Old 03-05-2014, 01:27 PM   #1936
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,895
Can someone with factory mufflers please give me the outlet diameter on the muffler.
Many thanks Andi
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 03-05-2014, 06:31 PM   #1937
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 905
Out Let
27mm ID
dogsslober is offline   Reply With Quote
Old 03-06-2014, 03:35 AM   #1938
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,895
Originally Posted by dogsslober View Post
27mm ID
Cheers man, appreciate it
Old 03-06-2014, 03:56 AM   #1939
Jarno
Jarno's Avatar
Oddometer: 23
Thx for the quick reply guys!
I don't hate people, i just feel better when there not around.
600SS, GPZ500, Z750S, ADV990, ADV640, 950SUPERENDURO
Jarno is offline   Reply With Quote
Old 03-08-2014, 01:59 AM   #1940
johnno950
Oddometer: 1,074
Some questions
I recently got a 950se just after some onfo if possible please gentlemen,
# do the oem voltage regulators fail because of where they are located?,or have they got a internal oem problem?,if its heat related i will relocate it.
#the rottwieler filter system,is it a good thing?any dramas with dirt ingress if mounted and serviced to oem specs?
#any dramas with useing a mikuni diaphram pump instead of the oem pump? thanks
johnno950 is offline   Reply With Quote
Old 03-08-2014, 08:16 AM   #1941
Headbeater
Oddometer: 49
Very happy with my 950 se and the rottwieier (spelling>?), but make sure you use a filter sock, like PC racing. I can remove my filter without removal of the fuel tank, saves lots of time and the extra power is nice.
Headbeater is offline   Reply With Quote
Old 03-08-2014, 08:22 AM   #1942
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,895
Had to pinch the little connectors a little on my turn sig, unplugging and plugging back in wasn't a nuff
Ok, crimped the little buggers this time, before crimping I noticed that when they were fully on they seem to sit not completely firm so now there is no dispute and they will need a tractor to pull them out, hopefully this will sort it.
Just need a battery and new front tire, of interest MT21 or Enduro 3 front in Salta Argentina ...... $250 USD , $50 in Peru!!!
Old 03-08-2014, 06:38 PM   #1943
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 238
Little Carburettor Problem...
I've got a small problem that's stumping me. Bike is stumbling at high speed 75+ mph and ultimately dies. Pull to the side, restart, repeat. If I don't whack it or run at a reasonable pace, it goes all day. Running a Motohooligan intake with reworked jetting from H2W - 45 low, 65 idle, 178f/180r main, IMS @ 2.5, 3.0+mm float. It's a bit rich at sea level, but fine at altitude.
One thing rather strange did occur during the clean and re-jet. There were no lower washers on the slide needles. I thought this strange, but there were no operational issues before this change, so I just reassembled and moved on. With all the other changes, could this be the source of my current issues?
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 03-08-2014, 08:29 PM   #1944
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,301
Hmm... If it was just a jetting problem, I can't believe the bike would actually die. Your idle circuit seems right on so the bike should idle. To be clear, you're saying your bike stumbles at high speed and then your rpm goes to ZERO and you have to restart?
Sounds fuel related to me. Any kinked vent lines? Have you tried running with the gas cap open as a starting point?
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 03-09-2014, 12:49 AM   #1945
DRJens
DRJens
Oddometer: 16
Fuelpump...
DRJens is offline   Reply With Quote
Old 03-09-2014, 12:52 AM   #1946
mousitsas
mousitsas's Avatar
Oddometer: 2,784
Needles at?
Ambient temperature?
If I got it right, if you open the thottle slowly it is fine up to 100% throttle, but it dies on hard acceleration, correct?
Also, I beileve you meant LEAN @ sea level, fine at altitude. Is there any case your problem appeared with dropped outside temperatures?
Old 03-09-2014, 05:09 PM   #1947
Monterey_BS
Oddometer: 238
Not a problem with the tank. I swapped from the stock to the Safari, checked all the lines, filter is showing flow, and pump vacuum lines have no kinks. I popped the gas cap and the symptoms persist.
Bob in Monterey
Old 03-09-2014, 05:15 PM   #1948
dogsslober
dogsslober's Avatar
Oddometer: 905
Which fuel pump? stock, vacuum, facet? Sounds like it running it self out of fuel. Low float level maybe.
Old 03-09-2014, 05:18 PM   #1949
Monterey_BS
Oddometer: 238
Originally Posted by mousitsas View Post
Needles at?
1) Third position. I can't help but think that it has something to do with no thin shim washers under the needles; but as I said, it ran fine before w/o them. I'm in search of those now.
2) 50 to 70degF. That's kind of the way it is here on the Central Coast.
3) Yeah, sorry about that. Lean, but not overly so.
Bob in Monterey
Old 03-09-2014, 05:30 PM   #1950
Monterey_BS
Oddometer: 238
I'm running a vacuum pump and had similar thoughts. It does react similar to running dry. Next is to check with a Facet I've got lying around. It could be that, even though the vacuum line looks OK, it may not be pulling sufficiently. After that, it's the floats, although they were set just North of 3mm when I did the rebuild.
Bob in Monterey
Times are GMT -7.   It's 05:54 PM.
