Old 06-17-2010, 01:08 PM   #1
ShaunJ OP
Oddometer: 54
F800GS Losing oil
Hi
I was talking to a guy at a bike meet who told me that his bike had been losing/using oil and that the most he had to top it up by was 1.5L his bike had only done about 6k. So i checked mine this afternoon and found mine had lost about 500ml in 1800 miles since i did the oil change, i know the rocker gasket is seeping oil but not enough to make a noticeable difference.
Is anyone elses f8 losing oil?
ShaunJ is offline   Reply With Quote
Old 06-17-2010, 01:36 PM   #2
blender
Just another rider
Oddometer: 726
Not mine, however I have only 7,700 miles on it so far.
Every time I've checked the oil level it was spot-on. That's made me a bit complacent and I haven't been checking it as regularly as I should.
Steve
Madison, WI
blender is offline   Reply With Quote
Old 06-17-2010, 02:07 PM   #3
itsforrest
Ugly bag of mostly water
itsforrest's Avatar
Oddometer: 330
I haven't noticed any oil loss on mine, but it only has a few thousand miles on it so far.
Not saying you're mistaken by any means but...
When checking the oil make sure you check it the same every time. I.E. fully warmed up, on center stand and right after shutting it off. If you don't warm it up fully one time, wait a few minutes after shutting it off or even put the dip stick in crooked when you check, the level showing on the dip stick could be significantly different and lead to unnecessary worry. When the oil level goes UP between checks, you'll know this is more than likely the problem.
The urge to buy terrorizes.
itsforrest is offline   Reply With Quote
Old 06-17-2010, 02:40 PM   #4
reinerka
Oddometer: 350
I'm having 17K miles on mine and no oil usage whatsoever.
Make sure you follow the procedure/instructions in the book. If the bike wasn't fully warmed up the oil won't make it back 'home' and you get a low reading. Not having it level will give false readings as well (low or high - depending on which side it leans towards).
Reiner
'09 R1200GSA
'09 F800GS
'05 KLR650
reinerka is offline   Reply With Quote
Old 06-17-2010, 10:16 PM   #5
SenorPeligro
Proper Naughty
SenorPeligro's Avatar
Oddometer: 1,962
My 2005 F650GS barely ever used a drop of oil. It looks my F800GS is the same way. These Rotax engines are precision machines.
My XR650L will use oil when it's pushed hard.
If the bike is still under warranty, I suggest talking to your dealer about it. Typically they will ask you to measure oil consumption over a fixed period of miles, like 1000 miles. There's a threshold of acceptable oil use for every bike.
It's just good clean dirt.
Video Antics
Where am I Riding?
Baja Blitz Yard Sale
SenorPeligro is offline   Reply With Quote
Old 06-18-2010, 02:38 PM   #6
reinerka
Oddometer: 350
Pretty much every manufacturer is saying a quart of oil per 1000 miles is "normal". To use that much oil is a sure sign that the engine is "on its last legs".
Reiner
'09 R1200GSA
'09 F800GS
'05 KLR650
Old 06-18-2010, 06:58 PM   #7
Pete O Static
Adventure Seeker
Pete O Static's Avatar
Oddometer: 568
I hate to ask the obvious but are you checking the oil level when the engine is hot as it states in the manual?
If you are checking a cold engine, then yes, you will add oil and it will get pissed out the breather when the engine warms up.
I have found that mine doesn't use a drop. I have never had to add oil between changes. I hope it is something this simple for you.
Cheers
Pete O Static is offline   Reply With Quote
Old 06-21-2010, 05:17 AM   #8
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,467
Not a drop.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 06-21-2010, 05:50 AM   #9
Tor
Native Viking
Tor's Avatar
Oddometer: 803
No oil usage on my 800.
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 06-21-2010, 08:34 AM   #10
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,683
Oil usage
Reminds me of the oil usage on the 1150GS. Guys would fill it right to the top of the sight glass and it would get "used" up till it was at about the halfway mark. If you did nothing it would stay there. If you added oil it would "burn" it.
Mine 800 hasn't changed level in the last 4000kms. Reads at the min mark if it isn't warmed up.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 06-21-2010, 12:34 PM   #11
ShaunJ OP
Oddometer: 54
Did a mad 300mile run around wales on sunday and it didn't lose a drop makes me wonder how accurate the 2.9l stated in the manual is.
Old 06-21-2010, 10:47 PM   #12
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,735
Never seen a drop leak... cept from my forks!!! I'm going to give those techs at my dealer an earful if they can't stem the flow from my forks, they have worked on them a few times now, aftermarket springs and oil.
EnderTheX is offline   Reply With Quote
Times are GMT -7.   It's 01:32 AM.
