Old 04-09-2014, 07:10 AM   #2026
JRod152
will work for tires
JRod152's Avatar
Oddometer: 339
Originally Posted by KTM450SX View Post
I like the look without the metal grab bars on the back but I use those a ll the time to drag the beast around.. I want to take them off but i use them all the time. how do you lift the back end up and push it around if you fall?
I have never really used the stock grab bars. Currently, without the rear mud flap & single side out, you can easily grab hold of the subframe just behind the rear number plate. This works great for a pick-up point or for using the center stand.
I'll ditch the center stand soon once I get the bracket fabbed up for my PMB sidestand.
Here are the "racks" I use when I am packing for camping or riding 2-up... I had it set up like a big pig, huh!! Now I'm trying to strip it back to what it was intended to be.
Berg was kind enough to make me a set of one-off bars that reasonably follow the lines of the rear of the bike. They give the SF a little more strength, offer good pickup points, offer passenger grab handles, and are great at keeping my GL bag from pressing on the plastic.
I picked up a 2 into 2 OEM collector for cheap a while ago and am thinking of going to shorty 2 into 2's... if so, the bars wont really be necessary and I can just use a heat shield on the exhaust.
We'll see... a work in progress. To each their own, I say.
"Never let the things you want make you forget the things you have"
JRod152 screwed with this post 04-09-2014 at 07:17 AM
JRod152 is offline   Reply With Quote
Old 04-09-2014, 08:16 AM   #2027
KTM450SX
Oddometer: 482
Nice
I just throw my giant loop on the back no racks no heat shields.. actually there may be some heat stuff inside the plastic i don't know if thats stock or if the previous owner put it there.
2014 KTM 500 EXC
2007 KTM 950 Super Enduro
KTM450SX is offline   Reply With Quote
Old 04-09-2014, 03:39 PM   #2028
KTM450SX
Oddometer: 482
Originally Posted by JRod152 View Post
Is that the rotewieller filter?
I have the same tank, can you get the filter off without pulling the tank?
was thinking of getting that filter, mine has the stock car airbox lol, and a oiled pre-filter.
2014 KTM 500 EXC
Old 04-09-2014, 04:18 PM   #2029
SpeedyR
SE in the SE
Oddometer: 948
The red tabs are more than likely from the SW7 filter kit but I'll let him confirm. But yes with the sausage filter you can reach in and remove the filter without removing the tank. I have the same setup. Helps to have rubber gloves on to keep the oil off your hands but certainly enough room for it all to go in and out.
SpeedyR is offline   Reply With Quote
Old 04-10-2014, 10:27 AM   #2030
JRod152
will work for tires
JRod152's Avatar
Oddometer: 339
Speedy's correct.
HERE is a post I wrote about it a while back.
With the stock or Safari tank, you can change the pre-filter or main filter w/o removing the tank. Granted, this is with the Rottweiler sausage filter... not sure about the ADV "non-domed" filter.
I love the filter system. With Ken's tank that I'm running now, I can't change the pre-filter quite as easy, but not far off. His tank is so quick to get off... 1 bolt, 3 fuel QD, fuel pump wiring, & its off. The other advantages if this tank are well worth it for what it offers, IMO.
Old 04-10-2014, 11:00 AM   #2031
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 252
Speedy's correct.
I've got the Motohooligan intake. The sock can easily be R&R'd. The filter can be removed w/o tank removal, but it's not easily accomplished. I've a similar tank configuration as you; but also, as you know, a frame-mounted vacuum fuel pump. For me it's three bolts, two QD fuel taps, and the low fuel sender. Probably five minutes max in either direction.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 04-10-2014, 12:29 PM   #2032
KTM450SX
Oddometer: 482
Cool thanks!
I have been emailing back and fourth with Chris @cpr/Rottweiler been really helpful.
I'll definitely be getting the sausage filter and the Jet kit. To many projects at this instant to drop $500 on all that right now though.
2014 KTM 500 EXC
Old 04-10-2014, 04:59 PM   #2033
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,114
Cool thanks!
Did you look here, might save you some $$
http://advrider.com/forums/showthread.php?t=870579
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is offline   Reply With Quote
Old 04-10-2014, 10:31 PM   #2034
KTM450SX
Oddometer: 482
Hadn't seen that one why is it so much cheaper and it looks exactly the same?
2014 KTM 500 EXC
Old 04-11-2014, 05:46 AM   #2035
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,114
Lots of discussion on that try here :
http://advrider.com/forums/showthread.php?t=928395
I believe the main difference is the the construction material of the baseplate.
I run Sporting Woods
'09 BMW R1200GSA
pizzaboy screwed with this post 04-11-2014 at 05:56 AM
Old 04-11-2014, 06:52 AM   #2036
JRod152
will work for tires
JRod152's Avatar
Oddometer: 339
Because it's not the same!
Old 04-11-2014, 07:51 AM   #2037
foroffroaduseonly
foroffroaduseonly's Avatar
Oddometer: 82
I just bought one of these and it needs a set of tires. interested to know what tires everyone is running? I plan on prob 50/50 on/off road. I was thinking of maybe those continental tkc80?
Sent from my DROID RAZR using Tapatalk 2
foroffroaduseonly is offline   Reply With Quote
Old 04-11-2014, 07:56 AM   #2038
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,476
What oil are you using???
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 04-11-2014, 07:59 AM   #2039
Monterey_BS
Oddometer: 252
This is a very dangerous question that takes us precipitously close to oil thread territory, but my take is...
Split duty: D606 Front/D908 Rear, although my next round will likely be a MotoZ or Mitas rear. I'm intrigued by reports out of the 690 community and others.
More on than off: D606 Front/Heidenau Scout (or something similar) Rear
Bob in Monterey
Old 04-11-2014, 08:00 AM   #2040
Monterey_BS
Oddometer: 252
Damn!!! Beat me to it, again!
Bob in Monterey
Times are GMT -7.   It's 01:09 PM.
