Old 10-10-2012, 12:41 PM   #1456
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
rusted SE spokes
I do have around four front wheel spokes that are rusted/lightly pitted
I use "flitz" metal polish to bring it up to luster and remove rust, but with time grow back up like fungus. Bike is stored in my work underground parking and bike is covered, so there is no humidity nor sea water spraying.
Bike has never been in rain nor mud, and consider myself a "weird one"
but if i ride it in dirt dirt,i use a cotton rag to clean it.
It has never ever been washed nor water has touched the bike, only cotton rag, maxima or honda plastic spray polish, flitz on metal and armour all. SO it does not make sense on how some spokes "pitted and rusted"
LURKER
pepetrueba is offline   Reply With Quote
Old 10-10-2012, 12:46 PM   #1457
CA Stu
CA Stu's Avatar
Oddometer: 47,107
Steering stem bearings - notchy steering
There are definite tight spots in the steering on my SE, binding and then releasing when turning the bars... Pretty disconcerting.
Anyone else have this problem on their SE?
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 10-10-2012, 01:48 PM   #1458
JustinT
I will ride my whole life
JustinT's Avatar
Oddometer: 950
Need steering stem bearings?
My other bike had a cog-wheel regidity as a result of steering stem bearings.
Full Throttle - it either solves the problem or ends the suspense
JustinT is offline   Reply With Quote
Old 10-21-2012, 02:19 PM   #1459
Baharaider
Irtractors
Baharaider's Avatar
Oddometer: 42
Are the 690 and 950se rear suspension intrechangable?
Anybody know if the mounting points measure the same on the 690 and 950? Wanting to mount a sno-track kit on my SE but no fit-kit for the SE only the 690. Thanks
Baharaider is offline   Reply With Quote
Old 10-21-2012, 06:52 PM   #1460
Pitster
miniac
Oddometer: 348
Not the same, I talked to a few guys on a snow track last winder as well. So far nobody has a kit that I know of.
www.pitsterpro.com Pitster Pro, Mini Bikes, Pit bikes and Play bikes, Side x Side, ATV
www.nomadrider.com Adventure luggage and gear
Pitster is offline   Reply With Quote
Old 10-22-2012, 11:49 PM   #1461
karinjtimoyht
Oddometer: 12
I am getting a strange clicking noise from the steering. I can't believe the bearing could be bad, no movement in the triple on the stand. Looked for something cracked or showing wear signs. What else could it be?
karinjtimoyht is offline   Reply With Quote
Old 10-23-2012, 01:46 AM   #1462
georgedaman
Oddometer: 123
Originally Posted by randel View Post
Does anybody have a clue what can cause this?
I participated in two day-long motorcycle orienteering events during last month and both time had similar problems.
Bike runs just fine until suddenly it will not start anymore like battery has run out, relay only clicking or very slowly turning engine. After I got it started with the help from another bike, it runs fine again and I can start it like 15min after this has happened and no signs from weak battery.
Both times have been quite cold, +10...+15C and rainy, a lot of mud and water. Any hints, what can cause this problem? Weak electrical connection somewhere?
I use my bike for daily commuting and it runs fine again, no problems I am aware off, power is ok and fuel consumption also reasonable.
Something similar happend to me as well.esp after water crossings.
I''ll check the side stand sensor on mine.
georgedaman is offline   Reply With Quote
Old 10-23-2012, 01:53 AM   #1463
randel
randel's Avatar
Oddometer: 315
I finally managed to check my bike last weekend and discovered faulty regulator/rectifier - voltage went up to 17V, this probably killed battery after few hours of riding. Also first connection after ignition lock was corroded - one pin was greenish color, I cleaned that also.
I hope I found cause for my problems.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 10-23-2012, 11:19 PM   #1464
CA Stu
CA Stu's Avatar
Oddometer: 47,107
Quick question: Where is the best place to get a set of supermoto wheels for this beast?
Quite liking the SE right now, thinking a set of good road wheels might get me some extra shop space...
Old 10-24-2012, 10:05 AM   #1465
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,677
Warp 9?
traveltoad is offline   Reply With Quote
Old 10-24-2012, 11:53 AM   #1466
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,441
You want Cheap ? or Good ? Ya cant have both at the same time .
Warp 9 are OK , I have 2 sets for XR's , the break spokes some of the time for no reason , if money is an issue , well then go for it ,
Otherwise , get ya a set of Talon on Excels , or something on stock Hubs ,
Woodys here does that , Try KSR wheels . Keith is a good guy to work with ,
I just dont know if I would put Warp 9's on a 100 hp+ machine .
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 10-24-2012, 12:42 PM   #1467
Dan950ser
NW Shredder
Oddometer: 402
Woody's wheels. Buy the good stuff for this much power.
2007 KTM 990 SuperDuperEnduroR
2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 10-24-2012, 09:25 PM   #1468
max2
max2's Avatar
Oddometer: 217
High quality custom wheels at an afordable price...tons of color options and hub/rim combos. He's a great guy to work with
http://www.fasterusa.com/ecommerce/s...eelsets/ktm950
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 10-25-2012, 10:17 AM   #1469
CA Stu
CA Stu's Avatar
Oddometer: 47,107
And local to me, too! Thanks!
Old 10-30-2012, 09:37 AM   #1470
fastdirt505
Oddometer: 70
Jetting for the CPR filter
I just ordered the CPR Rottweiler from KTM Twins and need to know what jets to use. I made the mistake of ordering it online without researching it first.
Edit: I cancelled the order and just went with CJ designs. So, I got the jet kit with the CPR and Stacks as a package. Now that's what I'm talking about.
Brian
Erzberg SE 950R and a KTM 250SX
http://www.youtube.com/fastdirt505
fastdirt505 screwed with this post 10-30-2012 at 11:06 AM
fastdirt505 is offline   Reply With Quote
Times are GMT -7.   It's 02:50 PM.
