06-14-2010, 07:02 PM
#1 |
regret minimizer
Oddometer: 641
Airhead rear main seal install: oil or no oil?
As I understand it, Part No. 11 11 1 261 739 is an upgraded rear main seal design. It looks remarkably different than the original spring-actuated lip seal. I've read it has a teflon sealing surface and therefore should be installed dry. This is consistent with my experience on Cummins 12V diesel engines that use teflon main seals front and rear. I've also read that the BMW seal should first be soaked in hot oil before installation. What's been your experience? Thanks.
06-14-2010, 07:15 PM
#2 |
the thread-killer
Oddometer: 4,297
I've installed that teflon seal 10 times in as many years. I've never had one leak. I put mine in dry and dry. no soaking, no wetting.
06-14-2010, 07:46 PM
#3 |
Coyote's Brother
Oddometer: 3,299
Dry.
Hawkdude Hate rots the pocket that carries it. |
06-14-2010, 08:05 PM
#4 |
Finding My Way..
Oddometer: 7,506
Matt Parkhouse did mine for me for while I watched (in my basement). He massaged it a bit (not sure why) and stuck it in there. Dry.
T. |
06-14-2010, 08:14 PM
#5 |
Oddometer: 1,483
The "massaging" is to shape the lip. This prevents the lip from tearing as the flywheel goes on.
06-14-2010, 09:11 PM
#6 |
Beemerguru...G/S guy
Oddometer: 640
Easiest way is to install the seal on the "guide ring" for a couple hours. That lets the seal naturally conform to the shape when you install everything.
Also make REAL sure the seal goes in dry and straight (use a round disc with holes for the flywheel bolts) as a pusher. If you see some shavings on the side of the disk when you finish pushing it in flush, you increase the likely hood of a later leak.
Greg Hutchinson BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club http://gregsgssite.shutterfly.com/ ![]() |
06-15-2010, 03:51 AM
#7 |
regret minimizer
Oddometer: 641
Dry it is. Thanks all for the help. Much appreciated. Beemerguru: I borrowed an installation tool like the one you describe. Seal went in clean and straight.
06-15-2010, 04:25 AM
#8 |
Wisconsin Airhead
Oddometer: 3,451
Mostly good advice. The new seals are something like the 4th generation and do not need oil or forming. Put them in dry, square and to the right depth and you are in business.
JT www.northwoodsairheads.com www.jefftrappwindsors.com "Between two explanations, choose the clearest; between two forms, the most elementary; between two expressions, the shortest." Between two motorcycles the simplest (DW) Eugeni d' Ors (1881-1954); Spanish writer. |
06-15-2010, 05:23 AM
#9 |
Scope Creep's Victim
Oddometer: 2,289
I did it dry. No leaks, no errors, and I have about 2K miles since the service.
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
06-15-2010, 05:42 AM
#10 | |
Oddometer: 304
06-15-2010, 07:27 AM
#11 | |
the thread-killer
Oddometer: 4,297
When BMW changes part numbers (which happens a lot) it doesn't always mean the part itself has changed. this the tool that I have been using. a pieces of nylon that I spun up in the lathe. That and a hammer and it's a snapperoo! Robert wirewrkr screwed with this post 12-03-2010 at 10:17 PM |
06-15-2010, 11:11 AM
#12 |
Oddometer: 430
so what happens if it goes in wet
06-15-2010, 06:47 PM
#13 | |
the thread-killer
Oddometer: 4,297
I don't care to tempt fate when it comes down to having to do a job twice. Whatever you want to do, do it. |
06-16-2010, 06:50 AM
#14 | |
Wisconsin Airhead
Oddometer: 3,451
06-16-2010, 06:57 AM
#15 |
Along for the ride
Oddometer: 914
Not knowing any better at the time I put mine in wet. Seal is working fine with 2500 miles so far.
__________________________________________ "There's a fine line between a skinning and a shearing" |
