Old 06-15-2010, 08:41 AM   #31
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,402
The connector on a 950 is located, along with the sidestand connector, just in front of the generator housing on the left side. It is tucked behind the front aluminum motor mount.
I'll bet the 990 is the same location.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC
To Think is to Create!
My2Wheels
dad2bike is offline   Reply With Quote
Old 06-15-2010, 09:15 AM   #32
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,066
Hmmmm, should I??? I just got it all back together... Can I access it just by pulling the bash plate?
It never ends (and I think that's a good thing ).
viola-tor is offline   Reply With Quote
Old 06-15-2010, 10:06 AM   #33
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,402
I have a TT plate. I can reach it right there.
Tom
My2Wheels
Old 06-15-2010, 11:15 AM   #34
Master
Oddometer: 270
jup, 990 is in the same location
If you have long and lean fingers, you can even reach it without pulling the bashplate, but if you lower it you won't have any problem getting to the connector.
Master is offline   Reply With Quote
Old 06-15-2010, 01:17 PM   #35
happy pilgrim
Oddometer: 3
Send a message via ICQ to happy pilgrim
found it at last. well pushed in behind other cables and generator?
now disconnected two cables and took it for a run after mod. seemed far more lively to me? pschological or not? but either way seems worth it
happy pilgrim is offline   Reply With Quote
Old 06-15-2010, 04:37 PM   #36
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 466
maybe your like me and you check for livelyness and the throttle stop too!
2009 KTM 990
Honeymoon Ride Report
Crazy Europeans Tour Utah
Bronco3738 is offline   Reply With Quote
Old 06-15-2010, 10:06 PM   #37
Rellik
o-KAY!
Rellik's Avatar
Oddometer: 584
The wire colors were different on mine, but I got it done. I don't know if 20% more power is true, but there is a significant difference. The neutral switch on my '07 990 was pale green.
No problem, that'll buff right out!
Rellik is offline   Reply With Quote
Old 06-18-2010, 01:51 PM   #38
udhawg
udhawg's Avatar
Oddometer: 182
+1 on the wires on my 07 990 S. I still have the stock cans and the hesitation seems to be almost gone, plus its a bit crisper on the throttle.
2007 990 Adventure S
(KTM) Kronreif, Trunkenpolz, Mattighofen
2007 Yamaha WR250F
udhawg is offline   Reply With Quote
Old 06-18-2010, 02:19 PM   #39
orangewarrior
Oddometer: 25
i ve done it, works a treat. on the ADV990 the plug is above the rectifier on the left hand side of engine. pain in ass to undo, so i just snipped the wires halfway between the plug and switch. try it. better all round, and two up !!!!
orangewarrior is offline   Reply With Quote
Old 06-18-2010, 08:27 PM   #40
boat.man OP
Chief bottle washer
boat.man's Avatar
Oddometer: 112
I just got back from a nice 70 miles off road and i have to say that the snatchy throttle in 2nd and 3rd is almost gone I cant believe how much smoother it is on and off throttle now! Me so happy
When I read about the evils of drinking, I gave up reading.
07 KTM 990 Adventure
06 TE610 Sold
2 sleds
lets go play!!
boat.man is offline   Reply With Quote
Old 06-18-2010, 09:52 PM   #41
spazlam520
spazlam520's Avatar
Oddometer: 5
im lost here
so i have and 07 990 adv and i think i found the wiring harness but the wires in it are blue pink and black.....is that it? i dont want to cut something wrong and all of the sudden gravity is reversed.....so is that the right harness? could someone post a pic of an 07 adv's harness location or something like that?
spazlam520 is offline   Reply With Quote
Old 06-18-2010, 11:34 PM   #42
Master
Oddometer: 270
Hmm, don't know if you have the right one.
It should be a black connector that runs together with another cable with a white connector.
I have yellow-brown, gray and green-black at the engine side and pale green, yellow-green and blue-red at the gear sensor side.
Mine is not an '07, so maybe one of the guys with '07s can check for you...
Old 06-19-2010, 07:18 AM   #43
boat.man OP
Chief bottle washer
boat.man's Avatar
Oddometer: 112
I hope this helps.
06 TE610 Sold
2 sleds
lets go play!!
Old 06-19-2010, 08:32 AM   #44
spazlam520
spazlam520's Avatar
Oddometer: 5
i did it!
http://www.facebook.com/album.php?ai...7&id=730051927http://www.facebook.com/photo.php?pi...d=438606616927http://www.facebook.com/photo.php?pi...d=438606631927i hope these pics work....im new to all this posting stuff....but this is my 07 adv so anybody else having trouble finding the cable here it is!
Old 06-19-2010, 09:12 AM   #45
Master
Oddometer: 270
I would not've hacked into the cable like that, but maybe I'm just over sensitive
Once again: it is really easy to just push the end plates of the wires out of the connector with a small screwdriver. You don't have to touch any of the wire insulation and it is very easy to undo the mod if you have trouble with it (don't know what cutting into the wires does with your warranty).
Times are GMT -7.   It's 05:41 AM.
