Old 06-22-2010, 04:23 PM   #1
OlyRider OP
Oddometer: 1,256
Forks are off: *Now* I need help!
OK, I thought I had enough info to go ahead and install my Hyperpro fork springs, but apparently not.
I've drained the fork legs. Now I need to put the correct amount of oil in them. (120mm from the top). But does *top* mean the top of the gold outer tube...or the chromed inner tube? (There's a difference in height, you know!)
Also, the Hyperpro instructions read to me like I'm not supposed to have the springs installed when I make this measurement. Is that correct? Put in the correct amount of fork oil, then put the Hyperpro springs on, tighten the cap over them, and re-install on the bike?
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 06-22-2010, 05:05 PM   #2
itsforrest
Ugly bag of mostly water
itsforrest's Avatar
Oddometer: 330
From top generally means the top of everything, top of the outside tube with the forks fully compressed.
Yes, measure the oil level before installing the springs.
Put in the oil, pump the fork all the way a few times to get the bubbles out, then install the springs.
The urge to buy terrorizes.
itsforrest is offline   Reply With Quote
Old 06-22-2010, 05:17 PM   #3
David_S
David_S's Avatar
Oddometer: 1,130
Looks like it's from the top of the tube itself
bikeless
David_S is offline   Reply With Quote
Old 06-22-2010, 07:21 PM   #4
OlyRider OP
Oddometer: 1,256
fork springs
Thanks!!!
After a trip to the bicycle store to get a 13mm cone wrench, I was good to go!
Now for the test ride.
Olyrider
Ob-la-di...Ob-la-da
Old 06-23-2010, 10:58 PM   #5
Waino
Waino's Avatar
Oddometer: 51
Olyrider, You will love them. I just put mine in last week. Best bang for the buck out there.
Waino is offline   Reply With Quote
Old 06-24-2010, 11:22 PM   #6
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
+1
Times are GMT -7.   It's 07:38 PM.
