Old 04-18-2013, 09:23 AM   #1711
kanur
cu new er
kanur's Avatar
Oddometer: 715
Originally Posted by JRod152 View Post
***Caution***
It seems my "new-style" brace needs some slight modification. It's rubbing on each side of the radiator, both on the seam and the corner. Sorry for the poor phone pics, but you get the idea. You can see bare aluminum if you look closely. I was actually thinking about calling up to request the old style brace for this reason.
Anyone else with similar experience?
I had to do a lot of tweeking to my new style brace to get it to clear the radiator to my liking.
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Old 04-23-2013, 01:29 AM   #1712
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,558
Rear Brake Rotor
Will a 950 Adventure Rear Brake Rotor fit a 950Super Enduro ?
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 04-23-2013, 04:26 AM   #1713
Modder
Modder's Avatar
Oddometer: 17
Rear brake rotor
Should be no problem.
I use a complete set of 950 Adv wheels with discs and sprocket.
(removed one front disc)
I shrink bikes
Modder is offline   Reply With Quote
Old 04-24-2013, 01:39 AM   #1714
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,558
Confirmed. Bought a new sold Metalgear rear disc rotor for a 950ADV & it fits like a glove, even used original bolts.
Much cheaper than floating disc @ $129 & will last longer.
Hodgo Spot
Old 04-29-2013, 01:11 AM   #1715
Monkey Butt
Rusty
Oddometer: 80
Hi Guys,
I have recently purchased a SE and are enquiring on the correct way to fit a under bar Scotts Damper to the SE that has a 30ltr Safari fitted. In my opinion it appears that it does not fit, I also have the BRP triple clamps. The frame bracket that attaches the Damper to the frame is where the problem lies. It appears there is not enough clearance between the base plate and the Safari tank.
If you have this set up can you please explain on how to fit and even better if you could send some close up photos of your set up.
Cheers Russ.
Monkey Butt is offline   Reply With Quote
Old 04-29-2013, 08:14 AM   #1716
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,739
Originally Posted by Monkey Butt View Post
Hi Guys,
Cheers Russ.
Heya Russ
You will have to take a small skim off the top of the front bolt bracket as it is too tight as you have discovered.
Will take a couple of pics this morning for you.
Cheers Andi
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 04-29-2013, 11:26 AM   #1717
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,739
Heya Russ
Sorry for the quality but Ellen took the good camera to school and if these do not show you what you need I will ping some more of tomorrow morning.
Posted a few pics with slightly different angles, sorry bout bein grubby haven't done the housework for a few weeks
Any queries fire away.
Old 04-29-2013, 03:17 PM   #1718
wilso122
Oddometer: 183
cpr rottweiler intake
Interested in hearing 950SE specific good bad n ugly on fitting the CPR Rottweiler air intake on the 950SE. Read quite a bit already but its all mixed in with ADV's, so those who have fitted to the mighty SE can you share your thoughts?
Really interested in whats it like on wet muddy trails as well as desert....
Seems easy enough to fit but have most of you re-jetted?
Have a full 2-1 exhaust system and the blow is fine just need to work through the suck......
525 exc rally lite project
950superenduro.com For those who own the best bike!
wilso122 is offline   Reply With Quote
Old 04-30-2013, 05:47 AM   #1719
Monkey Butt
Rusty
Oddometer: 80
Hi Andi,
Thanks for all your trouble with the photos, I really appreciate it. How did you cut into the steel etc and is it possible to point out which area you shaved off exactly. I am a bit of a dumbass in this area.
Thanks again mate.
Cheers Russ.
Old 04-30-2013, 09:00 AM   #1720
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,739
Hi Andi,
Thanks again mate.
Cheers Russ.
Heya Russ
This was all done when we got the bike so I cab't honestly tell you.
It would just be a matter of taking your time, marking it out and doing it quietly and properly.
We will have the tank off in a week and a half doing air filter etc so can put so "apart" photos up if this helps.
Old 04-30-2013, 11:14 AM   #1721
bigkuri
bigkuri's Avatar
Oddometer: 724
Any pictures or description of where you run your fuel filter, and how routed to fit with the stock fuel pump and a 30l Safari tank?
I've only seen one post describing a big loop from after the T-junction, out to around the rear cylinder, the filter zip tied to the frame, and then back up to the quick disconnect. Sorry no photo though, hence my ask! Also, that method sounds a bit clunky... :)
---------- Current Bike: 2006 Honda XR650R ------------
bigkuri is offline   Reply With Quote
Old 04-30-2013, 03:59 PM   #1722
Monkey Butt
Rusty
Oddometer: 80
No worries, thanks again Andy.
Cheers Russ.
Old 04-30-2013, 04:45 PM   #1723
KASUYAHO
Road Hog
Oddometer: 3,574
A few questions
Hi Guys,
Is there somewhere I can download the proper work shop
manual for the SE ?
Also where is the best place to buy EOM and aftermarket parts online for the SE ?
Cheers
Glenn
KASUYAHO is offline   Reply With Quote
Old 05-01-2013, 05:29 AM   #1724
wilso122
Oddometer: 183
Originally Posted by KASUYAHO View Post
Hi Guys,
manual for the SE ?
Cheers
Glenn
Glenn, you have PM, respond to that and your wish will be granted
Online parts, not sure about OZ but KTMtwins.com in the states ship all over and I know a dealer in the UK that could probably ship you stuff if you get stuck with anything.
HTH Wilso
Old 05-01-2013, 03:10 PM   #1725
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 377
can anyone tell me where the fuel pump relay is located on a 950 se.i was leaving work and she would not start fuel pump dead.swapped the fuel pump with a spare i keep around(facet) and still no go,i figure its the relay or i have to chase down a pinched wire. i wired the pump direct it fires up so its a power supply issue.
mud... its the new chrome
ststrider is offline   Reply With Quote
Times are GMT -7.   It's 04:29 PM.
