Old 05-08-2013, 07:01 AM   #1696
wpbarlow
Oddometer: 11,267
Originally Posted by AndyCap View Post
I just swooped down to NJ and bought one today. ...
Who's did you buy?
wpbarlow is offline   Reply With Quote
Old 05-08-2013, 07:03 AM   #1697
wpbarlow
Oddometer: 11,267
Originally Posted by Brown Dog View Post
I ordered the stock male & female quick coupling for the fuel line at the 950SE fuel pump WITHOUT checking the price first.
When they arrived, I found out both pieces totaled $83.00 !!!!!!!
I like having spare parts on hand, but Dang .
I just bought a used tail light off ebay for $20. It's for an '04 Adventure, but they look identical on the fiche even though they have a different p/n. The Adv part is $120 for some reason.
Old 05-08-2013, 07:11 AM   #1698
HooliKen
Awesome is a flavor
HooliKen's Avatar
Oddometer: 3,014
Originally Posted by KASUYAHO View Post
Hey guys,
Setting the valve clearance, do you guys use Hotcams shim kit ?
And do the clearances on the LC8 need to be done a lot ?
Cheers
Glenn
Yep! Use the hot cams kit. Very happy with it.
Did mine at 20K, all four exhaust were tight, buy only slighty.
And the duration you go between checks will depend a lot on how you ride.
"People in this country sleep peaceably in their beds at night because rough men stand ready to do violence on their behalf." George Orwell
950R Super Enduro - 450EXC - Gas Gas TXT 280 - 2000 Honda XR100R - 1988 Honda Z50R
HooliKen is offline   Reply With Quote
Old 05-08-2013, 06:14 PM   #1699
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,960
Keep us posted if it fits & the difference between the two
Brown Dog is offline   Reply With Quote
Old 05-09-2013, 07:11 AM   #1700
AndyCap
Mineral Oil Anyone?
AndyCap's Avatar
Oddometer: 1,472
Who's did you buy?
Originally it belonged to WARRIORPRINCEJJ
He sold it to Quint Eastwood, and I bought it from him.
2004 R1150GSA, 2000 BMW R1150GS, 2008 KTM 950R SE, 2001 Honda XR400R, 2003 Honda XR100R
Another Proud Small Scale Faker......
New England Pie-O-Rama
ADV Pie Map
AndyCap is offline   Reply With Quote
Old 05-10-2013, 04:31 AM   #1701
Balsta
Oddometer: 400
Hey guys,
Cheers
Glenn
I just buy a one step thinner shim when the gap goes too small. After 113 kkm and two motors I have learned:
  • clearance hardly changes providing the motor operating temperature is stable (nowadays my 2009 990 motor never sees anything but four bars on the panel) also with plenty high load on low and high rpms at low speed and very high ambient temperatures
  • intake valve clearances havent changed at all after 40000 km
  • all four exhaust valves needed one step thinner shim after 40000 km
  • my old 2006 950 motor was another animal, much more temperature variations and need to reshim both intakes and exhausts after each season of about 20000 km
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 05-10-2013, 06:25 AM   #1702
mousitsas
mousitsas's Avatar
Oddometer: 2,948
I read that Clint Eastwood
Old 05-10-2013, 08:48 AM   #1703
mattc
mattc's Avatar
Oddometer: 439
Anyone with a Safari Tank have clearance issues between the brace and the front tire? I have the flat bar style brace and even with a short mt21 front, it caught and twisted the brace at full compression.
I modified it a little for more clearance. Will test ride and verify a fix at some point. I'm curious if others have had this trouble.
mattc is offline   Reply With Quote
Old 05-10-2013, 01:43 PM   #1704
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,590
Yes I have the flat brace & notice that it hits sometimes on a hard landing wheel stand. The tube one broke & was pretty crappy. Would like to see the photos of your mods to the brace.
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 05-10-2013, 11:18 PM   #1705
Crowley
Crowley's Avatar
Oddometer: 56
Guy that I ride with once in a while also complains about the lack of clearance.
It stands out quite a but more than the old tube type bracket that I have on mine. Tube type has no clearance problems.
Crowley is offline   Reply With Quote
Old 05-11-2013, 10:15 AM   #1706
bigkuri
bigkuri's Avatar
Oddometer: 842
What is this diode actually for? It is in the cowling, and part number 11 on the parts fiche.
One of the wires going into it broke; I only noticed that my indicators stopped working. I have repaired the wire, but now the indicators don't flash, just a constant light. I thought diodes are just like a one-way directional valve for the current, but wondering if it has something to do with the flashing?...
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R
bigkuri screwed with this post 05-11-2013 at 10:22 AM
bigkuri is offline   Reply With Quote
Old 05-11-2013, 11:47 AM   #1707
charlie264
charlie264's Avatar
Oddometer: 8,367
Pretty Much, they tend to go two ways...ohms meter...they break so no flow, they open so flow both ways.
Looking at the SE C diagram...can only see two diodes....one diode is to do with return for the gear sensor switch and tuther clutch switch...should be nout to do with indicators....check flasher relay.
charlie264 is online now   Reply With Quote
Old 05-11-2013, 12:25 PM   #1708
wpbarlow
Oddometer: 11,267
I just bought a used tail light off ebay for $20. It's for an '04 Adventure, but they look identical on the fiche even though they have a different p/n. The OEM Adv part is $120 for some reason.
I received the used Adv tail light yesterday and it is identical to the SE (and SM) piece. Still can't understand why the Adv piece is $40 more (OEM) than the others.
I also don't understand why KTM didn't provide a lens that screws on, rather than making it a whole sub-assembly. There's not much room to snake your hand in to either replace a bulb or remove the unit. Having younger grand-kids is helpful
Old 05-11-2013, 12:48 PM   #1709
bigkuri
bigkuri's Avatar
Oddometer: 842
Thanks! eerrrrr which one is actually the flasher relay? The last one before the tail-light??...
Old 05-11-2013, 12:58 PM   #1710
Brown Dog
Brown Dog's Avatar
Oddometer: 1,960
I received the used Adv tail light yesterday and it is identical to the SE (and SM) piece ...
Walter,
I added a 1/2" thick piece of foam to the existing top foam on the lens to keep it from shaking & jarring on rough trails
http://advrider.com/forums/showthread.php?t=580886
Times are GMT -7.   It's 05:23 PM.
