Old 07-16-2013, 09:28 AM   #1786
BENRON
I'm Mr. Crabtree
BENRON's Avatar
Oddometer: 3,632
fwiw, My SE can also be finicky about finding neutral when it's good and hot with the engine running.
I've never worried about it.
BENRON is offline   Reply With Quote
Old 07-17-2013, 08:43 PM   #1787
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 238
RadGuard (Australia) Radiator Guard
RadGuard - I need a radiator guard and am curious to know whether anybody has experience with this piece of kit and the folks who make them.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 07-22-2013, 08:17 AM   #1788
KaaJa
KaaJa's Avatar
Oddometer: 45
What is the thickness of a waterpump cover o-ring?
Its leaking and I cant get original part fast enough so I try to make one from o-ring material.
Sim Salabim Bamba Saladu Saladim
KaaJa is offline   Reply With Quote
Old 07-24-2013, 07:54 AM   #1789
SpeedyR
SE in the SE
Oddometer: 875
cut intake for foam dome filter?
and another question- those that have added a CPR or other similar filter (sportingwoods), how much did you trim the air intakes to fit? If anyone has a photo or can just describe how much they trimmed I'd appreciate it.
wasn't sure if I should take off the belled/flared area, or if it's the height that needs to be reduced, or if you are really just using the intake to hold the plate in place and you really cut it down.
SpeedyR is offline   Reply With Quote
Old 07-24-2013, 08:11 AM   #1790
wilso122
Oddometer: 183
I cut off the belled/flared are so about 1/2inch to an inch, there was a flat bit on the side from memory and I cut straight over from the top of that.
hth if not can see if I can get a photo for you over the weekend.
525 exc rally lite project
950superenduro.com For those who own the best bike!
wilso122 is offline   Reply With Quote
Old 08-06-2013, 08:33 AM   #1791
Colorado Uli
Motociclista Non Elegante
Colorado Uli's Avatar
Oddometer: 2,562
Clutch hoser
Oi! I've pinched the clutch hose enought to have to replace it now. Anyone know how long it is so I can try to find one that doesn't cost $1,000,000,000?
Danke from the Uli
Something, something, something ... in latin.
"Now with more SE then ever!"
Das KTM520
2004 KTM 625 SXC - Sick. Getting better
Colorado Uli is offline   Reply With Quote
Old 08-06-2013, 06:12 PM   #1792
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,336
Danke from the Uli
I just happen to have a brand new in sealed package clutch pipe that I don't need. If you're interested, PM me and I can save you some money.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 08-10-2013, 07:49 PM   #1793
Behindbars
Let's Ride
Behindbars's Avatar
Oddometer: 680
The bolt in the center with oil residue. What does it do and why do I have oil residue?
2011 Kawasaki Concours 14
2009 KTM 950 Super Enduro
Behindbars is offline   Reply With Quote
Old 08-10-2013, 08:22 PM   #1794
JRod152
will work for tires
JRod152's Avatar
Oddometer: 303
When you remove "that bolt", you have access for the tool/bolt can find the notches in the crank. This confirms TDC w/ correct camshaft orientation and ensures no movement during a valve check and camshaft removal, etc.
See HERE
If it's leaking or seaping, retorque... 10NM. If it doesnt seal, replace the copper washer, or anneal (soften) it.
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 08-11-2013, 06:02 AM   #1795
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,519
Case question
So first off, I have noticed with every recent oil change (now 15K on the bike) that the bolts one removes to drain the oil, and clean the filters, have all shown some significant wear. Effectively, they all go from a linear, parallel profile, to more of a coke-bottle profile where the middle of the bolt is narrower than the tip and the part closest to the head. This applies to to the M6 and M8 bolts, not the actual drain plug.
Seeing this, and after snapping off one of these bolts while removing it for an oil change last year, I opted to replace the bolts with stainless steel - I don't recommend this as I think the stainless steel bolts in the softer metal case causes problems...which is what I will get to now.
2 oil changes later, while replacing the lowest bolt that holds the oil filter cap, the bolt snapped off at the head, in the case. While using a bolt extractor to get the bolt out, the part of the case where the bolt resides cracked. This part of the case is contiguous with the entire left-sided engine case.
Now my question...Is the case Magnesium or Aluminum? The bike is 2500 miles from home, and I want to get it welded and re-tapped.
Learn from my mistakes? It is probably worth replacing all those bolts (6 in all - 4 on the left and 2 on the right) whenever doing an oil change, or at least at regular intervals.
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 08-11-2013, 06:26 AM   #1796
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,889
We haven't had any issues with these, are you over tightening them or torquing them up.?
Sorry can't answer about the casings.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 08-11-2013, 09:06 AM   #1797
Behindbars
Let's Ride
Behindbars's Avatar
Oddometer: 680
See HERE
So I should be able to pull that bolt out,clean it, install new washer and reinstall to 10NM?
Old 08-11-2013, 09:43 AM   #1798
JRod152
will work for tires
JRod152's Avatar
Oddometer: 303
Yep
If you have an se, the oil tank has no check valve. So lay the bike on its left side to remove and replace... Minimal to no oil loss if done briskly. The adventures have a check valve won't have much in the sump.
Old 08-11-2013, 09:58 AM   #1799
Behindbars
Let's Ride
Behindbars's Avatar
Oddometer: 680
Thanks!!
Old 08-11-2013, 12:01 PM   #1800
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,301
Hi OC,
Does anyone have detailed pictures showing bracket ideas to support the digital speedo display once the stock headlight is removed? I'm looking at installing the Baja Designs LaPaz Dual 8 inch headlights on my SE once I get out to California (the bike's in storage in Cali right now and I'm on the east coast). I want to know if this is something I could fab up in a hotel parking lot, or something I can build before I go and bolt on. From what I gather (and remember I don't have the bike in front of me), the speedo unit is held by the stock plastic headlight housing.
Thanks.
-JW
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Times are GMT -7.   It's 11:09 PM.
