Old 01-06-2013, 12:42 AM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
Shift linkage boss?
When did the airhead frames first get the boss to which the shifter linkage attaches? As opposed to the shifter that attaches directly to the shifter shaft on the gearbox...
I find pics of /5 and /6 bikes without it, and later bikes with it. But when did it first appear?
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is offline   Reply With Quote
Old 01-06-2013, 01:29 AM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,594
I'm not too sure but I thought it was 77/78 but a lot of bikes had it retrofitted because it improves the gear change so much.
Rob Farmer is offline   Reply With Quote
Old 01-06-2013, 02:33 AM   #3
carpetburn
Oddometer: 129
correct- i fitted one to my/6
carpetburn is offline   Reply With Quote
Old 01-06-2013, 03:05 AM   #4
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,469
It's easy enough to find pix of 1978 models with the direct gear lever, and even some 1979 ones. I'm guessing it's during the 1979 model run starting with the straight rod with the rubber bellows cover.
edit: Have a look at this 1978 brochure...
boxerboy81 screwed with this post 01-06-2013 at 03:15 AM
boxerboy81 is offline   Reply With Quote
Old 01-06-2013, 11:08 AM   #5
rambozo
rambozo's Avatar
Oddometer: 528
Both my 78 and 79 have the rubber bellow shifter as per that photo
Robs probably right with 77/78 year
rambozo is offline   Reply With Quote
Old 01-06-2013, 11:28 AM   #6
CanadaBiker
Oddometer: 265
Does it really improve shifting that much?
I have a direct on my '77, but I haven't been able to put many miles on the bike since I got it. Although, my left foot feels a bit cramped on the peg and that the shifter doesn't stick out far enough to get my toe under it. But I wonder if changing to the linkage would improve that specific issue.
2005 Suzuki DR650, 1987 BMW R80
CanadaBiker is online now   Reply With Quote
Old 01-06-2013, 12:02 PM   #7
outfit
outfit's Avatar
Oddometer: 658
I've retrofitted both my Mono and /7 to direct year's ago The gear linkage may well have been okay when new, but the sloppiness soon set's in. Anyway's I think it was just a publicity stunt by BMW in answer to press complaint's.
outfit is offline   Reply With Quote
Old 01-06-2013, 12:57 PM   #8
DiabloADV OP
Semi-Occasional
Oddometer: 2,275
My bike is a 74 90/6, and has the shifter boss. So I guess it was retro-fitted. How would somebody tell a /7 frame from a /6 frame?
1970 R60/5
Old 01-06-2013, 01:28 PM   #9
supershaft
because I can
Oddometer: 9,116
It had to of been late '78? I remember lots of our customers making the retro-switch. Lots of people said that it improved shifting quite a bit. I do too. Sloppy? The have replaceable bushings, bearings, and bolts. I have repaired quite a few of them and then they are like new again.
Old 01-06-2013, 10:51 PM   #10
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,542
Serial number?
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Times are GMT -7.   It's 04:18 PM.
