Old 01-06-2013, 12:07 PM   #1
woodly1069 OP
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,854
R75/5 engine removal
Isn't it typical that one or two little things lead to an entire tear down? Well it is for me...Just wondering about this last bolt, the one that runs under/through the engine. The engine is pivoting on it when I take the rear one out. Is it a long stud like the rear one or is there a trick I'm missing? Doesn't look like there are any seals around it so I assume that it isn't in the oil...Just don't want to beat on the thing and break the engine casing! Any thoughts?
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 01-06-2013, 12:19 PM   #2
dmftoy1
dmftoy1's Avatar
Oddometer: 240
Two long through bolts on my 74 r90/6. The rear is longer because the foot pegs bolt to it. Pretty sure /5 is identical frame/mounting wise. Mine had significant corrosion which kept it from coming out easily.
Good luck!
dmftoy1 is offline   Reply With Quote
Old 01-06-2013, 12:36 PM   #3
pbarmy
pbarmy's Avatar
Oddometer: 1,818
Get a drift and pound her thru.
"Nostalgia ain't what it once was"
pbarmy is offline   Reply With Quote
Old 01-06-2013, 12:51 PM   #4
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,854
OK fellas! Thanks a bunch!
Old 01-06-2013, 02:02 PM   #5
dan-o
Oddometer: 80
get a jack under the engine to take the weight off
dan-o is offline   Reply With Quote
Old 01-06-2013, 02:36 PM   #6
woodly1069 OP
woodly1069's Avatar
Oddometer: 1,854
yo Dan O that's exactly what I did and just so everyone knows for sure, the front was a long stud just the same as the rear one and there was corrosion all over it so I just pounded it out! Thanks guys the engine is out of the frame!
Times are GMT -7.   It's 07:34 AM.
