Old 06-05-2012, 12:27 PM   #1156
skopiec
Oddometer: 69
Did try normal and it seemed to have too much compression damping especially in the front. Also, on washboard, it seemed to be packing up - the bike had a slowing down sensation.
I've backed off on the compression on both ends, and it seems a bit better. I just thought I'd see what everyone else is using as a starting point - I have a habit of twisting dials until it's really screwed up! :)
Originally Posted by mousitsas View Post
Have you tried 'normal' settings and if yes, what is that you don't like?
skopiec is offline   Reply With Quote
Old 06-05-2012, 12:54 PM   #1157
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 861
Need to upgrade the seals and bushings, the stiction issues with these forks are the worst out there. The clickers can only do so much, the midtstroke damping needs to be addressed to eliminate the harshness as well. If your looking for just clicker settings, compression @ 23, rebound @ 18.
KTM offers the seals, wipers, and bushings for under $100.00, part number R14020.
I also offer bushings I had made for these 48mm forks as well.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports screwed with this post 06-05-2012 at 11:17 PM
Konflict Motorsports is offline   Reply With Quote
Old 06-05-2012, 12:58 PM   #1158
mousitsas
mousitsas's Avatar
Oddometer: 2,913
Stiff compression on the front is a problem on this bike. You have nothing to loose to try lighter oil in the forks, something like 2W
I would suggest to use normal (or sport) settings on the back, but reduce preload 2 turns or so and use sport settings on the front with the lighter oil.
mousitsas is online now   Reply With Quote
Old 06-05-2012, 01:25 PM   #1159
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,175
Originally Posted by spencergt66 View Post
Hey is there a way to put a factory tach on the SE? Also do these bikes have a revlimitter?
You can put a 950 Adventure Tach on the SE.
I was going to do it to mine but never got around to it.
If I remember correctly the Tach gets is signal from the #12 pin of the ECU.
Q~
Old 06-05-2012, 01:31 PM   #1160
Schannulleke
Oddometer: 209
Yes, 3 things:
- add a metal contact pin tot the correct slot in the connector going to the ECU. Don't know which number, just by memory. This provides the tacho signal.
- Look for a way to mount the tacho.
- Power the tacho via ACC2 (power when key on)
Schannulleke is offline   Reply With Quote
Old 06-05-2012, 11:20 PM   #1161
KM TUNER
Oddometer: 861
Its actually the mid-stroke damping on this bike that creates the harshness you are feeling, along with the stiction issues. I have mounted a go pro on a 950 with crash bars just to see how little the lowers were moving over 2 to 4 inch braking bumps on a forest service road, and the forks were moving maybe 1/2 inch at most going 50 to 80 mph. These forks have the same issue's as the smaller KTM's of this year.
I have replaced the bushings, and seals along with polishing the lowers on numerous bikes varying in displacment and with the feedback I have gotten back I am positive with my outcome.
The harshness can be eliminated and I can provide stacks for people who can complete there revalves if theres an interest.
Old 06-06-2012, 08:22 AM   #1162
spencergt66
Oddometer: 784
Q~
SWEET thanks
now to find a tach
spencergt66 is offline   Reply With Quote
Old 06-06-2012, 02:42 PM   #1163
wpbarlow
Oddometer: 11,122
Has anyone run an Adventure sized rear knobbie ( 150/70-R18 ) in place of the standard SE sized knobbie (140/80-18 )?
Any issues/comments?
I don't have any issues with the stock size- I just happen to have a brand new 150/70-R18 TKC which I don't think I'll be using on the 990.
tia
wpbarlow is offline   Reply With Quote
Old 06-06-2012, 03:18 PM   #1164
skopiec
Oddometer: 69
Thanks for the suggestions - heading out Friday for a Northern AZ run, so I'll get a chance to try out the new settings.
Old 06-11-2012, 06:18 AM   #1165
wpbarlow
Oddometer: 11,122
I don't have any issues with the stock size- I just happen to have a brand new 150/70-R18 TKC which I don't think I'll be using on the 990. tia
Thought I'd bump this-- anyone?????
Old 06-11-2012, 09:41 AM   #1166
skopiec
Oddometer: 69
I just finished burning off a 150 TKC on my SE (Only 900 miles!).
Seemed to work fine, but it does look a bit wide for the rim. Didn't really notice any handling or other issues.
Gonna look at the K60 next time for hopefully some better wear/mileage.
Old 06-11-2012, 04:55 PM   #1167
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,785
I have an '07 SE with Neduro ADV tank and of course 2-1 exhaust. The heat generated at the exhaust pipe union is intense and I think is detrimental to the rectifier regulator which is just above this union. Is there a way to relocate the rectifier regulator? Is this necessary? Is there a way to insulate the rectifier/reg ? Thanks for any suggestions.
jimmex is offline   Reply With Quote
Old 06-11-2012, 05:49 PM   #1168
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,741
http://www.advrider.com/forums/showthread.php?t=668132
v8toilet is offline   Reply With Quote
Old 06-19-2012, 08:02 PM   #1169
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,922
Can the SE front sprocket be changed without breaking the chain? Going back to a 17t for some long commuting......
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 06-19-2012, 08:13 PM   #1170
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,283
Yes, just undo it from the rear to give you slack.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Times are GMT -7.   It's 04:20 AM.
