Old 06-13-2010, 07:42 PM   #1
riceless OP
Let's Ride!
riceless's Avatar
Oddometer: 3,267
Cry Blown Head or Base Gasket
I think one of those gaskets is gone. I have investigated yet but I had an oil leak, then I saw some coolant mixed in too.
My question is, will the cylinder come off with the motor in the frame? It looks like the head will... I hope. From what I can see, the leak seems to be up high.
At first I thought it was coming from the Oil Pressure Sensor.
But that wasn't it.
riceless is offline   Reply With Quote
Old 06-13-2010, 08:30 PM   #2
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,747
Try this:
http://www.advrider.com/forums/showthread.php?t=433598
I don't envy you.
unaweep is online now   Reply With Quote
Old 06-13-2010, 09:29 PM   #3
dabracing
dabracing's Avatar
Oddometer: 459
Front...yes, rear...no.
dabracing is offline   Reply With Quote
Old 06-13-2010, 10:08 PM   #4
Dale950
Dale950's Avatar
Oddometer: 986
You certain it's not the Oil Switch as Ive just done mine and it made a huge mess just likes yours the oil spewed up higher and down the opp side as well
Dale950 is offline   Reply With Quote
Old 06-13-2010, 10:12 PM   #5
imgonnasnap
Motard wrecker
imgonnasnap's Avatar
Oddometer: 808
Sucky. Good luck repairing it. Talk to mike (gearheart) about motor work on the 950.
Originally Posted by HappyGoLucky
lots of guys make excuses - it must be the tyres, it must be the weight, it must be the power, it must be the water pump.
ride the $*#(@) thing, and you'll quickly learn that the stain marks in your brooks were firstly from fear and then from ecstacy.
Scuderia: LB to SF
Bradshaw Bombrun 2007, 2008, 2009
Stupidly long road trip of 2009
imgonnasnap is offline   Reply With Quote
Old 06-13-2010, 10:32 PM   #6
TrentW
MMmmmm....
TrentW's Avatar
Oddometer: 87
+1
I've also seen a mess similar to yours and it was the Oil Pressure sensor leaking.
Clean it all up and check the Oil Pressure sensor again...
TrentW is offline   Reply With Quote
Old 06-14-2010, 12:34 AM   #7
DirtyADV
DirtyADV's Avatar
Oddometer: 2,372
Just hope its a simple gasket and not the "pyndon syndrome": http://www.advrider.com/forums/showp...postcount=1161
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 06-14-2010, 07:21 PM   #8
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
Hey man, on the first picture it looks like its coming from one of the coolant hoses/clamps looks wet up top.
I'd be checking everything up there,(one of my clamps was starting losen up and seep slowly at 35k) if nothing found guilty, remove cams and retorque head bolts, give her a nice wash, reasemble and go for another bashing to verify leak.
Better to get more evidence before you drop the motor
....unless of course you've done all that already
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 06-16-2010, 07:10 PM   #9
riceless OP
Let's Ride!
riceless's Avatar
Oddometer: 3,267
Thanks for all the ideas guys.
This weekend I'm gonna investigate further (again).
I'm hopeful about the oil sensor being the cause. Picked up a new washer today.
Second choice would be the hoses.
Next, the gasket and last, the nightmare would be the "Pydon Syndrome". My mileage is 66,000, about the same as his was when it happened.
I'll let you know what I find out. Thanks again.
Old 06-16-2010, 08:11 PM   #10
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,010
yeah....yeah....at least yours still has a charge in the battery....
Ok...buy a couple 12 packs....2 large meatlover pizzas...crank up some of those tunes of yours and I will come over and help you load that beast into your truck...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is online now   Reply With Quote
Old 06-16-2010, 08:31 PM   #11
Desertdweller
Desertdweller's Avatar
Oddometer: 79
Might be the rubber seal on the starter where it attaches to the motor.
Desertdweller is offline   Reply With Quote
Old 06-16-2010, 08:45 PM   #12
Desertdweller
Oddometer: 79
The front cylinder can be pulled off by taking out two of the motor mount bolts, and allowing the engine to adjust downward (hang) under its own weight until the cylinder clears the frame.
I haven't done it myself (yet), but that's how the chief mechanic at Malcolm's told me it could be done. Sounds a lot easier than separating the motor from the frame.
Old 06-17-2010, 01:06 AM   #13
Dale950
Dale950's Avatar
Oddometer: 986
If it is the oil switch , it most likely be the switch it self Riceless not the washer , you will be able to blow air through the unit as the ceramic material will be cracked . I found you need a long socket too to take it out .
Old 06-17-2010, 06:28 AM   #14
9nine0
Formally NineFive0 V2
9nine0's Avatar
Oddometer: 402
I can understand how this is easier and less hassle but you have already done 95% of the work to pull the complete engine. With the engine out of the frame, it is SO much easier to work on everything, clean everything and inspect other areas to make sure that they are fine. Now you can lube, grease and check over the complete engine and chassis.
2010 990 Adventure
9nine0 is offline   Reply With Quote
Old 06-17-2010, 04:48 PM   #15
riceless OP
Let's Ride!
riceless's Avatar
Oddometer: 3,267
The answer to this one is easy. Because I prefer riding to wrenching. Riding is a sickness for me...an addiction...a gotta have it kind of thing.
As evidence of this, If the leak is the switch itself (as suggested by Dale950 thanks Dale) and I don't have a new one to put back in, I'm screwin' in a bolt and goin' for a ride.
Oh and thanks also to Desertdweller for the starter seal and pivoting the motor ideas. I'll check the starter for sure.
riceless screwed with this post 06-17-2010 at 04:53 PM
Times are GMT -7.   It's 11:29 AM.
