Old 11-21-2004, 05:01 PM   #61
dirtrider
Dusty Adventurer
dirtrider's Avatar
Oddometer: 3,298
Originally Posted by creeper
I can't even begin to imagine how you could do that... unless of course you were trying to start it with your hand. Don't laugh, I used to show off how good I could tune a Shovelhead by kick starting it with my hand.
I was a lot dumber back then than I am now.
Welcome back Creep. It was lonely without you.
2013 Husky TE511
2012 KTM 350 XC-F
2001 KTM 640 LC4 Sold
2009 KTM 300 XCW Sold
I only like two kinds of women, foreign and domestic
dirtrider is offline   Reply With Quote
Old 11-21-2004, 07:50 PM   #62
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,892
Originally Posted by Stobie
Anybody done the mainshaft bearing swap on one of these things? I just completed it Friday after messing with it a little every night since last Sunday. It finally required pulling out sections of the bearing cage so I could make stouter hooks, then heating up the case, then several shots with a 10 pound slide hammer. The PVC pipe puller did not work.
Getting that bearing out was a major bitch.
On the upside, there is less bottom end noise, but I'm still gonna line the skidplate.
PVC cracked? Heads on modified bolts bent? Filed incorrectly? How did you use the slide hammer? What attachment?
20 questions, but I finally have time and desire to do this swap. Thanks!
Line the skidplate with what? Lead?
Reticulated foam?
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 11-21-2004, 07:51 PM   #63
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Only to give you the warm fuzzys dirt.
creeper is offline   Reply With Quote
Old 11-21-2004, 07:55 PM   #64
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Mallory metal
Old 11-21-2004, 11:27 PM   #65
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
Reticulated foam?
There is a bearing puller listed in the 2003 640 ADV parts fiche under special tools. I have not been able to determine if it is the proper puller for this bearing, but if it is, it would seem to be a great tool for this group, I would be willing to buy it, and then pass it on to the next guy for a very small fee plus shipping...... Just need to determine if it is the proper tool.
Navigation: Main Catalog 2003 640 LC4 Adventure
Component: SPECIAL TOOLS 640 LC4
Manual: 320899, Page Number: 03584290
Item Part Number Description Retail
16 15112018000 INTERN.BEAR.PULLER 12-16 MM $80.00
16 15112018100 INTERN.BEAR.PULLER 18-23 MM $80.00
http://216.165.194.66/munnracing/catalog/catalog.cfm
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack is offline   Reply With Quote
Old 11-22-2004, 05:17 AM   #66
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,762
Send a message via AIM to Stobie
Here ya go, Rapiti
PVC cracked?
Yep. Switched to galvanized pipe, then...
Yep.
Filed incorrectly?
Nope. For instance, it took four shots with the slide hammer to straighten them, shots that had the bike going "skrooot" across the concrete. Or maybe that was me.
I made some more hooks (from Grade 8 1/4"-20 x 4-1/2" bolts, as used before), leaving the hook at the full thickness of the bolt head. Fitting these into the bearing required that I remove sections of the bearing cage to make more wiggle room. I then screwed 1/4"-20 threaded shackles onto the bolts, and bolted the shackles to a standard puller jaw attachment that had been welded to the end of the slide hammer I borrowed. Then, 20 minutes with a 1500W heat gun, and it still took 4 shots to get the bearing to budge. The new bearing took quite a bit of force to install, even with it being frozen and the engine case still being warm. I'll try to take some pics of the tool this evening before I return the slide hammer.
Adhesive-backed cork, prolly 3/8" thick, unless that's too thick, then I'll use 1/4" thick stuff.
Good luck with the swap. It ain't much fun.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 11-22-2004, 08:13 AM   #67
dirtrider
Dusty Adventurer
dirtrider's Avatar
Oddometer: 3,298
Thanks, I feel warm and fuzzy all over.
I woke up this morning to 2 inches of snow on the ground I might have to put the LC4 away after all. I was able to put 700 miles on it since Loaded put his away though.
2013 Husky TE511
2012 KTM 350 XC-F
Old 11-22-2004, 01:24 PM   #68
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Awwww, slap a ski on the front and a paddle tire on the back and go like hell!
Old 11-22-2004, 02:28 PM   #69
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,839
thanks Arch.
aw heck dirty, you gots you some Snow Hawks... I don't have one ounce of pity for ya!
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-22-2004, 02:32 PM   #70
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
No no no....the ski yes, the bottom half of a snowmobile... No. Bigass paddle tire yes. This is a low budget (it's me afterall) project.
Old 11-22-2004, 02:36 PM   #71
dirtrider
Dusty Adventurer
dirtrider's Avatar
Oddometer: 3,298
That's true. The snow hawks are pretty fun. I also have this for some winter fun.
The only problem is the fact that there is enough snow on the ground to not be able to ride the bike, but not enough to have fun with the snowmobile. We need 2 feet or more to cover the rocks and stumps and be able to ride off of the road, so right now, I can't have fun with either.
2013 Husky TE511
2012 KTM 350 XC-F
Old 11-22-2004, 02:39 PM   #72
dirtrider
Dusty Adventurer
dirtrider's Avatar
Oddometer: 3,298
I put my sand paddle on the back of my EXC last year and tore around in the snow. It's amazing how well it works. Even better are the Trelleborg studded tires. My best freind has a set and we ran them last year on his 525 EXC. They were incredible and worth every penny.
2013 Husky TE511
2012 KTM 350 XC-F
Old 11-22-2004, 02:41 PM   #73
Buckster
Buckster's Avatar
Oddometer: 1,003
You are a cheap date Creep.
Buckster is offline   Reply With Quote
Old 11-22-2004, 02:41 PM   #74
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Yea buddy ... watch out for the fresh powder though.
Old 11-22-2004, 03:04 PM   #75
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
That's what my wife says too. But the cheaper the date, the more cash for toys.
About 15 years ago, there was a guy back in California that made a ski adaptor he sold for about a 100 bucks. Then al you needed was a snowmobubble ski, a paddle or studded tire and you were in business. About 350 bucks to go play in the snow.
Yea, it wasn't a snowmobile but it was fun... as soon as you remembered to turn left to go left and so on. Like a Jetski, the first half hour you fell over alot.
Times are GMT -7.   It's 04:09 AM.
