Old 09-24-2012, 06:04 AM   #1381
Navin
Navin's Avatar
Oddometer: 7,812
I find that now I deleted my speedo/temp guage I obsess about temp alot less.
I used to pay too much attention to it, now I don't even think about it. It doesn't boil over, the fan cycles, all is well. You'd be better off to tape over the damn thing IMO.
Navin is offline   Reply With Quote
Old 09-24-2012, 11:42 AM   #1382
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
kiwi boot polish
Thanks for the tip. I will purchase some after work
Nice remedy for carbon fibre
LURKER
pepetrueba is offline   Reply With Quote
Old 10-01-2012, 10:24 AM   #1383
markie_wales
Oddometer: 933
After a little drop-sie-poos on Saturday the rear brake stop bolt sheared and the eccentric "washer/spacer" came off. The bolt broke flush to the frame, so I'll need to drill it out & re-tap, or maybe a left handed drill bit will do the business. I sort of treat this as a sacrificial bolt and not too worried it went.
Anyway, this got me to thinking, if I was on a long week(s) trip and this happened I would not be able to fix it on the trail. So is there any reason why I shouldn't drill it through with a 6mm drill and just stick a nut on the inside of the frame (although it might be a bit fiddly)? This way I could carry a spare nut, bolt and spacer in my tool bag and fix on the trial?
I know I've probably missed something obvious, but for the life of me I can't think what would be wrong about this.
cheers
Markie
EDIT bolt stub now out, so just wondering whether to replace as-is or drill through and stick a nut on a longer bolt?
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
- Only bikers understand why dogs like to stick their heads out of car windows.
markie_wales screwed with this post 10-01-2012 at 12:52 PM
markie_wales is offline   Reply With Quote
Old 10-01-2012, 04:43 PM   #1384
triplenickel
triplenickel's Avatar
Oddometer: 2,428
cheers
Markie
Seems like a good idea to me.
07 SE
PG007
Old 10-02-2012, 01:11 AM   #1385
MP5
MP5's Avatar
Oddometer: 253
I have a Wings Pipe, which has that black carbon type wrap around it. It had started to peel off before I bought it, and is now getting worse. (I assume because of heat).
Anyone else suffered this ?
Can I just buy new wrap....or will Wings replace it?
'08 950 Super Enduro
'10 RMX 450Z
'09 Ultra Classic
MP5 is offline   Reply With Quote
Old 10-02-2012, 03:32 PM   #1386
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,038
Finally got out for a few days riding in the Smokey mountains.
"Quick" question - do you use any throttle input when starting the bike cold? any difference when hot?
Old 10-02-2012, 03:40 PM   #1387
triplenickel
Oddometer: 2,428
Full choke cold with no throttle, a little blip when hot, WOT after a tip over and flood.
07 SE
PG007
Old 10-03-2012, 01:19 AM   #1388
wilso122
Oddometer: 183
Just my opinion but have a personal hatred for carbon end cans as they simply cant take the heat and degrade over time, seems twins eat them, same on the 900ss, tl100 and seen it on ADV's as well. They are great if you are racing and get them free but for most mortals with a budget go for titanium every time.
As for the rest I would ask Wings directly, but, cant see you getting much luck.
wilso122 is offline   Reply With Quote
Old 10-03-2012, 07:50 AM   #1389
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,038
Old 10-03-2012, 09:11 PM   #1390
triplenickel
Oddometer: 2,428
+1 My carbon Remus lasted all of about 6000kms before the rivets rattled loose for the end caps. They offered a replacement but said if I went with another carbon warranty was over, they offered a Ti as a replacement with normal warranty terms so that's what I ended up with.
07 SE
PG007
Old 10-04-2012, 07:09 PM   #1391
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,834
Question
need some help please
i have a slight miss at low revs (at idle it's ok) / it's just off idle @ about 50kph then it disappears as i get past 60kph & up.
bike sits in a shed at home
originally i thought it was plugs so replaced them no fix & moisture as the bike sat in a good days down pore at work - a month ago.
i've sprayed all areas with wd40 that i could think maybe were moisture would cause it.
last couple weeks its been good weather 25+ degrees celcius so no moisture should be left.
bike sat for 3 weeks untill my throttle cables arrived for my FCR's (snapped cable)
yesterday i sync my carbs & the miss is still there & i swapped plugs again cr8eix & cr8ek ? ? ?
any ideas guys
i'll be in & out of the house trying to sort this so i'll reply when i can. cheers
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 10-04-2012 at 07:31 PM
veetwo _tls is offline   Reply With Quote
Old 10-04-2012, 07:23 PM   #1392
DRjoe
DRjoe's Avatar
Oddometer: 5,092
Might be time to give your carbs a clean.
Old 10-04-2012, 08:21 PM   #1393
veetwo _tls
RENOVATIO:
Oddometer: 1,834
sorry i did not mention that in my post
yes i pulled the jets & blew them out , float bowls were clean also.
K&N filters cleaned & resprayed with oil.
one thing i did notice when doing my sync.
on the carbtune - as i SLOWLY open the throttle the front FCR carb opens/rod rises way faster than the rear FCR carb ?
BUT at the cables i have them adjusted so the slightest pull movement both FCR carbs are opening at the same time.
hope you guys understand what im saying.
at idle there fluctuating on the carbtune @ + or - 1cmhg of each other
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 10-04-2012 at 08:41 PM
Old 10-05-2012, 06:10 PM   #1394
ct_rider
Oddometer: 78
fuel light not working
For some reason my fuel light stopped working. I checked the connection at the front of the tank by the horn and it is solidly connected and isn't damaged. No fuses are blown.
Anything I should check for?
Leaving for a week long trip in a couple days and want to get this sorted as the fuel range is pretty terrible and I don't want to run out.
ct_rider is offline   Reply With Quote
Old 10-08-2012, 12:00 AM   #1395
randel
randel's Avatar
Oddometer: 315
Does anybody have a clue what can cause this?
I participated in two day-long motorcycle orienteering events during last month and both time had similar problems.
Bike runs just fine until suddenly it will not start anymore like battery has run out, relay only clicking or very slowly turning engine. After I got it started with the help from another bike, it runs fine again and I can start it like 15min after this has happened and no signs from weak battery.
Both times have been quite cold, +10...+15C and rainy, a lot of mud and water. Any hints, what can cause this problem? Weak electrical connection somewhere?
I use my bike for daily commuting and it runs fine again, no problems I am aware off, power is ok and fuel consumption also reasonable.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Times are GMT -7.   It's 12:44 AM.
