Old 05-01-2013, 03:33 PM   #1681
wilso122
Oddometer: 184
Originally Posted by ststrider View Post
not sure what you mean,i turn the ignition on everything lights up starter turns but once it ran out of fuel(it started and idled with the fuel in the bowls) it was done.you thinking ignition switch?
Some se's have adventure type controls with an agnition kill on off switch, others have push kill like exc's.
525 exc rally lite project
950superenduro.com For those who own the best bike!
wilso122 is offline   Reply With Quote
Old 05-01-2013, 03:42 PM   #1682
max2
max2's Avatar
Oddometer: 219
My manual shows its the middle relay under the seat
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 05-01-2013, 03:56 PM   #1683
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 412
middle? there are 4 relays under my seat but i have no idea which one might be the fuel pump.
mud... its the new chrome
ststrider is online now   Reply With Quote
Old 05-01-2013, 03:57 PM   #1684
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 412
check voltage with a meter at fuel pump while cranking the starter
no juice when cranking.
Old 05-01-2013, 03:58 PM   #1685
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 412
the kill switch is in the run position.
Old 05-01-2013, 04:19 PM   #1686
CA Stu
CA Stu's Avatar
Oddometer: 48,000
You could easily swap them around...
Here's a link to another SE pump problem (solved) http://www.advrider.com/forums/showthread.php?t=852211
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 05-02-2013, 03:58 PM   #1687
KASUYAHO
Road Hog
Oddometer: 3,789
Glenn, you have PM, respond to that and your wish will be granted
Online parts, not sure about OZ but KTMtwins.com in the states ship all over and I know a dealer in the UK that could probably ship you stuff if you get stuck with anything.
HTH Wilso
Thanks for that Wilso
KASUYAHO is offline   Reply With Quote
Old 05-03-2013, 11:03 AM   #1688
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 412
for future reference the fuel pump relay is the front one in a row of four under the seat.once i got some help i found i was getting 5-6 volts to the fuel pump during start up cycle and then 5-8 volts while running.no pinches in the wiring so i hope its just a relay but i will have to wait till next week to try one.till then i made up a plug that uses the power cord from my aerostich warmbib and an sae flat connecter which gives me direct power to the fuel pump.
Old 05-06-2013, 11:26 AM   #1689
SpeedyR
SE in the SE
Oddometer: 956
not a question but a point of reference for the SE riders- I asked a few weeks ago about rear brake pads for the SE. Turns out they are the same as the front pads on my 07 450. I ordered a new set, but had a spare set for the 450 and they fit perfect. So if you need 'rear' pads for your 450, check to see if the dealer has any fronts for a 450 in stock.
SpeedyR is offline   Reply With Quote
Old 05-06-2013, 11:50 AM   #1690
wilso122
Oddometer: 184
Aren't they different disc sizes? 260 and 240? Seems odd they fit..
Old 05-06-2013, 04:24 PM   #1691
KASUYAHO
Road Hog
Oddometer: 3,789
Hey guys,
Setting the valve clearance, do you guys use Hotcams shim kit ?
And do the clearances on the LC8 need to be done a lot ?
Cheers
Glenn
Old 05-07-2013, 09:10 AM   #1692
wpbarlow
Oddometer: 11,503
SE Taillight
Does anyone know if the SE shares the rear taillight lens with another model that allows just ordering the red plastic? It looks like the only way to get the red plastic is to buy an assembly, which seems pretty cheesy on KTMs part. The SM and Adventure are the same
wpbarlow is offline   Reply With Quote
Old 05-07-2013, 10:59 AM   #1693
georgedaman
Oddometer: 124
Originally Posted by KASUYAHO View Post
Hey guys,
Cheers
Glenn
Hi
I just ground down the existing ones on sandpaper.
If you have a proper caliper and that shim calculator program, you can get it closer then anything available, plus its free and you can do it all at once vs. leaving the bike open, order ,pick up etc.
Apperently not much adjustment needed on the first scheduled check at 7-8k but i had some tight valves later.
georgedaman is offline   Reply With Quote
Old 05-07-2013, 07:24 PM   #1694
AndyCap
Mineral Oil Anyone?
AndyCap's Avatar
Oddometer: 1,473
Originally Posted by Xmoto View Post
Very nice! I have been trying to buy a SE but am having problems. I don't think I have ever worked so hard to spend money . If I can't get one this would be my next choice.
I just swooped down to NJ and bought one today. There is one in Florida that looks awesome. I just couldn't get my free time to line up with the seller's
2004 R1150GSA, 2000 BMW R1150GS, 2008 KTM 950R SE, 2001 Honda XR400R, 2003 Honda XR100R
Another Proud Small Scale Faker......
New England Pie-O-Rama
ADV Pie Map
AndyCap is offline   Reply With Quote
Old 05-07-2013, 08:42 PM   #1695
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,968
Originally Posted by wpbarlow View Post
Does anyone know if the SE shares the rear taillight lens with another model...
I ordered the stock male & female quick coupling for the fuel line at the 950SE fuel pump WITHOUT checking the price first.
When they arrived, I found out both pieces totaled $83.00 !!!!!!!
I like having spare parts on hand, but Dang
Brown Dog is offline   Reply With Quote
Times are GMT -7.   It's 02:20 AM.
