Old 06-24-2010, 08:40 AM   #1
RobStar OP
Still On Training Wheels
Oddometer: 436
Is 2010 GS Gas Cap Reversal Possible?
It seems odd that the gas cap on my 2010 GS flips up and opens back toward the rear of the bike making it necessary to get the fuel nozzle / handle up between the handlebars etc.. It seems like it should flip forward on the bike.
Has anyone tried or is it an easy fix to turn it 180 degs?
RobStar
Robert
Las Vegas
2015 1200GS Adventure
RobStar is offline   Reply With Quote
Old 06-24-2010, 08:44 AM   #2
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,186
Even more ridiculous is that there isn't any provision for mounting to a tankbag ring (as on the 05-07 versions). That weird triangelaround the cap looks arbitrary, IMHO.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is online now   Reply With Quote
Old 06-24-2010, 10:29 AM   #3
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,788
RobStar
It has been done. Here is one:
http://davedragon.rilysi.com/2008/02...od-rilysi.html
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline   Reply With Quote
Old 06-24-2010, 01:25 PM   #4
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 4,000
On '05-'07 yes.
I've heard that on newer models the mounting bolt pattern is no longer symetrical.
http://www.oilandpiston.com/
Well hes one of those who knows that life
Is just a leap of faith
Spread your arms and hold you breath
And always trust your cape (Guy Clark)
VonHelm is offline   Reply With Quote
Old 06-24-2010, 03:58 PM   #5
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,321
Yep dealing with that
Just bought a Daybag II from Twisted-Throttle and the appropriate gas cap ring. I have to remove the locking mechanism from the old one and apply it to the new one.
But, its well made stuff
John Hart McComb MS
2003 Ducati 999s "Christine"
2008 BMW R1200GSA Mary Jane
2005 Chaparral 210ssi " Native Sun II "
onesaintsfan is offline   Reply With Quote
Old 06-24-2010, 04:19 PM   #6
mkletecka
Oddometer: 286
I wanted to do the same/tried on my O8, however I had no luck. In closing, I've given up and just got used to a bit of hassle when its comes time to fuel up.
Mike K.
Dana Point, CA.
mkletecka is offline   Reply With Quote
Old 06-24-2010, 05:41 PM   #7
GS_Pilot
Oddometer: 200
Originally Posted by VonHelm
On '05-'07 yes.
Correct.
They changed it for the 2009's.
I saw the link and tried to reverse mine.
Different mount.
Had to put everything back.
Still opens to the rear.
Still have to move my Ram mounts forward to clear the fuel nozzle.
I'd like to kick the designers ass.
GS_Pilot is offline   Reply With Quote
Old 06-24-2010, 07:46 PM   #8
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 4,000
Originally Posted by GS_Pilot
Correct.
Different mount.
More likely a liability lawyer than an engineer, to discourage filling the tank while seated. Back in the 70's, all hinged MC gas caps hinged forward, like they are supposed to be.
Old 04-26-2013, 10:57 AM   #9
minidisco
When are we going?
minidisco's Avatar
Oddometer: 168
I just bought a 2012 model to replace my old 2005 GS, onto which I did the fuel cap surgery (see http://www.motorcycleinfo.co.uk/inde...&pageId=264247), and it was by far one of the best modifications ever.
However, on the 2010 and up models, the gas cap now has an EXTERNAL hinge point, plus it looks like the entire seating ring extends beyond the neck of the fuel filler area and under the plastic tank cover. I tried rotating it just 15min ago, took out all 7 bolts and discovered the extended lip - might revisit this over the weekend and disassemble a lot more of the fairings and stuff, to see if the flip is possible (even with some Dremel surgery if needed).
Can't stand having that cap open towards the seat: dumbest thing ever!
minidisco is offline   Reply With Quote
Old 04-26-2013, 09:21 PM   #10
crash a-ron
mmm...burnt steel
Oddometer: 326
Billet cap!
I had one of these billet caps on my old GS, and it worked fantastic! No hinge at all, and it makes filling up easy even with those damn foreskin fuel pumps.
http://www.slingshotracing.net/catal...cap-p-219.html
Aaron "It is all fun and games until Shoulder Surgery."
Seattle, Washington
crash a-ron is offline   Reply With Quote
Old 04-26-2013, 09:42 PM   #11
hammick
hammick's Avatar
Oddometer: 1,924
What's interesting is the new watercooled GS went back to the torque bolts for the gas cap ring.
2015 R1200 GSA
2014 Moto Guzzi California Custom
2014 Husky FE501
hammick is online now   Reply With Quote
Old 04-29-2013, 08:47 AM   #12
MrMike
No self control
MrMike's Avatar
Oddometer: 794
Just make cap removeable
It's a 10 minuet job to make the cap removable. It makes it really easy to fill up.
Stuff a rag in the hole, remove the bolts that hold the ring, turn it over and remove the two screws that hold the black piece on, where the steel pin goes through the cap fill with some silicone so the pin won't fall out, reinstall the ring, then just slide in the cap and lock down. Now it just slides out when refilling so no chance to brake it off when filling up.
My friend was complaining about this on his '09 so when I got my '10 I told him I'd find a fix for it. I called him back in 15 minuets later and told him it was fixed. It works great with my tank bag ring. Much easier to fill with the fillers here in Ca.
'09 KTM 530 EXC
'10 BMW R1200GS
'06 Bmw HP2 Enduro
'06 Ktm 950 SM
MrMike is offline   Reply With Quote
Old 04-29-2013, 09:44 AM   #13
minidisco
When are we going?
minidisco's Avatar
Oddometer: 168
Some pics would help, please!
Old 04-29-2013, 10:27 AM   #14
MrMike
No self control
MrMike's Avatar
Oddometer: 794
Pictures
When you take the cap and ring out it will look like the top picture. You then take the two little screws out of the black plastic piece on the left (little screws are already out in photo). Then as you can see in the second picture the cap just slides free of the ring. Put the ring back in. You can see in the cap part where the pin is on the left that I put a dab of red silicone in the gap to keep the pin from falling out. Just leave the black part out and the cap will just slide forward a little and come right out when your filling up.
'09 KTM 530 EXC
'10 BMW R1200GS
'06 Bmw HP2 Enduro
'06 Ktm 950 SM
Old 04-29-2013, 01:41 PM   #15
QED
Oddometer: 355
I don't think that's the reason
I heard it was so your cap wouldn't take you nuts off if it pops open in a crash when you go over the top.
QED is offline   Reply With Quote
Times are GMT -7.   It's 09:08 PM.
