Old 09-07-2011, 05:47 AM   #706
markie_wales
Oddometer: 940
Originally Posted by mcmann View Post
Start with 25mm on the front and back off the rear shock tension by 12mm to lower the back . . . . unless he is very heavy.
Thanks for that. I think there is only 8mm of rear preload as standard, but will wind out what I can. Don't know his weight but he's not a biffer (if that word translates).
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
markie_wales is offline   Reply With Quote
Old 09-08-2011, 06:23 PM   #707
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,874
Originally Posted by pizzaboy View Post
Anyone using a G2 400 throttle tamer cam? Thinking one would be nice in the slow stuff if it works and not much downside.
Yep. It's handy with knobs, off pavement or on. It's mostly helpful when you're riding slow, bumpy rocky stuff. Prevents the inadvertent throttle inputs that make you go all Superman-like.
It does sometimes seem to take off a little too much of the edge, so I revert back to the 200 or 100 cam if I'm not doing technical stuff.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 09-09-2011, 05:02 AM   #708
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,510
I'm riding in Timor-Leste at the moment... heading into Indonesia and mainland Asia for a while. When I had the tank off just before I left Australia, to replace a stuffed pump, I noticed a leak around the fuel level sensor.
Sorry to ask the question without doing some more searching... but the net connection here is shitty .... but is there an easy fix, or a "get me along OK" fix? I asked the KTM mechanic at the shop I was working outside when I did the fuel pump and he gave me some "white snot" to put on it. Doesn't seem to have worked .... as I had dripping fuel for a while there today.
Any thoughts? Bear in mind, I'm weeks away from getting any spare parts sent in. Weeks and thousands of km....
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 09-09-2011, 05:20 AM   #709
pizzaboy
retiring tomorrow
pizzaboy's Avatar
Oddometer: 1,120
Thanks Stobie! Definitely don't want to lose the "edge" . So once you put on the G2 throttle tube you can just trade out the cam as needed?
'09 BMW R1200GSA
'09 KTM 950SER Erz 03/08 BD
'14 KTM 1190 Adventure R 03/14 BD
pizzaboy is online now   Reply With Quote
Old 09-09-2011, 05:35 AM   #710
markie_wales
Oddometer: 940
On my 990 adv the longest part of fitting was getting the rubber grip off the old tube and onto the new one. Changing cams would be a 5 min, one socket job if the grip is already on.
cheers
Markie
EDIT: 2 sockets if you need to remove a bar end hand guard etc :)
markie_wales screwed with this post 09-09-2011 at 05:51 AM
Old 09-09-2011, 11:31 AM   #711
Beer
950 SE
Beer's Avatar
Oddometer: 364
Originally Posted by DirtJack View Post
You should see his brand new 2012, 300 2-smoke. It's blue and yellow.
mines a 300 blue and yellow
loaded like a pack horse recently....
Size matters.....
http://950superenduro.com
Beer is offline   Reply With Quote
Old 09-09-2011, 02:35 PM   #712
jacmac
Oddometer: 32
950 se voltage regulator
Anyone else have problems with voltage regulator on 950 super enduro? Bike is an 2009 bought it from dealer in Feb. 2011 has less than 4k miles, still under warranty backordered till 11-1-2011. WTF!
jacmac is offline   Reply With Quote
Old 09-09-2011, 03:17 PM   #713
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,739
Yep I've seen multiple reports of regulator failure, usually starts with a whistling battery.
v8toilet is offline   Reply With Quote
Old 09-09-2011, 10:53 PM   #714
LanceSA
LanceSA's Avatar
Oddometer: 80
Yip. Mine blew up in December last year in Cape Town. Specialist motorcycle auto lec rebuilt it in a day. 100% since then.
Ktm 690, Wr 450f, Kdx200
Honda XR125L - wife & son
Pw 80 - other son
Never argue, never justify, never defend
LanceSA is offline   Reply With Quote
Old 09-10-2011, 10:46 AM   #715
triplenickel
triplenickel's Avatar
Oddometer: 2,430
Yeah it happens, consider relocating to a spot with more airflow.
07 SE
PG007
Old 09-10-2011, 03:50 PM   #716
wpbarlow
Oddometer: 11,510
Yes-- just replaced the one on my 2007-- 23,000 miles. Was intermittent for a couple of weeks.
wpbarlow is online now   Reply With Quote
Old 09-11-2011, 07:22 AM   #717
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,874
Yep, about 5 minutes, like Markie said. More of my time is spent removing/replacing the handguard.
Stobie
-Albert Einstein
Old 09-11-2011, 10:11 AM   #718
LoFlow
Oddometer: 998
Finally got a little ride in this evening and it wasn't over 100 degrees Appears that we've turned a corner for cooler weather now just some rain would be nice.
I thought about this while riding yesterday. For me, I get to many of those awkward, about to stall moments where I appreciate a quick reacting throttle input. And usually when I stall while standing I end up on the ground. But yes the ass end does step out pretty quickly with the stock cam. Please report back your experience with the new cams.
LoFlow is offline   Reply With Quote
Old 09-11-2011, 01:45 PM   #719
DirtJack
DirtJack's Avatar
Oddometer: 1,607
Nice bike! The one I was referring to had a yellow frame (and was made at the same factory). Now back to the original thread.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 09-12-2011, 10:19 PM   #720
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,298
Just noticed this today. I am getting a strange clicking noise from the steering. I can't believe the bearing could be bad, no movement in the triple on the stand. Looked for something cracked or showing wear signs. What else could it be?
2013 Super-10, 2007 KTM950SEr, 2006 KLR650
buildit is offline   Reply With Quote
Times are GMT -7.   It's 07:23 AM.
