Old 10-10-2013, 07:05 PM   #1846
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 244
Originally Posted by veetwo _tls View Post
sorry about that my photobucket account got full so sorted out my junk from good while it was down. so all my pics got moved around & broke the links on here , tlzone , tlplanet , speedzilla , phil motorcycles , ktm talk , thumper talk , af1 aprillia etc. was just too much to fix
Understand. At least it was only small tragedy. That's too bad (for me ), though, as your SE build thread has provided much inspiration and many ideas. I should have been quicker.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 10-10-2013, 08:00 PM   #1847
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,922
Originally Posted by Nowwhat View Post
Hola.....
Ok...currently have the Facet mounted to the back of my airbox....
Going to lose the airbox (rottweiler) but want to keep the Facet in the same position.
Has anyone come us with a workable mount for that spot?
I went with the front of airbox option with the CPR. Hoping to use the other area for an underseat storage box later.......
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 10-13-2013, 05:14 AM   #1848
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,956
Question Is this mileage about normal for the OEM Fuel Pump ?
My OEM stock fuel pump lasted 14,203 miles
It had been very weak to prime up when switched on the last few months, so I knew its days were limited
I replaced with another OEM stocker.
I'll prolly put a Dr Bean's kit in my Old pump I took out
Brown Dog is offline   Reply With Quote
Old 10-13-2013, 05:17 AM   #1849
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
why waste money & time all time on these electric pumps ? powercell's mod with the mikuni vacuum pump was the best. thing do it once & for get it.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 10-13-2013, 05:25 AM   #1850
Brown Dog
Brown Dog's Avatar
Oddometer: 1,956
I'm not sold on any Aftermarket pumps & most of em puts out Way Too Much Pressure.
The Vacuum Pump may be ok
Anything over 1.5psi is OverKill IMHO.
Old 10-13-2013, 05:35 AM   #1851
veetwo _tls
RENOVATIO:
Oddometer: 1,850
personal experience i been using the mik vacuum for near 3 yrs now not one problem so far.
just add an easy to reach fuel tap see post 1891 (yellow lawn mower fuel line tap)
cheers: brett
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 10-13-2013 at 05:41 AM
Old 10-13-2013, 07:21 PM   #1852
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
cheers: brett
Never could get my bike to run in the Whoops with a vacuum pump....????
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 10-14-2013, 03:39 AM   #1853
Brown Dog
Brown Dog's Avatar
Oddometer: 1,956
NW, what pump did you end up using ?
Old 10-14-2013, 03:46 AM   #1854
mousitsas
mousitsas's Avatar
Oddometer: 2,911
I have never heard of a dr bean mod failure, but have heard problems with all other alternatives.
Also, by taking away electric load from the R/R (ie vacuum pump) doesn't that mean that it may get even hotter?
mousitsas is online now   Reply With Quote
Old 10-14-2013, 07:37 AM   #1855
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,656
The bottom end of my pump crapped out with the Dr bean kit. Not the fault of the kit, but just shows that the pump isn't perfect once installed. Running a facet now. Didn't want to deal with a manual fuel shutoff.
BENRON is offline   Reply With Quote
Old 10-14-2013, 08:02 AM   #1856
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
Facet
8k miles....all good
Old 10-14-2013, 05:32 PM   #1857
mookymoo
Mookish Mook
Oddometer: 4,396
Same in my case.
Electrical erosion isn't the only failure mode.
The internals of the pump can corrode and the piston can stick. In this case you tend to get intermittent failure symptoms. A sharp hit to the pump will free it up for a little while... maybe enough to get you home (as was my case).
Facet was the replacement here too ...
mookymoo is offline   Reply With Quote
Old 10-17-2013, 05:51 AM   #1858
Balsta
Oddometer: 400
My oem contacts blew up after around 40 kkm. 1st Facet died after just some 20 kkm (probably due to operation with empty gas tank). 2nd Facet has now 60 kkm and just works and works and works
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 10-17-2013, 07:22 AM   #1859
mousitsas
mousitsas's Avatar
Oddometer: 2,911
Is there any case that the facet does not corrode due to alternative placement?
Question mainly aimed to river crossers.
Old 10-17-2013, 08:11 PM   #1860
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
Rottweiler Air Filter went on today......
Nice change...better throttle response...the access and dirt bike like filter cleaning....very nice...
Times are GMT -7.   It's 01:36 PM.
