Old 10-08-2012, 05:04 AM   #1396
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,283
Originally Posted by randel View Post
Does anybody have a clue what can cause this?
I participated in two day-long motorcycle orienteering events during last month and both time had similar problems.
Bike runs just fine until suddenly it will not start anymore like battery has run out, relay only clicking or very slowly turning engine. After I got it started with the help from another bike, it runs fine again and I can start it like 15min after this has happened and no signs from weak battery.
Both times have been quite cold, +10...+15C and rainy, a lot of mud and water. Any hints, what can cause this problem? Weak electrical connection somewhere?
I use my bike for daily commuting and it runs fine again, no problems I am aware off, power is ok and fuel consumption also reasonable.
Bad Stator.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Old 10-08-2012, 05:46 AM   #1397
wilso122
Oddometer: 184
So it only happens when the bike gets hot on trails? You stop wait for it to cool down / battery to recover and its ok?
So maybe Regulator / Rectifier getting hot / clogged up / breaking down??
Or a bad earth?
wilso122 is offline   Reply With Quote
Old 10-08-2012, 08:21 AM   #1398
randel
randel's Avatar
Oddometer: 317
I haven't measured voltage yet, but while I use my bike daily, it's not low charging voltage (broken regulator) I guess.
Bike was at running temperature, not too hot (max 5 bars). It didn't start itself, I used wires to connect battery to another bike.
15minutes later it started itself without problems and is running fine after that. First time bike died when I started to brake on 3rd gear, second time was after I dropped bike while turning around (no speed, just lost my balance in slippery mud)
It's around +10C here and my bike sits outside all nights, no problems with starting in cold mornings, although I still have original battery (4,5 years, 46000km old).
I suspected bad connection somewhere in ignition circuit after ignition lock, but it happens so seldom, is it possible (twice within last month and 1000km)? Battery leads were tight, I have to check earth to frame yet.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 10-08-2012, 10:25 AM   #1399
TrentW
MMmmmm....
TrentW's Avatar
Oddometer: 87
Originally Posted by markie_wales View Post
So is there any reason why I shouldn't drill it through with a 6mm drill and just stick a nut on the inside of the frame (although it might be a bit fiddly)? This way I could carry a spare nut, bolt and spacer in my tool bag and fix on the trial?
EDIT bolt stub now out, so just wondering whether to replace as-is or drill through and stick a nut on a longer bolt?
Probs a bit late, but I've drilled through and used a longer bolt exactly as you describe after having the same thing happen to me.
I also carry a spare nut, bolt and spacer for trail side repairs.
I used a nyloc nut on the inside of the frame so it won't come loose.
No problems so far, but typically haven't had to use the spare since I did the mod...
TrentW is offline   Reply With Quote
Old 10-08-2012, 06:14 PM   #1400
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,956
950 SE canisterectomy & SAS removal
Im doing a buddys SE.
It's been so long since I did mine ... What are you guys doing with the 2 Extra carb vent hoses that come from the Brass 90 Degree Elbows on the carbs ??
These are the ones opposite from where the 10" & 11" vent hoses connects.
I read that their for venting the carbs in deep water crossings
http://www.ktm950.info/how/Orange%20...terectomy.html
http://home.comcast.net/~garrysimmon...er-Removal.htm
Im thinking I capped mine off, rather than running the tee'd hose up thru the Snorkle .... but I dont remember
I left the aluminum insert in the bottom of airbox, used a short 6mm bolt, fender washer & nut instead of epoxying the hole up
Help or pic appreciated
Brown Dog screwed with this post 10-08-2012 at 06:39 PM
Brown Dog is offline   Reply With Quote
Old 10-08-2012, 07:06 PM   #1401
Brown Dog
Brown Dog's Avatar
Oddometer: 1,956
Found it :
http://www.advrider.com/forums/showthread.php?t=423685
Plug em off
Old 10-09-2012, 12:46 AM   #1402
wilso122
Oddometer: 184
950SE dead battery!
Following a ride out on Saturday I went back to the bike last night, turned the key and absolutely nothing! No problems at all on Saturday. Got a car jump charger so put that on it and got the clocks to come up so the battery has completely and suddenly died.... Never had this on any bike I have owned in 20 odd years of riding... Any ideas why such a dramatic drain could happen?
Ordering up a new battery today...
Just a thought, what to people think of the shorai lithium battery, have heard some pretty mixed reports on them but interested in people running them on the 950SE? wet / cold weather in particular seeing as winter is here.
Cheers Wilso!
Old 10-09-2012, 02:04 AM   #1403
markie_wales
Oddometer: 938
Thanks h- good to know it worked OK. I ended up replacing "as-is" because with 4 years on an Adv and 2 years on the SE, I guessed it doesn't happen that much. If it goes again I'm drilling through!
cheers
Markie
- "Dad, when I grow up I want to ride motorbikes like you do." -------- "Son, you can't do both."
markie_wales is offline   Reply With Quote
Old 10-09-2012, 04:08 AM   #1404
mousitsas
mousitsas's Avatar
Oddometer: 2,911
Cheers Wilso!
It occurred to me too, a few months ago. Prior to that happening I could hear a hissing noise from the battery when turning the engine off. However, the very same battery is fine and dandy now after a few hours on the charger and meticulous topping up every few days when voltage drops below 12.75. It is the original yuasa battery and 3 years old.
Old 10-09-2012, 05:05 AM   #1405
Brown Dog
Brown Dog's Avatar
Oddometer: 1,956
...what to people think of the shorai lithium battery
My Shorai worked for 12 months & DIED
I don't believe their "advertised" Ah & cca ratings !!!
The weight savings isn't worth it when it WONT LAST IMHO
Go with an Absorbed Glass Mat (agm) battery
Ive had Fantastic service from East Penn Deka for many years in a variety of applications
Old 10-09-2012, 05:22 AM   #1406
wilso122
Oddometer: 184
Good to know, the more I read about them the more I don't like them when they are dead they are dead (and with the consumption of the SE that might not be long!), don't seem great in cold and damp.
Deka are hard to find here and got a good price on a replacement yuasa.
Old 10-09-2012, 07:36 PM   #1407
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
+1
And Sam's mart recently started carrying the same battery at a much reduced price
Old 10-10-2012, 11:41 AM   #1408
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
rusted SE spokes
I do have around four front wheel spokes that are rusted/lightly pitted
I use "flitz" metal polish to bring it up to luster and remove rust, but with time grow back up like fungus. Bike is stored in my work underground parking and bike is covered, so there is no humidity nor sea water spraying.
Bike has never been in rain nor mud, and consider myself a "weird one"
but if i ride it in dirt dirt,i use a cotton rag to clean it.
It has never ever been washed nor water has touched the bike, only cotton rag, maxima or honda plastic spray polish, flitz on metal and armour all. SO it does not make sense on how some spokes "pitted and rusted"
LURKER
pepetrueba is offline   Reply With Quote
Old 10-10-2012, 11:46 AM   #1409
CA Stu
CA Stu's Avatar
Oddometer: 47,644
Steering stem bearings - notchy steering
There are definite tight spots in the steering on my SE, binding and then releasing when turning the bars... Pretty disconcerting.
Anyone else have this problem on their SE?
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 10-10-2012, 12:48 PM   #1410
JustinT
I will ride my whole life
JustinT's Avatar
Oddometer: 955
Need steering stem bearings?
My other bike had a cog-wheel regidity as a result of steering stem bearings.
Full Throttle - it either solves the problem or ends the suspense
JustinT is online now   Reply With Quote
Times are GMT -7.   It's 11:03 AM.
