Old 06-21-2010, 12:16 PM   #1
Barnacle OP
Lurker Extraordinaire
Barnacle's Avatar
Oddometer: 27
Missing Bolt or Not?
Not sure if this bolt is supposed to be missing? Should there be a one here?
Thanks for answering this as I don't have the reprom quite yet...
Regards,
Barnacle
Barnacle is offline   Reply With Quote
Old 06-21-2010, 01:53 PM   #2
m0ng00se
Oddometer: 10
Regards,
Barnacle
Mine looks exactly the same ... not sure why it's there !
m0ng00se is offline   Reply With Quote
Old 06-21-2010, 02:51 PM   #3
Barnacle OP
Barnacle's Avatar
Oddometer: 27
Thanks muh bro! Makes me feel a bit better.
Just wondering if other folks are noticing the same...
Old 06-21-2010, 04:42 PM   #4
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
No, that is used to hold F800ST lower faring bracket.
Beemers Uber Alles
9248 Mike Garcia Drive
Manassas Va 20109
(571) 318 2472
Indie BMW Maintenance
www.beemersuberalles.com
GeorgeinVA is offline   Reply With Quote
Old 06-21-2010, 06:35 PM   #5
GSJon
GSJon's Avatar
Oddometer: 1,630
I noticed that on my F650GS the other day too. Thanks for reminding me and saving me the time to ask.
Jon
ADVMax: BMW's do not break down - they fail to proceed.
GSJon is offline   Reply With Quote
Old 06-22-2010, 08:26 PM   #6
blender
Just another rider
Oddometer: 727
I suspect BMW put it there simply to cause confusion and collect dirt and dust. I predict that BMW will, within a year, issue a voluntary recall to fit a covering bolt to "fill" that bolt hole. That "cover" bolt will also be available through the BMW Accessory catalogue, of course it will have The Roundel emblazoned on it.
Further prediction: Within another year BMW will be forced into a NTHFS recall mandating an oversized, reinforced bolt to prevent unintentional bolt-backing-out issues. Those will be installed by high school shop classes, since we have no where else to employ them.
Of course, BMW could simply have plugged the empty bolt holes with a rubber plug (then again the Interwebs would be asking "what is THAT plug for?). I'll have to check my F8GS and see if it has the same; never really looked. But I do have A Big Hammer and several rubber plugs. Or bolts.
Steve
Madison, WI
blender is offline   Reply With Quote
Old 06-23-2010, 10:46 AM   #7
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
This will be after several months of denying the issue then blaming it on rider error and too much ethanol/water in the gas.
No no no! This 10cent solution would add hundreds off dollars to the msrp and several ounces to the weight.
Beemers Uber Alles
Manassas Va 20109
(571) 318 2472
Old 06-23-2010, 12:25 PM   #8
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,230
You can probably order a special filler bolt from Touratech for the low price of $19.95.
MCMXCIVRS is offline   Reply With Quote
Old 06-23-2010, 11:25 PM   #9
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
There is one on the other side too. Both bolts have vibrated out of my F800ST fairing bracket.
EJ_92606 is offline   Reply With Quote
Old 06-24-2010, 01:43 AM   #10
ShaunJ
Oddometer: 54
Theres also some unused bolt holes on the front of the engine if you look up behind the rad
ShaunJ is offline   Reply With Quote
Old 06-24-2010, 02:22 AM   #11
Scapadu
Motomaniac
Scapadu's Avatar
Oddometer: 839
They just anticipated the "Turbo option" add-on capability
Time is not a test for truth.
"I've always been mad, I know I've been mad, like the
most of us...very hard to explain why you're mad, even if you're not mad..." N.M.
Visit Corsica Corsica Photo
Scapadu is offline   Reply With Quote
Old 06-24-2010, 03:23 AM   #12
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
Very common, some blue loctite on the new ones and they will stay put. Don't forget the washer they goes under the bracket.
Beemers Uber Alles
Manassas Va 20109
(571) 318 2472
Old 06-24-2010, 05:57 AM   #13
BykMyk
Oddometer: 262
It's for the Flux Capacitor!
Nobody gets out alive....
BykMyk is offline   Reply With Quote
Old 06-24-2010, 11:25 PM   #14
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
thanks....I'll ask the dealer if they can replace...not sure if I have a tool that can fit in there to tighten the new ones.
Times are GMT -7.   It's 07:28 PM.
