Old 09-21-2013, 12:13 PM   #1831
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,324
Well, I'm embarassed to admit that it was the very common water pump failure. I didn't have any of the other symptoms though. But I think the image below is self explanatory.... Fortunately, I have a spare fuel pump and water pump kit with me. I don't have any tools here at my friends house, but there is a KTM shop in town that is very helpful, so I'll just take in the right side engine plate and let them install the new one.
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters screwed with this post 09-21-2013 at 12:19 PM
jwalters is offline   Reply With Quote
Old 09-21-2013, 02:04 PM   #1832
charlie264
charlie264's Avatar
Oddometer: 8,367
Not necessarily, are you loosing coolant? Moisture that naturally acours in the engine just condences on the coolest parts, and that give gunk....
Same happens on air/oil cooled motors, but also could well be an indication of WP seal/shaft on its way out.
charlie264 is online now   Reply With Quote
Old 09-21-2013, 02:11 PM   #1833
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,324
You can see my post above. I was loosing a lot of coolant. 1 quart in 900 miles.
For reference, I also have a 990 Adventure that I put 50K on, never had a WP failure on it. The clutch stays dry with exception for a few drops of motor oil, so it's definitely not normal on these LC8 motors. What threw me was I didn't have any other symptoms.
jwalters screwed with this post 09-21-2013 at 02:30 PM
Old 09-21-2013, 03:39 PM   #1834
charlie264
charlie264's Avatar
Oddometer: 8,367
Yeh sorry didn't read that bit,
Personally think to many unnecessary changes due to a bit of emulation, which is normal.
The latest shafts are a gun blue colour and the seal is grey, if your not changing the bearings it can be done easily enough in the field...no special tools needed.
Don't bother taking the impeller off before removing the case, once its off you can just undo the bolt with a flat blade on the back of the shaft. Take the rear lip off and knock the shaft out and the other clip will push the seal out. Once the shaft is out you can knock the shaft out of the impeller, that's if it didn't come off easily earlier.
Old 09-23-2013, 11:40 AM   #1835
rattis
rattis's Avatar
Oddometer: 1,238
Pos?
I have a Hyde bash thingy made out of plastic (ABS) in the rar it's supported by 2 very flimsy looking 2mm bent pieces of flat bar with captive nuts.
It's pushed forward by the center stand so that these "support are all bent outta shape and it's also deformed around the oil tank bolts(by being pushed forwards.
What to do?
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline   Reply With Quote
Old 09-24-2013, 08:34 AM   #1836
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,664
What to do?
Throw it away. I had a Hyde bash plate on my new 500 and it shattered on the first ride. I don't know how they can stay in business.
Get a hold of Mike at info@mvmotoventure.ca. He's on the board here, but I've forgotten his user name. I just installed one of his skid plates on my SE last night. Nice product, good fit, no risk of oil cooler and rad damage. Pleasure to do business with, too.
unaweep is offline   Reply With Quote
Old 09-25-2013, 02:35 AM   #1837
KaaJa
KaaJa's Avatar
Oddometer: 50
Will upper triple from exc with 20mm offset fit on SE?
Sim Salabim Bamba Saladu Saladim
KaaJa is offline   Reply With Quote
Old 09-27-2013, 02:45 PM   #1838
triplenickel
triplenickel's Avatar
Oddometer: 2,430
he's on the board here, but i've forgotten his user name
lakemonster
07 SE
PG007
Old 09-27-2013, 05:58 PM   #1839
unaweep
unaweep's Avatar
Oddometer: 20,664
Originally Posted by triplenickel View Post
lakemonster
Thank you.
He's a good dude making a real nice product.
Old 10-10-2013, 01:14 PM   #1840
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
Hola.....
Ok...currently have the Facet mounted to the back of my airbox....
Going to lose the airbox (rottweiler) but want to keep the Facet in the same position.
Has anyone come us with a workable mount for that spot?
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 10-10-2013, 01:36 PM   #1841
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
just a L bracket mine was from a spare Honda XR/XL indicator mount.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 10-10-2013, 04:10 PM   #1842
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 249
Hey, V2, I was looking for these exact photos over on KTMTalk and they're all gone. It was a beautiful spread. What happened?
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 10-10-2013, 05:28 PM   #1843
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
thanks vee...
looks like some simple bar stock is in my future....
Old 10-10-2013, 06:29 PM   #1844
veetwo _tls
RENOVATIO:
Oddometer: 1,850
sorry about that my photobucket account got full so sorted out my junk from good while it was down. so all my pics got moved around & broke the links on here , tlzone , tlplanet , speedzilla , phil motorcycles , ktm talk , thumper talk , af1 aprillia etc. was just too much to fix
CHEERS: brett
MY07 950 SER
Old 10-10-2013, 06:31 PM   #1845
veetwo _tls
RENOVATIO:
Oddometer: 1,850
Originally Posted by Nowwhat View Post
thanks vee...
yeh mate simple 30min job
CHEERS: brett
MY07 950 SER
Times are GMT -7.   It's 02:50 PM.
