Old 06-24-2010, 11:57 AM   #1
mdmaroon OP
Mike
Oddometer: 157
Help Me Identify CCP in this photo
I'm thinking of removing my CCP (Cat Code Plug) to cure a surging issue. I have seen it described as being yellow, and in the center of the fuse box. Well I have a yellow relay (or whatever it is), but not in the center. Do I have a CCP at all? Is it the yellow one off to the side, or is it supposed to be where the empty socket is...
Thanks....
mdmaroon is offline   Reply With Quote
Old 06-24-2010, 12:02 PM   #2
MudSling
MudSling's Avatar
Oddometer: 386
Thanks....
You don't have a CCP on your bike. It would be where the white square socket is... my '01 1150GS didn't have one installed when I bought it either.
You can try the StepToe jumper mod which often helps.
'06 HP2 Enduro
'01 R1150GS
Montreal, Canada
http://apormc.com/
MudSling is offline   Reply With Quote
Old 06-24-2010, 12:42 PM   #3
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
cgdrake is correct. The cat code plug is a jumper. I is the only "relay" with only two terminals.
Beemers Uber Alles
9248 Mike Garcia Drive
Manassas Va 20109
(571) 318 2472
Indie BMW Maintenance
www.beemersuberalles.com
GeorgeinVA is offline   Reply With Quote
Old 06-24-2010, 12:42 PM   #4
bigdave-gs
Explorer
bigdave-gs's Avatar
Oddometer: 1,900
Send a message via Yahoo to bigdave-gs
what does this jumper change on the bike. Is it for bikes that have removed the stock exhaust? I have thought about changing my exhaust system out for the Wunderlich collector and the Wunderlich tuner so I wouldn't burn my valve from running lean.
It is said, some lives are linked across time, connected by an ancient calling that echoes through the ages.
Currently riding a 2004 R1150GS Adv. but a very long list of others over the 30 + + years of riding
bigdave-gs is offline   Reply With Quote
Old 06-24-2010, 01:06 PM   #5
mdmaroon OP
Mike
Oddometer: 157
Hey thanks! I'm going to try that out. Is the jumper position shown in your pic the best or only option?
I have a Y pipe so that is probably why the CCP is gone.
Old 06-24-2010, 01:14 PM   #6
MudSling
MudSling's Avatar
Oddometer: 386
Read this thread: http://www.advrider.com/forums/showthread.php?t=189972
It will answer some of your questions and has a chart with the various jumper settings.
Good luck!
'06 HP2 Enduro
'01 R1150GS
Montreal, Canada
http://apormc.com/
Old 06-24-2010, 04:02 PM   #7
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,189
Eh? How Much $
Wonder how much BMW charges for that little Faux Relay? That is crazy
John Hart McComb MS
2009 Triumph Speed Triple "the mistress"
2008 BMW R1200GSA-" the wife"
2005 Chaparral 210ssi " Native Sun II "
" Damn a motorcycle, if somone would buy this thing I would take the bus home "
onesaintsfan is offline   Reply With Quote
Old 06-24-2010, 04:26 PM   #8
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
$6.42
Beemers Uber Alles
Manassas Va 20109
(571) 318 2472
Old 06-24-2010, 10:46 PM   #9
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Originally Posted by GeorgeinVA
$6.42
Really? At least that's halfway reasonable. If I remember, that thing used to be $35.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 06-25-2010, 09:20 AM   #10
def
I have little to say
def's Avatar
Oddometer: 6,305
Send a message via Skype™ to def
BMWs for Canadian delivery are not fitted with the CCP. Only US bikes are. The CCP for US bikes is yellow/gold in color. The CCP selects the appropriate map in the ECM based upon emmissions requirements. Instal the US CCP and you'll get better mileage.
def is offline   Reply With Quote
Old 06-25-2010, 10:47 AM   #11
mdmaroon OP
Mike
Oddometer: 157
I did give it a try and it seemed like the slow speed throttle response was better (meaning more progressive and easier to use small amounts of throttle).
After a bit more testing, I found that the mid range power was kind of flat. Like it was getting either too much fuel or not enough (not sure). Kind of like the engine bogged a bit in the mid RPM range.
I removed the jumper as it did nothing for my surging issue which is what I was trying to fix. I think I'll just live with it, because apparently it is normal from what I've been reading.
Old 06-26-2010, 10:57 AM   #12
BluByU
BluByU's Avatar
Oddometer: 388
"they all do that"
Surge, surge SURGE what is this you speak of ??
OK, Ya they all do that, and have tried everything to solve it. some what better
best mod was the CCP jumper.
I did the 30 to 87a jumper,
Better low throttle response.
Fuel millage got better this makes no sense to me, but I am not complaining
Yes a bit flatter in the mid range, barley noticeable
"your results may very"
The 1100GS has a y pipe and low restriction muffler and I ride it like I stole it
BluByU is offline   Reply With Quote
Old 06-30-2012, 05:20 PM   #13
GmanVic
GmanVic's Avatar
Oddometer: 92
A surging we will go!
I bought a 1997 R1100GS from Seattle last year (I live in Victoria, BC) and love the bike EXCEPT FOR the surging issue. Been working through all the AWESOME advice on this site, including meticulous Rocker Arm and valve adjustments; new plugs; complete Zero=Zero; bought a TwinMaster and everything (woohoo)! So far, no improvement. I have just changed the throttle cables and aircleaner and now putting 'er back together. Thanks for all the great wisdom, wit, experience, and opinion on this site. I will post (here? someother thread?) with those results.
GmanVic is offline   Reply With Quote
Old 07-03-2012, 12:20 AM   #14
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 8,033
You can connect the bottom jumper to the right for low octane fuel.
I am not intimidated by the DMV
James and Colleen Tucker.
Real Cafe Racers drink tea.
Aut viam inveniam aut faciam
TUCKERS is offline   Reply With Quote
Old 07-03-2012, 03:00 AM   #15
roger 04 rt
roger 04 rt's Avatar
Oddometer: 839
Here is a link to jumper info: Coding Plug Info
On the R1100GS the 30-87a jumper wire disables the O2 sensor and accesses a richer fueling map. It you do that, it's a good idea to add a CO potentiometer and get CO adjutee to 1.5%. Before doing that I'd ask if your bike runs better when the engine is cold.
Looks like you're working your way down the list. It'd probably be a good idea to start a different thread for your questions.
roger 04 rt is online now   Reply With Quote
Times are GMT -7.   It's 10:18 AM.
