Old 01-14-2014, 07:55 AM   #1891
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,954
Originally Posted by bigborefan View Post
The rad switch I am referencing causes the fan to come on sooner at a lower temperature ...
Good Choice
I'm running one on my 690 & 950
Brown Dog is offline   Reply With Quote
Old 01-14-2014, 08:42 AM   #1892
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,620
I am disappointed BrownDog. I thought for sure you would recommend silver rims....
What if you took Axl Rose down to Paradise City, but the grass was brown and under watered?
bigborefan is offline   Reply With Quote
Old 01-15-2014, 05:51 PM   #1893
Brown Dog
Brown Dog's Avatar
Oddometer: 1,954
Lol
Yea Them TOO
I Must be Well Remembered for that
Old 01-29-2014, 05:28 PM   #1894
1derer
Sh*t Where am I?
Oddometer: 261
Rally Fuel Tank Question
I was not able to find any info on fuel flow. Does the rally side fuel tank empty into main 1st or? Interested in one does anyone have experience with this tank they can share?
1derer is offline   Reply With Quote
Old 01-29-2014, 06:27 PM   #1895
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 493
Yes I have one. PO had the top rear mounting using zip ties though. Must fabricate a proper bracket.
If you ride with the aux petcock open it will go down in tandem with the main. If you want to use it as a reserve just keep the aux petcock closed until you need it.
I now run a Safari main and I'm keeping the aux as a reserve. Just make sure the petcock closes fully. Mine doesn't and leaks into the main, depleating my reserve. Must fix it.
Depends on one's range requirements but I like having the gas onboard
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 01-30-2014, 07:21 AM   #1896
triplenickel
triplenickel's Avatar
Oddometer: 2,428
You can plumb it to flow anyway you want, I didn't like the weight back there when luggaged up for travel so I'd run it out first. I installed a small valve so I could just reach down and switch to the main tank when this one was empty (first little sputter) or when mileage said it should be low. There was a check valve in the line from the aux tank to prevent back flow from the main.
07 SE
PG007
Old 01-30-2014, 09:31 AM   #1897
1derer
Sh*t Where am I?
Oddometer: 261
Like that idea prefer the aux tank to drain 1st.
Old 01-30-2014, 10:07 AM   #1898
KaaJa
KaaJa's Avatar
Oddometer: 47
You can connect it to main tank breather hose and it will drain the rear tank first automaticly. You might have to add o-ring under the main tank cap gasket to make it tight. Works like a charm.
Sim Salabim Bamba Saladu Saladim
KaaJa is offline   Reply With Quote
Old 02-07-2014, 02:30 PM   #1899
Afry
Why hike?
Afry's Avatar
Oddometer: 611
I have and and prefer it to the big Safari tank up front. Mine is always connected and drains slower then the main tank. When the main tank is empty the rear tank has about 1/3 left.
I once had a problem in Death Valley riding up a looooong uphill road for a good 20 or so miles and didn't make it to the top as the rear tank stopped feeding due to the incline and the front tank was dry. A buddy gave me a pint of fuel and I made it to the top.
I used to get 135 miles out of the stock tank and now it good for over 200.
I don't really notice the extra weight in the back but when I put it on I still had the stock exhaust so I think it's even when comparing the two setups.
KTM 950 SE
Yamaha TDR250
CRF450 flat tracker
Get on with riding or get on with dying - one or the other
Afry is offline   Reply With Quote
Old 02-07-2014, 02:51 PM   #1900
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,949
We have the same setup although CJ tank and like you always run the rear tank dry first, system works very well.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 02-07-2014, 09:04 PM   #1901
1derer
Sh*t Where am I?
Oddometer: 261
I was looking at the CJ as well, what range do you get with the CJ added?
Old 02-08-2014, 05:26 AM   #1902
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,949
130 km or 80 miles usually.
Old 02-12-2014, 04:54 PM   #1903
1derer
Sh*t Where am I?
Oddometer: 261
Anyone have a set of SE / SM passenger pegs they would be willing to separate with? Interesting how some came with pegs and some didn't. Then again I guess its one of those things KTM couldn't decide if should be included or not.
Old 02-12-2014, 05:04 PM   #1904
Nytro
Nytro's Avatar
Oddometer: 117
Handlebars wanted
Have any of you swapped out your stock handlebars and threw them in a box somewhere in your garage?
I'm looking for clean undamaged set for my Adventure. Thanks.
Nytro is offline   Reply With Quote
Old 02-12-2014, 08:32 PM   #1905
Brown Dog
Brown Dog's Avatar
Oddometer: 1,954
Best swap U can do is get rid of those swept back adventure / SM bars & repłace with the Wider Straighter OEM SE bend bars
Smart move
Times are GMT -7.   It's 02:59 PM.
