Old 05-23-2011, 05:22 PM   #121
melville OP
melville's Avatar
Oddometer: 1,495
Originally Posted by melville View Post
Also this afternoon, I think I may have figured out what's up with the headlight. It occurs to me now that the dip switch has full power running through it and that it is itself the switch for high and low beams, unlike my newer VWs which use a dimmer relay. As well, there are two yellow wires coming from the switch--one brings power in from the relay and one sends it out to low beam. As much as I can tell, if they are transposed I should get the sitch I have now, which is "passing light only."
No, it wasn't that at all. The passing beam takes its power from the red (always hot) wire that goes directly to the dip switch. It was getting no power from the relay. The light relay was doing everything it should EXCEPT power up terminal #87. Searching out a new light relay to check now.
I may have issues with the dip switch, in that it does not hold high beam. I presume that there should be a detent to hold low or high, with passing beam available momentarily. The switch does not hold high beam, but springs back to low. I'm not too concerned yet, as my contract stipulates that I am to be a daytime only rider (and I'm OK with that).
A wide shot mit the tank on to keep me inspired:
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is offline   Reply With Quote
Old 05-23-2011, 07:39 PM   #122
The Killstar
Ted Simon Acolyte
The Killstar's Avatar
Oddometer: 312
That is going to be a beautiful bike. I've never noticed how those old boxers just hang on the frame. Looks kinda goofy with all the line and cables unattached.
Watch out for snakes! - Crow T Robot
2000 Honda Sabre (Sold)
2010 Triumph T100 Black
"Absolutely! If we didn't like visually beautiful bikes we'd all ride V-Stroms or something." - Av8rPaul
The Killstar is offline   Reply With Quote
Old 05-28-2011, 05:07 PM   #123
melville OP
melville's Avatar
Oddometer: 1,495
More electrical voodoo! Trying to get my instrument/idiot lights to do their thing. When I made it run a couple years ago, some of them worked. When I put it back together, nothing lit up anymore. So after checking that I had the right signals coming to the plug, I went inside the instruments to see what was up. Most of the contacts inside were corroded where the copper film inside the flexible thingy met the contacts on the bulb holders. All the bulbs were still good after cleaning (sanding) the bulb holder contacts, but I could only get continuity on a few of the runs in the flexible thingy. Cleaning helped a couple, but hurt a couple more. The contact on the right has just had a few strokes of 600 grit paper, and it has lost the copper right where it makes contact with the bulb holder. I may try to solder some wires into it, but most likely I'm going to bend over and spend the $$ to get a new flexible thingy while they're still available.
Speaking of soldering, is that the preferred method of getting the coil-end contact onto the HT spark plug leads? Any tips that you, my friends of the innerwebs, may have would be highly appreciated.
Old 05-28-2011, 07:38 PM   #124
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
I see no mention of SnoBum anywhere. Do yourself a favor and take the time to review in gross detail all relevant sections of this site>>>>>
http://bmwmotorcycletech.info/techindex.htm
Great project.
DoktorT is offline   Reply With Quote
Old 05-28-2011, 08:12 PM   #125
melville OP
melville's Avatar
Oddometer: 1,495
Great project.
Gross Detail? Yowza!
I've seen bits of Mr. Bum's site before but not the WHOLE THING AT ONCE.
Oh my.
Old 05-30-2011, 12:08 PM   #126
e28rusty
Fool
e28rusty's Avatar
Oddometer: 82
I can only dream of ever having a fraction of the patience you're putting into every nook and cranny on this bike. It really is looking awesome.
I've been fighting with my idiot lights too, and I actually just gobbed some solder on the film where it was cracked, not graceful or pretty, but most of my lights work again :) I've learned to live without a "fern light" indicator.
I can't wait to see the finished product.
e28rusty is offline   Reply With Quote
Old 05-30-2011, 12:54 PM   #127
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
I got a T-2 too, a 72. It's now confirgured for tool shed duty to service the Airhead since I don't have a shop anymore. I do love simple, easy to maintain vehicles. Need to do ANYTHING, reconfigure the T-2. Need to blow out the cobwebs from your cranium, enter the RS.
Old 05-30-2011, 05:35 PM   #128
melville OP
melville's Avatar
Oddometer: 1,495
Thanks! I can wait, but only enough to get it right.
Yeah, I'm going to try to foodle with the existing flexicircuit thingy but I expect $$ will be leaving my pocket.
Old 05-30-2011, 05:37 PM   #129
melville OP
melville's Avatar
Oddometer: 1,495
Yeah, not too much cranium cobweb blowing with my 50 hp '71 Kombi, which got all my mechanical attention today for a valve adjust and oil change.
Old 06-01-2011, 04:41 PM   #130
melville OP
melville's Avatar
Oddometer: 1,495
Slayed a wee electrical dragon today--set the static timing, then cranked it and open-fired a plug to check for spark. Sparks were in the yellow-to-blue range, which is just fine with me given the state of the battery.
I think I'm on the verge of a breakthrough as regards the headlight and its relay and the dipswitch. If it works, it will be the slickest thing I've ever coaxed out of this voodoo electricity. More to come this weekend.
Old 06-04-2011, 06:13 PM   #131
melville OP
melville's Avatar
Oddometer: 1,495
Here it is the weekend. Y'all can get off the edges of your chairs, and stop holding your breath. I realized that in addition to having no power to the headlight that my dip switch was not functioning. It would not hold the high beam position. As a new left side switch runs nearly $200, and the other functions of the switch were just fine, I thought about how I could get high beam with just an intermittent signal from the switch. Then I drove the Kombi to go surfing before dawn one morning and I realized that VW had solved my problem 40 some years ago. Voila, a 1971 VW dimmer relay:
And here's the schematic:
So on this one, hot comes in at 56 and goes out to 56a or 56b. The choice of where it goes changes each time S is momentarily connected to ground. S (the switch circuit) gets its hot also from 56.
Unfortunately, this relay came from my junk pile. It stuck once and shorted inside, taking out my last German voltage regulator. So I went to my VW FLAPS and scored a new one, just $30:
The part number is slightly different, and it's intended for later WCVWs so there's a tiny functional difference. Also note that it's from Siemens/VDO, which makes me smile every time I think of VDO's aftermarket ad campaign from a while ago, "Help Spread VDO!" Clearly it's now, "Help Spread VDO with Siemens!" I'll be just a minute ROFL.
And I'm back. The schematic is different:
The switch circuit needs its own hot, coming in at 30. No big deal, as I can piggyback on the headlight hot, and it will function just like the earlier one.
I try where I can, when I'm wiring stuff in, to match the DIN wire color. To make this one go, I needed yellow to go from 56a (low beam) to the junction board, and white to go from 56b (high beam) to the junction board. I also needed yellow/white to go from the main light relay to 56 on the dimmer relay. I didn't want to chase down a funky wire when I only needed a few inches, so I made my own yellow/white:
It worked a trick:
Wiring was like so: New yellow/white from 87 on the light relay to 56 on the dimmer relay. New yellow/white piggybacked from 87 on the light relay to 30 on the dimmer relay. New white from 56a on the dimmer to 56a on the junction board. New yellow from 56b on the dimmer relay to 56b on the junction board. I then connected the yellow/white from the dipswitch to S on the relay, and the white from the dipswitch to a spare ground on the circuit board. The yellow and red wires from the dipswitch are not used. They are taped up and put out of the way.
The wiring works great--just a push up on the dipswitch takes it from low to high, and the indicator light should work as I have power to the appropriate pins in the instrument plug. The next push up takes it right back to low beam. I'm having some issues getting the headlight to mount to this crowded shell. I may have to relocate the dimmer relay under the tank, in the space made available by the recent starter and horn relay work.
Old 06-05-2011, 05:03 PM   #132
melville OP
melville's Avatar
Oddometer: 1,495
So there's just no getting that new dimmer relay outta the way of the actual headlight:
I'm going to have to build a wee bit o' harness and stick it under the tank.
So after I found that out, I went to have fun with gorilla snot while the sun was out today. The stuff:
Snot applied:
Clamped:
And all mounted up:
Old 06-08-2011, 04:32 PM   #133
melville OP
melville's Avatar
Oddometer: 1,495
Those pesky electrons are going where I tell them, dammit! Got the dimmer relay relocated today.
I wanted to use proper wiring harness style loom, and when I went to look for it Monday, I got shot down everywhere. The auto electric shops were all, "Yeah, I know what you want but I ain't got it." NAPA was the same. The HD shop is open on Mondays after Memorial Day, and they sold me 48 cents of shrink wrap tubing, saying "It oughta do it" when I described the application.
Not completely happy with all that, I stopped by my local airhead guy's shop when he was open on Tuesday, and he was all "What size and how many feet?" He had the genuine stuff, and I felt much better about my prospects on this job. My local airhead guy is an inmate http://advrider.com/forums/member.php?u=8619 and an altogether nice guy. Here's his shop, if you are ever coming through here: http://www.northcoastcycle.com/aboutus.html
The job--I started by making a bracket to hold the relay:
Then I got the wires into the loom, marked DIN style so I knew which was which (I used 2 cents worth of the HD shrink tube on each end of the loom):
Then got it all mounted and wired up:
Ta Da! The headlight now fits, and has high and low beam at the touch of a button:
And a couple wide shots, one with the tank on to make sure everything fits:
If I'm up early enough, I'll check the aim of the headlight.
Old 06-11-2011, 08:12 PM   #134
melville OP
melville's Avatar
Oddometer: 1,495
Fun mit metal today! Stock, my bike had a remote choke lever, which is actually on the motor, just behind the rider's left knee. It pulls a coupla cables which terminate at a pinch bolt on each carburetor, like this one:
Now a pinch bolt is something quite familiar to me from my past life as a bicycle mechanic. As the cables needed replacement anyway, I wondered about how I might make the choke controls special or distinctive. I remember one guy on the old Boxerworks forum, probably Chuey, had made some out of old bicycle spokes. I have plenty of those! Here's 32 of them, only 20,000 miles:
Now the first battle is to make a handle, one that I can operate mit moto gloves on:
Then, to make it lollipop shaped:
Now it was time to make the loop solid. I tried some of the limited hot metal methods available to me, and none of them would take:
So I ended up getting some 1/8 SS .028 wall tube and making crimps out of it, reinforced with mucho JB Weld:
Drawing it down:
And all done:
And mounted, with moto glove test:
Now the more observant of you might notice that the carb in these pictures is somewhat crusty. You might be asking yourself, "How could melville stand to have such crustiness in his life?" Well, I'll tell you--it disturbs me very much, but the first thing I did on this bike was rebuild the carbs from a box of loose parts, before I started the bling-a-thon. Looking at them now, I could spend the whole summer getting them up to my standard, or
I could just bling the tops and bowls for now, and come back for the bodies the next time I rebuild them. Here's the quickie result:
There's a lot of casting flash, and the deeper question of whether or not "BING" stays on the tops after the polish goes final. But that's for another day.
Old 06-11-2011, 08:58 PM   #135
Mr. Vintage
Family Dude
Mr. Vintage's Avatar
Oddometer: 867
Looking good!
- Jeff (Mr. Vintage) -
Quota, SL350, MW250, MT250, CT90
Mr. Vintage is offline   Reply With Quote
Times are GMT -7.   It's 09:50 PM.
