Old 07-01-2010, 12:57 PM   #1
Airhead Wrangler OP
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,607
Airhead mono final drives
Couple of questions for those who've been there / done that. I'm doing some long term planning for a revamp on my bike and was considering a slightly higher final drive ratio in order to save a bit of gas and maybe get a little more speed. I was wondering if the later Monolever final drives have the same spline as the earlier G/S and ST final drives. Also, will a later GS 4 lug wheel mount up to the monolever 4 lug final drives? I'm betting StephenB can shed some light here.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 07-01-2010, 02:18 PM   #2
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,193
For example a 1989 monolever rear from a RT will fit.
Four lug has the same patern but wheel ofset is totally not the same
Caddy82rats is offline   Reply With Quote
Old 07-01-2010, 02:24 PM   #3
Airhead Wrangler OP
Adios Mexico
Oddometer: 6,607
The offset of the rim in relation to the hub or the offset within the hub itself?
Old 07-01-2010, 02:33 PM   #4
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Sure can do!
G/S and ST have 3-lug final drives, both with the known 37:11 ratio. Acc to the ETC there are further crowngear sets available in 32:9 (R65 I believe) and 32:11 (Swiss model, Joerg should be able to confirm).
4-lug final drives can be had in 33:11, 32:10 and 37:11 (33:11 is the nicest on a 1000cc engine for street, IMHO).
Input FD splines are all the same.
All 4-lug monolever FDs work with the 4-lug GS hub (see link below) and whatever you lace to it, obviously ;-)
Two relevant links:
Paralever -> Monolever conversion: http://www.stephenbottcher.net/BMW/paraconv.htm
Spoked wheels on a monolever:
http://www.stephenbottcher.net/BMW/rearconv.htm
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
StephenB screwed with this post 07-01-2010 at 04:32 PM
StephenB is offline   Reply With Quote
Old 07-01-2010, 02:38 PM   #5
Caddy82rats
Oddometer: 1,193
Stephen had put all the information here
http://www.advrider.com/forums/showt...paralever+mono
Edit : Oops too late Stepfen had been faster than me
Times are GMT -7.   It's 02:52 AM.
