Old 08-31-2014, 08:50 PM   #2206
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Escondido, CA, USA, Earth, Milky Way, Local Group
Oddometer: 1,471
Originally Posted by LMSB View Post
If you dont mind me asking, who makes the after market light mount and where did you get it?
Here it is:
http://blackdogcw.com/black-dog-shop...ro-detail.html
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney is offline   Reply With Quote
Old 09-01-2014, 12:45 AM   #2207
pingvin
pingvin's Avatar
Oddometer: 536
Rack for 950SM fit 950SE?
Will this rack fit my 950SE?
http://shop.sw-motech.com/cgi-bin/co...ypid=149080376
2006 KTM 950 SuperEnduro
2010 KTM 530 EXC-R
2006 Suzuki RM-Z 250
1981 Husqvarna 420 AE
pingvin is offline   Reply With Quote
Old 09-01-2014, 07:08 AM   #2208
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 953
Rack
Yes that would fit the SE
dogsslober is offline   Reply With Quote
Old 09-01-2014, 08:39 AM   #2209
pingvin
pingvin's Avatar
Oddometer: 536
2010 KTM 530 EXC-R
Old 09-03-2014, 02:42 PM   #2210
Balsta
Oddometer: 400
Originally Posted by Boatman View Post
....I've had the suction pipe off before and don't recall seeing a check valve in the end that attaches to the oil tank but I wasn't looking either.
There is no check valve on the SE
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 09-06-2014, 02:59 PM   #2211
grant22
grant22's Avatar
Oddometer: 478
Hey guys, reassembly time and don't have my manual with me.
Green wire(s) on my VRR go to POS or NEG on the batt?
Thx in advance
grant22 is offline   Reply With Quote
Old 09-06-2014, 03:43 PM   #2212
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,074
Thx in advance
Neg
pfdskipper is offline   Reply With Quote
Old 09-06-2014, 04:06 PM   #2213
grant22
grant22's Avatar
Oddometer: 478
Glad I didn't assume.
THX
Old 09-07-2014, 07:46 PM   #2214
johnny2bad
Oddometer: 24
Tool Kit / Tire Iron
My new to me 2007 SE did not come with a tool kit.
I found the list of tools form the Hall of Wisdom and will start making one up. I need to get some tire irons anyway and am considering the motion pro t6 spoon type levers with the axle nut box wrench to keep on the bike.
Can anyone comment on these tire iron combo?
Do they store well on the bike? If so, where?
Are the correct sizes 32 mm and 27mm?
This probably a loaded question, but is there a cross reference for the oil filter? I've found a part number for a K&N but would rather use a Purolater or Wix and the KTM dealer is bit out of the way.
johnny2bad is offline   Reply With Quote
Old 09-07-2014, 08:45 PM   #2215
zeegman
zeegman's Avatar
Oddometer: 378
Motion Pro T6 Combo Tire iron box axle nut wrench
Just bought and tried out the 32mm T6 combo wrench on my 950 Adventure front and rear tire when it was cold even. Works awesome - does two things to save space and weighs very little. Get two or 3. No brainer investment. I think the Adventure and Super Enduro use the same axle nuts so 32mm but hopefully others can comment.
Desmog the bike and remove the rear canister and you will have a nice little spot to store the tire irons. I wrap the irons in a small shop rag to keep them from bouncing around. And you have a rag to put your tools instead of the dirt.
Mike Z
zeegman screwed with this post 09-07-2014 at 08:54 PM
zeegman is offline   Reply With Quote
Old 09-07-2014, 10:21 PM   #2216
DangerMoney
Oddometer: 1,471
Rear axle nut on my 2007 SE is 32mm.
Old 09-08-2014, 04:53 AM   #2217
oldfuddy
oldfuddy's Avatar
Oddometer: 658
950 Super Enduro "Quick Question(s)" Thread...
As mentioned earlier, plenty of room under the seat and in the tail section once you do the canisterectomy.
I found the tools (minus irons) fit perfectly in my son's old Playstation Vita carrying case. The case fits perfectly between the fuse blocks and doesn't need to be strapped down or held in place. And it's rugged enough not to get all torn up from vibration.
oldfuddy screwed with this post 09-08-2014 at 04:59 AM Reason: added pic
oldfuddy is offline   Reply With Quote
Old 09-08-2014, 12:45 PM   #2218
johnny2bad
Oddometer: 24
oldfuddy:
Do the axle nut wrenches in your pics serve another purpose as well?
What are the castleations for?
Old 09-11-2014, 01:55 PM   #2219
oldfuddy
oldfuddy's Avatar
Oddometer: 658
oldfuddy:
Nope, just the axels nuts. I currently carry large spoons and don't have a t6-type set up yet for this bike. When I do, I'll pull the stock axle wrenches out of the kit and ditch the spoons. Not sure what you mean by castleations, but if its the little craftsman bag that's all the hex, torx, and screwdriver bits that come in the stock kit.
Old 09-11-2014, 02:26 PM   #2220
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
Believe the SE has a 27mm front and 32mm rear if you buy spoons...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is online now   Reply With Quote
Times are GMT -7.   It's 02:54 AM.
