatar
Oddometer: 1,302
Originally Posted by yawningfungus
I've edited my profile, please dont beat me.
It really does help when we can see what bike-year and what country at least.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 06-14-2010, 10:44 PM   #17
Master
Oddometer: 338
Originally Posted by dad2bike
Hmmm. Never thought about doing this little mod to my 950. I see the wiring in my diagrams. Nothing to lose to give it a try.
Funny thing is I just had that plug in my hands 2 days ago when I did my Torque Limiter update.
Since the 950 has a more physical way to control power in 2nd and 3d, I would find it strange if doing this cutting the wires thing would work for it. What this mod does is just fooling the 990 ECU into thinking you're not in 2nd or 3d gear so it allows full power. If you do try it, please comment on the result!
Master is offline   Reply With Quote
Old 06-15-2010, 12:16 AM   #18
BartG
BartG's Avatar
Oddometer: 174
Fuel consumption??
The Akro map makes the fuel consumption even worse than standard no... so does this not have the same effect...?
BartG is offline   Reply With Quote
Old 06-15-2010, 12:38 AM   #19
mynameis
mynameis's Avatar
Oddometer: 212
From what i understand,on the 950`s if you have already removed the EPC stuff and plugged the carb tops then you dont need to do this.See the HOW.
Andy UK.
KTM 950SM
Suzuki DRZ400S
mynameis is offline   Reply With Quote
Old 06-15-2010, 01:05 AM   #20
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
I did mine while I was doing the Canisterectomy and the SAS removal. Definitely hits harder in second than it did before. But I can't say which mod did what, because I changed 3 things at once. Bike feels more lively when you open it up so who's to say. Can't hurt to try it. Just cut 2 wires. If you don't like it solder them back together.
2009 KTM 990
Honeymoon Ride Report
Crazy Europeans Tour Utah
Bronco3738 is offline   Reply With Quote
Old 06-15-2010, 01:25 AM   #21
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,177
I removed the secondary butterfly valves in the FI throttle body of my '07 990S, which is equivalent to cutting the wires on the 2nd-3rd gear sensor.
Couldn't find any noticeable difference in performance or power delivery.
2007 KTM Adv990S - Sold
2010 KTM530Exc-Rally and 2012 KTM Adv990
Vicks is online now   Reply With Quote
Old 06-15-2010, 02:29 AM   #22
Master
Oddometer: 338
I noticed no change in fuel consumption
I think removing the secondary butterfly valves affect more than doing the gear sensor mod. That being said, it seems to be a personal appreciation thing. Some people say thet don't feel any difference, other say their bike is much more alive in 2nd and 3d.
Maybe depends on driving style?
Old 06-15-2010, 02:32 AM   #23
motomal
motomal's Avatar
Oddometer: 175
The electronic part of the EPC triggers a solenoid on each carb to bleed the air through as I described earlier. If you haven't removed the EPC but want to try the mod out then the simple disconnect behind the panel is a good place to start.
For me, removing the SAS & EPC was a logical way to go as it adds nothing to the performance but does add complexity and therefore likelihood of failure to the bike. Much happier without the unnecessary junk!
2007 KTM 950 SM
motomal is offline   Reply With Quote
Old 06-15-2010, 04:40 AM   #24
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,147
Got it! Already have all that done. I won't mess with it.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC
My2Wheels
dad2bike is offline   Reply With Quote
Old 06-15-2010, 05:32 AM   #25
happy pilgrim
Oddometer: 4
I have a 59 plate 990 adventure and I had to remove the belly pan to get at the battery to fit some more accessories. whilst there I thought I would do the mod? cannot find the plug at all? is it still there on 59 plate 990 ? or am I missing it somehow?
happy pilgrim is offline   Reply With Quote
Old 06-15-2010, 06:23 AM   #26
kirb
should be out riding
kirb's Avatar
Oddometer: 1,839
This is a much better way to go about the noise issue than what Buell did on the 1125 bikes...they installed a solenoid that actually pulls the throttle back when WFO in 3rd gear for noise concerns. It's not real smooth, either.
The solution there is to install a resistor in place of the solenoid. The KTM mod is much easier, but a neat harness could be installed between the two connectors in place of cutting wires.
I would suspect 100% that it impacts US bikes too.
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is offline   Reply With Quote
Old 06-15-2010, 06:29 AM   #27
jamesbrown
Lefty tighty.
jamesbrown's Avatar
Oddometer: 6,413
Yes, that is correct.
If you haven't done the SAS/EPC, there's a couple of relevant posts about disabling the 2nd/3rd gear sensor on the H.O.W.:
http://www.ktm950.info/how/wotf/wotf...icPowerControl
jamesbrown is offline   Reply With Quote
Old 06-15-2010, 07:09 AM   #28
Master
Oddometer: 338
It should be there... are you looking in the right place? Best way to find the connector is to start off from the gear sensor (located right at the base of the sidestand) and then follow the wire until you find the connector. The connector should be right in front of the engine case.
Old 06-15-2010, 07:11 AM   #29
happy pilgrim
Oddometer: 4
thanks, will have another look tonight. buggered if I could see it this morning though?
Old 06-15-2010, 07:57 AM   #30
9nine0
Formally NineFive0 V2
9nine0's Avatar
Oddometer: 402
The 2nd and 3rd gear limiter ONLY affects the very last % of throttle opening in 2nd and 3rd gear. It WILL NOT affect any performance "off idle or midrange" it will not make it feel "more lively or peppy" unless you are at 100% wide open throttle.
basically, before the mod your throttle opened 97% of maximum and after the mod it now opens 100% (yes the difference is about that small)
hope this helps,
cheers
2010 990 Adventure
9nine0 is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
