Old 03-01-2012, 03:29 AM   #991
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,963
Originally Posted by The Bigfella View Post
My 950 SE is running lean - very lean... When I first connected the battery up, she pumped fuel for a while..... and then pissed herself on the ground ...
Lean or Rich
Stock Fuel Pump or the Notorious Flooding Facet that produces Way Way
Too Much Pressure ?? . . . . .
Brown Dog is offline   Reply With Quote
Old 03-01-2012, 03:43 AM   #992
Brown Dog
Brown Dog's Avatar
Oddometer: 1,963
Stock Jetting with Needles Raised by lowering Clip one position After
Desmogged works GREAT with my Akra's, from 600-6,000 ft above
Sea Level 35-95 degrees on my 950 SE
Richer Jetting may be needed ONLY if in real cold climates.
Leaner Jetting may be needed if in High Altitude.
Air cleaner & air box setup changes will also need to be considered
as I'm running bone stock.
Just my .02 cents
Originally Posted by LoFlow View Post
This and the cold weather performance is improved. Starts quicker and less choke time. This might not be an issue with the warmer climate guys but it's really nice on our damp, cold days around here.
Old 03-01-2012, 05:39 AM   #993
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,184
Oil filter access
Hello All.
I bought my SE used.
I've noticed that there are two oil lines that are in front of the oil filter, which will make getting the oil filter out difficult. I think the previous owner did this.
Can anyone post a picture of how these oil lines are supposed to be located?
I'm going to change this to make the oil change procedure easier.
Thanks in advance.
Q~
Old 03-01-2012, 06:51 AM   #994
The Bigfella
Big Adventurer
The Bigfella's Avatar
Oddometer: 2,494
Ahhh - a vacuum line. Interesting. I'll take a good look in the morning. Its funny, but here in the land of the motorcycles I couldn't find a bike shop to take me on with the KTM. I'll have an interpreter with me tomorrow... and don't shoot me, first stop is the Harley place. They aren't scared of big bikes
Stock fuel pump - a relatively new one, The other one shit itself on Cape York - we jury rigged fuel lines around the pump and got 1000km back to civilisatation and a new pump using gravity feed only
A man should only do the work that is required of him. To do more is a form of greed.
Ride through Oz and Asia
The Bigfella is offline   Reply With Quote
Old 03-01-2012, 08:10 AM   #995
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 2,043
Originally Posted by Questor View Post
Hello All.
Thanks in advance.
Q~
Try the Owners Manual:
Vee2 ADV "The Train", Wee2 "Muliti-tool"
NC7X "Commuter Xtraordinaire"
mcmann is online now   Reply With Quote
Old 03-01-2012, 08:40 AM   #996
Thisguy
Hold Fast
Thisguy's Avatar
Oddometer: 2,307
And they are not factory lines.
1986 R80RT
2000 Land Cruiser
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over." Hunter S. Thompson
Thisguy is offline   Reply With Quote
Old 03-01-2012, 09:54 AM   #997
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,184
Holy crap!
It looks like the oil lines are going to the wrong ports!
Outside bottom goes to top on my bike but the manual shows outside bottom to lower.
Q~
Old 03-01-2012, 05:48 PM   #998
The Bigfella
Big Adventurer
Oddometer: 2,494
Well, I've found some cracks in one of the vacuum leads, The one I tapped into to fit the Scotsoiler. I just taped it... haven't solved the backfiring problem yet though... there's obviously others I can't reach. I've bought some fuel hose from a local supplier - best I could get. Next step will be tank off, etc. My mate is running to Bali time. 9am has now turned into 11am. Beggars can't be choosers though.
Old 03-05-2012, 12:54 AM   #999
IDOC
IDOC's Avatar
Oddometer: 27
I have tried, without success, to use a 'normal' lift bike stand for my 950 SE. I broke the aluminum one and the steel ones that I have seem to either lift the front wheel off the ground, or the back wheel off the ground, but not both. On the few occasions it was off the ground with both wheels, it seemed very unstable. My question is what bike lift stand works best for the 950 SE?
IDOC is offline   Reply With Quote
Old 03-05-2012, 03:29 AM   #1000
Brown Dog
Brown Dog's Avatar
Oddometer: 1,963
I use an alum MX bike stand that holds the front
tire off the ground & a street bike rear stand that
fits the spindles I installed in the swingarm to
to hold up the rear tire.
Only time I use the MX stand is for front tire changing
Cause the SE is Too Heavy to lift
Old 03-05-2012, 03:33 AM   #1001
mousitsas
mousitsas's Avatar
Oddometer: 2,972
The center stand!
Old 03-05-2012, 02:45 PM   #1002
IDOC
IDOC's Avatar
Oddometer: 27
Thanks...I was hoping that there would be a magical lift stand that someone knew about that would easily and safely lift it off of the ground without having to install somthing on the frame or swingarm....or installing an eight pound center stand. Today, I saw a heavy duty stand offered at Harbor Freight that might work. I believe I read that it would hold a thousand pound street bike, but I am afraid that it would once again be unstable once I got it up in the air...Thanks for the input. You got me thinking.
Old 03-05-2012, 02:53 PM   #1003
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,665
Harbor freight, sears, and others sell this one-
It works well and the 950 is stable on it... Though it goes Just barely high enough.
BENRON is offline   Reply With Quote
Old 03-05-2012, 03:05 PM   #1004
spencergt66
Oddometer: 789
Pre Filter?
Just doing some maintenance on my SE Have a cleanable Air filter and its dirty. I got the bike not too long ago and am just now starting to go through some things. Can you run a uni pre filter on these with a Safari tank? Also is anyone rejetting for using a prefilter?
Next Item on the list is the frozen axle adjusting screw in the swing armI hate stuck/ broken bolts
spencergt66 is offline   Reply With Quote
Old 03-05-2012, 03:09 PM   #1005
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,291
I can lift the rear. But I just use an ATV lift like the one pictured above.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Times are GMT -7.   It's 06:51 PM.
